The smoke effect keeps going off every so often and then comes back on.I have cleaned it out as instructions,but still does it on my cavendish CSH20 PS love the fire
2 Suggested Answers
  • 4736 Answers
SOURCE: On a Dimplex Cavendish CSH 20 the smoke effect and
Right off hand, I'd say the light bulbs are burned out and need to be replaced. The model you listed comes in 2 editions, one with a misting effect and the other without. In both, the bulbs are replaced the same way - by opening the sump door to access the bulbs.
To further help you, I have included a link to the Owners Manual for your model. You may download and print it for future reference.
http://www.dimplex.co.uk/assets/kb/operating_instructions/0/Cavendish_Chesford_Opti-myst_Issue_1.pdf
Hope this helped you resolve the problem. Please let me know. Thanks.
Posted on May 24, 2011
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
Car running lean on bank 2, changed intake gaskets and pcv valve
what does exhaust smell like you may have carbon build up in engine try removing o2 sensors and cleaning with brake clean and reinstalling reset code and see if it comes back and how long it takes to reset also you can put a can of berryman in the gas tank with at least 1/2 tank of gas or more also buy a can of sea foam and install through vacuum booster hose you may see lots of black smoke from tail pipe if so after following instructions for application drive some what hard and if the black smoke continues fore at least a mile keep driving and if you notice a diff in runability but still have a little black smoke buy another can of sea foam and repeat service NAPA has sea foam on sale this month
Apr 11, 2012 | 1996 Chevrolet Impala SS
On a Dimplex Cavendish CSH 20 the smoke effect and lights do not operate. What should I be looking for\r\nNeil
May 24, 2011 | General Heating & Cooling
Alarms keep going off but no fire
There may be a short in the system. But
Hopefully, that should solve the problem. Please let me know.
Feb 12, 2011 | Kidde 4618 Firex Hardwire Ionization Smoke...
Smoke come up from bottom of 3-month new smeg oven SA702X when try to heat up
Hi.
Smoke coming from the oven is not normal. Ensure that the smoke is not vapour coming from the food inside the oven.
If there is vapour coming from the hinge area, then ensure that door and hinges are installed properly.
If you get smoke from the oven, try cleaning the oven cavity, follow the instructions on manual to clean the oven.
If after cleaning the oven, there is still smoke coming from the bottom side, then call Smeg and have the oven replaced. There is one or two years warranty on the appliance.
Smeg support and service phone number is listed in the oven manual.
Regards.
Mar 09, 2010 | Smeg Ovens
Smoke and fumes coming from oven
Sounds like you need to clean the whole oven as old grease and spillages will keep on burning and smoking.
Jan 03, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Vcr doesn't record sound. Though it plays back
Needs cleaning. You can either use headcleaner cassette ( not always effective ( If you can find the type with micro-filament brushes they're more expensive but far more effective and last forever ) ) ; or alternatively do it manually ( sometimes neccesary ) ; unplug unit, remove the cover and clean all the surfaces that the tape comes into contact with ( using Q-tips and head cleaning fluid ( most effective ( when done thoroughly ( have to keep at it until absolutely no trace of black carbon comes off on Q-tip ) ) ) .
Oct 15, 2009 | Sony SLV-N750 VHS/S-VHS playback VCR
Black smoke
Change your air filter and clean the blow by tube that crosses the heads and connects to the back side of the air filter. If the tube or the air filter is clogged, then the oil that the blow by removes is going back into the cylinders, causing the black smoke. Also keep in mind that a Harley will blow a little black smoke upon starting as it ages, it's normal.
Jul 26, 2008 | Harley Davidson Harley-Davidson Motorcycle...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
