The contrast on my flatscreen TV keeps going back up to 100 even though I hit the enter button when I lower the contrast to 50
SOURCE: The Contrast screen pops on all the time
It looks like your UP button contact is demaged.
SOLUTION is to insert a piece from your business card mostly above the button to adjust it down or up. It works fine.
Posted on Feb 02, 2008
  • 28 Answers
SOURCE: contrast 100 window keeps appearing on screen
try to use the monitor menu button and do a factory reset, it should take care. try to unplug the monitor cable from the tower you will get monitor self test if its good then the problem is not with the monitor it should be the problem with the tower.
Posted on Jun 10, 2009
Ryan5443
  • 336 Answers
SOURCE: Volume won't stay set
There have been many new things that have been introduced when Google bought Youtube, and I believe that one of them is that it resets the computers speaker volume all they way up, the best I can currently suggest is that you leave the computer volume up and turn the physical speaker volume down, and it should be fine.
Hope this has helped,
Ryan Frame
Creative Energy Associates Technical Center
Posted on Aug 17, 2009
Geekman
  • 32281 Answers
SOURCE: it looks very dark
The fault could be a faulty inverter board or a faulty CCFD lamp.
The inverter supplies high voltage to the CCFL lamp. The CCFL lamp is a mini fluro lamp and can dim with age.
Check LCD Parts for service, parts and DIY info - click on this link to their WEB site : -
www.lcdparts.net
Posted on Oct 06, 2009
Sarethan
  • 76 Answers
SOURCE: contrast 100 box
That would be the monitor and not the PC. try going to menu on the monitor and doing a factory reset.....if that doesn't work unplug for 3mins and try agin....if neither work then your monitor is faulty. Hope this works out for ya
Posted on Nov 02, 2009
How to set power settings
Set the time as you normally would to cook your food: i.e. 60 seconds. Hit the power button; 100 will pop up on the screen, as in 100 % of power, enter 50 for 50% power, 70 for 70% etc. Food will cook more evenly this way, not burnt to a crisp on the outside, cold in the center.
Mar 13, 2013 | Rival Rgst902 Microwave Ovens
The volume on my plasma tv goes up to 100 and when i lower the volume it will take a second volume for the volume to go up to 100 how can i fix my tv to lower the
The tact switch is most likely defective which is keeping the volume up engaged. Replace the tact switch should fix the issue. If not the button assembly pcb will need replacement. You can get replacement boards from www.tvcircuitboards.com
Dec 10, 2012 | LG 60PC1D 60 in. Plasma Television
Want to know how to adjust contrast
Very old set--always adjust so contrast not too high--it should always be lower than brightness---say brightness at 75% and contrast lower--if contrast set too high smearing will occur and picture quality will be affected.
Apr 08, 2012 | Televison & Video
What are the best settings so that i can get the best picture from samsung plasma tv model PS50A457P1D?
hi can i just add? I have recently got this tv but for some reason when i set setting to Normal they reset to dynamic?? After about twenty mins? I keep having to change back to normal or if i set it to perfect brightness etc... it just goes back to dynamic again? i.e cell light 100% and contrast up to 100%!
Why is this??
Mar 09, 2012 | Samsung PS50A457 50 in. Plasma TV
LG Plasma TV, 42
Hi that wold indicate a problem with one of your sustain boards. Most likelly the y-sus but it could be either one. You can find parts for this TV at www.interliquidparts.com remember when ordering parts you have to go by part number of the part.
Feb 24, 2012 | LG RU-42PX10 42 in. HD-Ready Plasma...
LOOKING FOR PICTURE SETTING SAMSUNG MO.NO.LN-T5265F
This may help you...you can also get an owners manual free on line.
English - 23
Using Automatic Picture Settings
Your TV has Three automatic picture settings ("Dynamic", "Standard", "Movie") that are preset at the factory.
You can activate either Dynamic, Standard, Movie by making a selection from the menu.
1. Press the MENU button to display the menu.
Press the ENTER button, to select "Picture".
