Question about Whirlpool Washing Machines
I have a whirlpool 7410/1 washing machine. I pulled it out today to clean behind. Now I don't know we're red pipe goes
    Sergeant:
  • Whirlpool Expert
  • 448 Answers
Hot water marked on back of machine
  • 262 Answers
SOURCE: washing machine
there is a tool that hooks to you garden hose that goes in your pipe and expands then blows water down the drain to blow out stoppage it work great you can get it at your local hardware store
Posted on Dec 20, 2007
SOURCE: miele W830
I have exactly the same problem - what was the answer ?
Posted on Apr 05, 2008
  • 1028 Answers
SOURCE: clean pump!
remove bottom panel torx or 7 mm nut driver needed.pump has "knob" turn counter clock wise ..have plenty of towels handy to unlock door first reach up to bottom of door lock tear shaped plastic tab pull down door will open
Posted on Apr 28, 2008
SOURCE: Whirlpool AWO/D 4505 Washing Machine
Unplug your machine and unclip the plastic trim panel across the bottom of the machine (front) to reveal the circular pump filter cover. Unscrew this cover with your fingers and remove any debris inside. Put the cover back on, clip the panel back on and try your machine again. Should be fine.
Posted on Feb 05, 2009
  • 1891 Answers
SOURCE: How do I clean my whirlpool washing machine pump?
rmove the 3 screws ot the bottom of toe panel . pull down and out to remove . pump is just right of center . about a 3 in lid rigt in front turn t open and clean out tray . mm.
Posted on Nov 20, 2009
Testimonial: "Thank you very much for your help, it worked like a charm."
Whirlpool SM8281115
You probably have the end of the outlet hose too low to the ground it should be about half way up the back of the machine or fitted into a stand pipe.
http://selfix-uk.co.uk/under%20sink%20plumbing.html
or the water entering the machine will just siphon out
Mar 28, 2017 | Whirlpool Washing Machines
The clean filter light is on, where is the filter on the Whirlpool AWD3571
There is a little door set in the botton right of the front of the machine. Flip the door open, the filter is behind it (It unscrews).
Can't recall if this model has a little drain pipe that you pull out do drain off any dregs of water in the filter. If it doesn't, I usually pull the machine out from the wall and tip it back a little so the water in the filter doesn't pour out when I unscrew it. HEAVY MACHINE, if you are going to tip it backwards, have someone help you do this!
Please rate this solution
Jul 18, 2011 | Whirlpool Washing Machines
Water is not getting into the washing machine. Fridgidaire Crown series. Water is coming through the hoses. Detatched hose from washer, water still comes out. Cleaned screen on back of washer. No...
Hi. sounds like the pressure system is blocked if it goes through a cycle with no water. Find the pressure switch in the top of the machine its the size of a small coffee jar lid, it has wires and a thin rubber pipe to it, pull the pipe off and see if the switch clicks as you do so. If it does you need to follow the pipe, at the end it goes to the pressure chamber.It will be blocked with gunge and will need cleaning out, also blow through the pipe to make sure thats clear. Make sure you fit the pipe back with no air leaks or the machine will over fill and flood.If you don't feel confident in doing this Please call an engineer.Best to be safe, it could also have damaged the heater or thermal cutout
Regards Elect App
Jul 14, 2011 | Washing Machines
Clean pump indicator light on washing machine whirlpool wfs1273bw
The Pump is directly behind the bottom panels plug. The Pump is gravity fed via a large pipe connected to the bottom of the drum sink (The bit that collects all the water from the the bit that spins). There are 2 outputs from the pump. The pressure side (coming out of the hose) and the auxillary drain (the black plug behind the bottom panel). Undo the plug as mentioned above... and if you have taken the thing outside to drain it, you might as well tip the machine up on its side and pull out the big hose off the drum sink (mentioned in a post above) to check that nothing is blocking that either, As you will see when you tip it up and look in from underneath the machine, it's just a small pump, easilily accessible. Nothing complicated about it.
Mar 16, 2011 | Whirlpool Washing Machines
My duet frontloader is shooting water from the area where your detergent goes it is not going in the machine
Hi from retired Englishman in SW France @14:22 Sat afternoon!
Suggestion- remove the detergent tray by pressing (not too) firmly on the (plastic) lip at the back centre of the tray and pull out.
Clean it really well and also see if behind the tray has not some foreign objects in it. Clean the whole area also- I use a dish washing brush to clean the jet to ensure the water goes straight down into the tray rather than squirting all over the place!
Hope this helps,
Cheers,
John C
Jan 29, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool 6th Sense AWOE8759B Wont drain or spin
look for the filter under the machine or sometimes on the front behind a flap and clean it out along with the pipes and hoses all leading from the pump to the drum some times you may find the waste pipe is blocked
Jan 19, 2011 | Whirlpool Ultimate Care II LSQ9549L Top...
My Whirlpool washing machine WFS1273AW, has been displaying "clean pump" and F02. I have cleaned the pump and even had a repair man change the pump. However the machine won't move beyond the wash cycle and...
The same thing happened to me and it was because there were socks stuck where the drain pipe attaches to the machine. If you tip your machine on its side and pull the black pipe off from the bottom of the drum you can remove anything which is stuck. Then it just clips back on again with a metal clip.
Aug 31, 2010 | Washing Machines
How do I clean my whirlpool washing machine pump? The red light of my washing machine is on and it is saying clean washing machine pump and my washing machine door won't open.
Nov 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Clean pump!
Apr 26, 2008 | Whirlpool AWM8143 Front Load Washer
Doesn't fill
Is your outlet pipe at the required height behind the machine? Your outlet pipe should be approx 3 feet high behind your machine, or the water would just flow out. The pump in your machine pumps the water OVER this height. Check this out.
Aug 31, 2007 | Whirlpool GHW9400SU Front Load Stacked...
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
