Why dose recording in dvr goes on default date when light goes
When light goes & comes again recording gets start from default date(that is when DVR is made).Recording dosenot starts from on going date.
    Scholar:
    New Friend:
  • 73 Answers
Well, I'm trying to decipher this. Why does the recording in DVR revert to the default (date/time???) when the light goes off and comes back on.
I'm guessing you are trying to say time, not date, maybe day?
The DVR is trying to remember when a show comes on and record it, based on your settings. Usually shows come on at a specific time. DVRs usually update their scheduled recordings based on updated programming guide information. If you are constantly unplugging or causing your receiver to otherwise restart, most receivers will download an updated guide upon getting power back or restarting (DVRs themselves not having any idea how long they've been without power, download a new guide just in case after you unplugged them you moved to Arizona). During this time, the recording you set is showing the original time you set it up, because until the guide is downloaded, it has no idea that its wrong.
My best advice, even if I'm wrong about our language barrier here, stop unplugging your receiver. Leave it plugged in and powered at all times.
All times.
For ever.
Posted on Dec 22, 2016
Gamut cctv recorder admin password
To reset password of your CCTV DVR press and hold the ENTER button for 15 to 30 second until the DVR restart's. After the restart you DVR default wizard will come up the same way like if you are setting up the DVR for the first time.
Apr 04, 2017 | Computers & Internet
Bunker hill 67139 dvr hard drive wrong year 2058
The issue may be is that you have a DVD in your dvr , that still shoes that date and time. Just a possibility, not sure,. try to see if you can take DVD out of dvr, and use a new one. I happened to me but, the case was a vcr,and I had a recorded video tape which while playing , was showing a blue screen, with "no data received" which actually it was when no data vcr was receiving from cable at the time it was recording . If the problem still is not solved then there is issue with some circuits, and processors. Also you may want to check if Bunker Hill has any customer support, to check with them.
May 18, 2014 | Televison & Video
I have somehow changed the language into Japanese from English whilst trying to change the date. Please tell me how to change it back and also to put in the correct date.
On mine its ..
switch on .(make sure its not recording)
Record start/stop on mine is beside to on/off button
menu button twice (second menu)
on this option screen its the second option down - press record to select.
from there you can select your language.
One you've done that its the same input method for date , you just select the date and time options.
Jan 22, 2014 | HD DVR Hd Portable Dvr With 2.5 Tft Lcd...
L.S.My Pioneer DVR-550H does not record when programmed with the timer. After setting a timerprogram one can see the small red clock in the display but that disapears after some time and so the DVR does...
Make sure you have the right date and time set. You cannot set a timer program until you have the correct time and date set. Let me know if that helps.
Feb 20, 2011 | Pioneer DVR-550HS HDD Recorder
My pelco 16 cameras reset each one minutes
You need to do a INITIALIZATION/REINITIALIZATION PROCEDURE See below for details Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you are installing the DVR, follow the steps below to initialize
the unit as part of the installation instructions in the Installation/
Operation Manual. This procedure erases all data on the hard disk
drive and is necessary to ensure that there is no data that could cause
improper operation when you try to use it. With a clean hard drive, the
DVR can correctly index recorded video with the correct time and date.
Once the DVR is initialized, you should not reinitialize the DVR
again unless you are having trouble finding and playing back video,
and there is no other solution. If you have to reinitialize the DVR, make
sure the time and date are correct before beginning the procedure.
WARNING: When you initialize or reinitialize the DVR:
• The hard disk drive is erased.
• The password and all menu settings return to their default
conditions.
To initialize or reinitialize the DVR:
1. Press and hold the Function button. The Function Key List
appears. Keep holding the Function button.
2. Press and release the 0 button, and then release the Function
button. Enter the password if requested. The Setup Menu
appears.
3. Using the front panel buttons, enter 1220.
4. A screen appears and asks if you want to continue. Use the
Search (<</>>) buttons to highlight Yes or No to erase the
hard disk drive, and then press the Play/Pause button.
PASSWORD
The default password is 0000. If you change the password, and
then forget it, you can get into the system by using 2002.
Aug 25, 2009 | Pelco DX1000
Direct TV DVR record light on, but it won't do anything
contact directv 800-531-5000 if you have the protection plan a new receiver will be covered under most circumstances. sounds like a bad receiver. hope this helps
Mar 24, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Directv dvr will not power on. The record light
Unplug the DVR for about 20 minutes and then plug it back in. If that doesn't work its probably time to contact DTV for a replacement.
Mar 23, 2009 | Directv Plus DVR DTV Receiver / 100-Hours...
Problem with DISH DVR 625
You can accomplish this by either going to the specific TV and selecting the record option at the time the program is about to come on or you can press menu-8-5 and change the record preferences. You can either set the DVR to record programs to the TV2 location by default or TV1 by enabling the record plus feature. In dual mode without record plus enabled all programs you select to record default to the tuner you are viewing e,g, if watching tv1 and selecting to record a program in the future it will record to the tv1 location.In single mode all recordings default to tv2 so you can continue to watch live tv from tv1. I hope this answers your question and thanks for using Fix Ya. Let me know if I can further assist you.
Dec 14, 2008 | DISH Network DVR-625 DTV Receiver /...
Ellion DVR-950S
Ellion DVR 950S Festplattenrecorder.
Please help me.
I have a problem, that the Power on/off Display get never out - it is a loop - power on an than power off power on .....
I diconnect the line (power cable), but it is the sam again. There is no more - other funktion by the recorder.
Thank you for help
walter-august
Jan 02, 2008 | Ellion DVR-530S DVD Recorder
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