2. Press the ENTER button to select "Mode".
Press the ??² or ??¼ buttons to select the "Dynamic", "Standard", "Movie" picture
setting. Press the ENTER button.
?³ Choose Dynamic to increase the clarity and sharpness of the picture.
?³ Choose Standard for the standard factory settings.
?³ Choose Movie for a natural Image without picture enhancements.
3. Press the ??² or ??¼ buttons to select "Contrast", "Brightness", "Sharpness",
"Color", or "Tint(G/R)", then press the ENTER button.
4. Press the ??? or ??? buttons to decrease or increase the value of a particular item.
For example, if you select "Contrast", pressing the ??? button increases it.
Press the EXIT button to exit.
• When you make changes to Contrast, Brightness, Sharpness, Color, Tint(G/R)
the OSD will be adjusted accordingly.
• When in PC mode, Tint, Sharpness, and Color are not available.
Press the P.MODE button on the remote control repeatedly to select the desired
picture mode.
Picture Control
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 00
??¼More
TV Picture
Move Enter Return
Mode : Dynamic
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
Dynamic
Standard
Movie
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balck light 1 0
??¼More
TV Picture
50
??² Con trast ??¼
Move Adjust Return
English - 24
Adjusting the Color Tone
You can change the color of the entire screen according to your preference.
Press the ENTER button to select "Picture".
2. Press the ??² or ??¼ button to select "Color Tone", then press the ENT ER button.
3. Press the ??² or ??¼ button to select "Cool2", "Cool1", "Normal", "Warm1",
or "Warm2".
When the picture mode is set to Dynamic or Standard, Warm1 and Warm2
cannot be selected. Movie mode is only available.
Move Enter Return
??²More
Color Tone : Cool2 ???
Detailed settings ???
Size : 16 : 9 ???
Digital NR : Low ???
Active Color : On ???
DNle : On ???
Reset : OK ???
TV Picture
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : On
Reset : OK
TV Picture
Cool2
Cool1
Normal
Warm1
Warm2
Activating Backlight
You can adjust the screen brightness by adjusting the LCD backlight brightness. (0~10)
2. Press the ??² or ??¼ button to select "Backlight", then press the ENTER button.
3. Press the ??? or ??? button to decrease or increase the valueof the backlight
brightness.
Move Enter Return
Mode : Dynamic ???
Contrast 1 00
Brightness 50
Sharpness 85
Color 55
Tint G 50 R 50
Balcklight 1 0
??¼More
TV Picture
5
??² Balcklight
??¼
Move Adjust Return
Move Enter Return
??²More
Color Tone : Cool2
Detailed settings
Size : 16 : 9
Digital NR : Low
Active Color : On
DNle : Off
Reset : OK
TV Picture
OK
Cancel
Resetting the Picture Settings to the Factory Defaults
1. Press the ??² or ??¼ button to select "Reset", then press the ENTER button.
Press the ??² or ??¼ button to select "Cancel" or "OK" then press the ENTER button.
Each mode can be reset.
Feb 04, 2011 | Televison & Video
My tv is about 2 years old. It just started burning old images into the screen and they slowly fade away but its very annoying.
Removing burn-in takes time. The best practice is to avoid creating the images.
Whatever the image is coming from has been left on screen for an extended period of time. The TV should be turned off or the source turned off when not watching.
You may find some relief by lowering your contrast (which I am suspecting is still at or near 100% as they come from the store). Bring contrast down to, say 60. Use brightness or backlight to brighten the screen if you think it is too dark with the contrast lowered. (Best picture quality is near 50, the center of the scale.)
Jun 13, 2010 | Televison & Video
I need a manual for a Samsung tantus flatscreen TV
I checked that model number and even on Samsungs service portal doesnt have that model number listed which is weird since they have manuals available for all models since the mid 1980's.
Is that the model number or the chassis number?
Nov 23, 2009 | Televison & Video
Screen goes blank, sound still on
even though lamp came back on and worked for awhile, it was a bad lamp. replaced lamp and set works
Mar 23, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
Dec 09, 2007 | ViewSonic VX910 19" LCD Monitor
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
