Question about Canon imageRUNNER 3030 Black and White Copier
How to scan and save matter in canon ir3030? I could not able to find the way!
How to scan with my printer canon mg 2965
1. First, Install the MP Navigator EX software.
2. Select "Start" > "Programs" > "Canon Utilities" > "MP Navigator EX" > "MP Navigator EX".
3. Select "Photos/Documents".
4. Open the top of the scanner and place the document you wish to scan on the glass.
5. Set preferences on the screen as needed. Select the "Scan" button when ready.
6. The Pixma 5220 should start the scanning process. When it's finished, select "Save" to save the document(s) as a JPEG, or select "Save as PDF" to save it in PDF format.
If you want any help in writing your assignments, you can approach custom essay writing service.
Jul 20, 2016 | Canon Office Equipment & Supplies
Canon ir 3030 paper loading problem in cassette
The problem could be one of several things.
1) Check your "printer preferences" setting and make sure you have selected the CORRECT SIZE OF PAPER. For example; Letter, Legal, etc.
2) Un-install and re-install the drivers.
Hope these suggestions help.
Nov 03, 2014 | Canon imageRUNNER 3030 Black and White...
Why won't my canon mp495 scan photo's to documents? it scans them but will not save them
are you using the software that came with your canon?
if so you need to save them manually or you are not knowing where exactly it is saving them
Mar 03, 2011 | Canon PIXMA MP495 InkJet Printer
Canon dr 6080 scanner is getting papers but i dont know where the scanned images are being saved and whether being saved or not?
What scanning software are you using? Once you initiate scan command, the software will ask for location (and format) where you want to save the files. After scanning, try & use 'Save as' command, by default it will go to where it is already saved. Alternatively, search for the file name under Windows.
S. Mohan
Aug 16, 2010 | Canon DR-6080 Path-Through Scanner
How to scan a document using Canon MX310 to Microsoft Word
you can try it by using the scanner option on the control panel. If you are using windows operating system, go on start menu, select control panel and double click scanners & cameras. Double click the scanner online and start scanning the documents. Save it in the format you want but it is usually default as jpeg.
scanned documents usually saved as .pdf file if you run the scan option directly on the printer. By pressing the SCAN button the printer. So do not use this option if you do not want the documents to be saved as pdf files.
Mar 30, 2009 | Canon MX310 Office All-In-One Printer
Canoscan lide 70
Head for the Canoscan Toolbox and click on "Settings".
Under "select folder where temporary files are saved", click on "browser".
Choose where you want the scanned item to be sent and then click 'OK".
This works for me.
Jun 08, 2008 | Canon CanoScan LiDE 70 Flatbed Scanner
Scanning negatives on CanoScan 600F, I get an error message "Cannot write or read. 252.0.0"
The Canon support site is the place to go for that if your Manual does not tell you.
However remove the software and reload it - it may be as simple as that.
Dec 26, 2007 | Canon CanoScan LiDE 600F Flatbed Scanner
Canon imageRUNNER 3030 Black and White Copier Logo
63 people viewed this question
old marine
old marine
