Question about Toro Garden
I need the size of the belt for my TORO 6.75 190cc walk behind. Can you HELP?
  • 433 Answers
Have you checked the toro web page
Posted on Dec 18, 2016
I need the size of the traction belt for my Toro 6.75 190cc walk behind? Can you HELP
you will need the model, code, serial numbers. get the from the engine and off the frame. take them to your local mower parts store and they can sell you the belt you need, if you have a manual for it that will help with part numbers.
Dec 18, 2016 | Toro Garden
I have a year 2000 toro dingo (walk behind). The I have a year 2000 toro dingo (walk behind). The motor runs great but stalls out immediately when I engage the track. To move forward or back. I checke
One of your hydro pumps are seized. this is causing the engine to stall when ever the torque is transferred to the pump. There are the small pumps (or final drives) under the engine. One or both need to be replaced
Mar 27, 2013 | Toro 2007 Dingo Tx420 Walk Behind Mini...
Toro 52 inch walk behind blades won't engage
if it has a electric clutch check for power to the clutch if no check the safety switches
Apr 10, 2012 | Toro 52" Cut Wide Area Walk Behind Lawn...
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
I have a Toro Proline walk behind . Problems with the self propel
I suspect the drive belt, not the Hydro. Especially if the drive belt was never replaced. The belts are known to stretch and wear out over time. It's a cheap part.
Jun 04, 2010 | Toro Lawn Mower With Toro Power Tools
I have an old Toro proline 52 inch commercial walk behind 18hp kohler and I don't know how to put the transmission belt on right.
Simple rule. V of the belt goes in V pulleys
The back of the belt goes on flat or idler pulleys .
It may take several tries but I am sure you can figure it out.
Sep 10, 2009 | Garden
Toro 20073 self propeled, walk behind mower-how to replace belt ?
Wait until the mower cools off
1. Remove the drive belt cover from the top of the mower
2. Tip the mower up, being careful to not go too far or the oil and fuels may spill out
3. Remove the mower blade - as I recall the bolt is 5/8" (could be 9/16") You will have to hold the blade from turning (if you have impact tools, this will be much easier)
4. Remove the blade
5. Pull the pulley out or off and remove the belt - be careful to not lose the crankshaft "woodruff" key - it's the little piece of half/moon shaped metal that keeps the pulley from spinning on the crankshaft.
6. Reverse the steps to reinstall
You MUST make sure the blade is tight when you reinstall it. Also, the blade usually fits over a couple of pins - make sure they are lined up properly and the blade is installed right-side up.
Mar 16, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
66 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
