Question about Music
Tryin to find some information on my BC Rich Warlock, serial number 42410841
  • 11 Answers
SOURCE: How do i repair my B.C. Rich guitar??
Guitar manufacturers use generally one of two different knob types: (1) knob has a small set screw of some type holding it on or (2) press fit onto the shaft of the tuneing pot (volume knob in your case).
Now, the problem is if it is NOT a set screw type, it is press fit. You see press fit used most of the time on lower-end instruments (and a few high end). The BEST way to get a stuck volume know off is to get a shoe string, loop part of it under the knob, brace the guitar firmly and PULL SLOWLY WITH FORCE. Realize that it is possible to damage the guitar if you **** on the string too hard.
I have never seen where a stuck know did not come off (or hear of someone breaking their guitar doing it).
I have also resorted to using a small screwdriver: work it way under the know and gently twist it to loosen it so it can be pulled off with a string or your hands.
Be carefull not to scratch your guitar!
Good luck,
-mike
Posted on Mar 30, 2009
PolyrhythmFX
  • 109 Answers
SOURCE: Guitar knob wiring damaged need HELP
Take a look at this diagram. Even though your guitar may not have Seymour Duncan's, the wiring is all the same. Go to their website if you have a different pickup & control config.
http://www.seymourduncan.com/support/wiring-diagrams/schematics.php?schematic=2h_1v_1t_3w
Posted on Aug 26, 2009
  • 1138 Answers
SOURCE: i need to re wire in new pickups new pots and new
Try looking here:http://mediawebsource.com/guitar/pickup.htm .
Posted on Sep 28, 2009
SOURCE: How to lower the action on a b.c.rich warlock
To fix the action on your B.C.Rich Warlock, you need an Allen Wrench, or Hex key. There is a truss rod cover on your B.C.Rich's headstock. Just open it using a screwdriver and you will find the truss rod. Then adjust the action using the hex key.
check out more here -
http://www.squidoo.com/b-c-rich-warlock-set-up-and-fixing
Posted on Feb 07, 2011
criss_michae
  • 63 Answers
SOURCE: the part that holds the strings under the bridge
The tailpiece, as it's called, can be purchased from various parts shops, as well as online. Check AllParts as well as Warmoth. either one should have what you need. If you don't want to pay shipping, then you may be able to find it at Guitar Center, Sam Ash Music, or Musician's Friend.
If it's a string-thru-body design, then you'll have to take it to a luthier (guitar builder and technician) to have it fixed.
Hope that helps!
Posted on Mar 27, 2011
B.C. Rich Ironbird Pro guitar serial no G01111219. What year was it made and where?
Dating Your Rich Guitar Dolphin Music
The relevant part -
In November of 2000 B.C. Rich implemented a new date stamp format for serial number coding of it's imported models. . This started on the January 2001 models. All B.C. Rich models, both imported and usa handmades implement this same year time date stamp and guitar production number format:
121XXXXX first digit = year of manufacture
second digit = means nothing until double-digit years get here again
third digit = quarter of manufacture
digits 4 thru 8 = production number
Current US-made B.C. Rich serial numbers follow the same year and guitar production number format. (example - serial number #24123 was the 123rd guitar made in 2004)
Jun 10, 2016 | B.C. Rich Music
I have a BC Rich bronze series, beast head guitar. Would anyone know how to trace the serial Number and ownership details of this item?
Very hard to track serial numbers on these guitars
they made and sold millions since the 80's
they are worth $100-$300 and more depending on condition and exact model
there is very little info available online with the exception of eBay and other sites for price reference... Rich Warlock
Mar 25, 2015 | B.C. Rich Music
BC Rich Warlock Frets catch high E string
It sounds lie the frets aren't seated correctly. This will need to go to a professional repairman. It's too easy to mess your guitar up if it's done wrong.
Jan 23, 2014 | B.C. Rich Music
Need wiring schematic for it warlock
Maybe one of these is similar?
http://www.bcrich.com/learn_schematics.html
Apr 30, 2011 | B.C. Rich BC Rich Warlock Revenge Electric...
How to lower the action on a b.c.rich warlock bronze series
Nov 20, 2010 | B.C. Rich Dark Arts Warlock Electric...
The part that holds the strings under the bridge has broken on my B.C. Rich platinum warlock
Hope that helps!
Jul 20, 2010 | B.C. Rich Nt Warlock Electric Guitar
My warlock does not work no sound thru the amp. Is there a fuse somewhere on the guitar?
Try looking for a battery pack in case you have active pickups. Otherwise I'd check the output jack first if your cable is good.
Jun 17, 2010 | B.C. Rich Nt Warlock Electric Guitar
Good luck,
-mike
Mar 30, 2009 | B.C. Rich Nt Warlock Electric Guitar
Music Logo
Top Music Experts
Michial Gueffroy
Vito Vacirca Jr.
Are you a Music Expert? Answer questions, earn points and help others
