Question about Miscellaneous
Top Tier gas stations near 19711 - Miscellaneous
Which brans of gasoline are top tier or tier 0ne stations in La Mesa, CA 91942
Fuel since the 80s is very regulated. As long is it is not contaminated with water there all equal.
Jul 27, 2017 | Cars & Trucks
I have misplaced the rules for playing the Tripoly game. My virus protection will not allow me to download them. Could you please E-mail them to me at the address below. Thank you very much. Grandma...
Game set up and ending
  • 1 Unfold the game boards and place the largest down first. Put the second-smallest board inside the largest board, matching the corners marked "elevator," and the smallest board inside the medium one.
  • 2 Give each player $3,500 in the form of two $1,000 bills, two $500 bills, three $100 bills, two $50 bills, three $20 bills, three $10 bills and two $5 bills.
  • 3 Separate out the deed cards. The first-tier property deeds have a marble textured back, the second-tier ones have a water design back and the top-tier deeds have a sky design back.
  • 4 Begin play by rolling two dice and moving your piece to the appropriate square.
  • 5 The game is over when all but one player have gone bankrupt. If playing with a time limit, the player with the most money when time expires wins.
Property, Stock Market and Travel squares
  • 1 Land on a property and buy it, if it's for sale, or pay a lease fee if it's owned. Distribute deed cards as properties are purchased.
  • 2 Improve lease values on purchased properties by adding facilities: gas stations, shopping malls and skyscrapers. The cost for each is on the deed card. Players build facilities before rolling the dice.
  • 3 Build gas stations on any property that has no other facilities. Add shopping malls and skyscrapers only if the player owns all the properties in a city. If a property has a gas station, it must be leveled before malls or skyscrapers can be built there.
  • 4 Draw a Stock Market card when you land on the Stock Market square. These cards specify gains or losses for players as well as additional moves and options. If the player must roll the dice to determine a gain or loss to his wealth, even-numbered rolls indicate gains and odd-numbered rolls indicate losses.
  • 5 Draw a Travel card when you land on the Travel square. These cards transport players to specific properties. Once there, the player can either buy the property or pay the lease fee if it's already owned.
Other Squares
  • 1 Request a salary when you land or pass by the Pay Day space. Players on the bottom tier receive a salary of $300, on the second tier a salary of $250 and on the top tier, $200.
  • 2 Use the elevator squares to move between levels. The only two ways to travel among the three tiers is via the elevator squares or Travel cards.
  • 3 Try to avoid the Rental Car corners on the middle or top tiers; if you land on them, you get sent to the Rental Car Line on the bottom tier. A player can get off this square by rolling doubles or passing the next two turns.
  • 4 Gamble money on the Las Vegas and Atlantic City squares. The player decides how much to bet and whether to wager 10 times the number on the dice or 100 times the number on the dice. An even roll means a gain and an odd roll means a loss. Each player must gamble at least once and no more than three times.
  • 5 Pay $100 to the lottery fund when you land on the Shopping Spree square. Collect the lottery funds if you land on the Lottery square on the lower level. The lottery fund also collects all losses from the Stock Market and the Shopping Spree spaces.
Read more: Triopoly Game Directions ' eHow.com http://www.ehow.com/how_8308744_triopoly-game-directions.html#ixzz1Lrych7PL
May 09, 2011 | Cadaco Toys
Does nissan sentra automatic 2004 needs a high octane or low octane gas? why?... what will happen if i change from XCS to gold?
Nothing will happen, your car will run fine. I do reccomend however, to use top tier fuel, NOT Arco, Thrifty, or cheaper stations. Cheaper stations do not clean their fuel.
Jan 20, 2011 | 2002 Nissan Sentra
New 2009 VW Jetta has occaisional starting problem-I turn key in the ignition and nothing happens- all the panel lights work but engine won't turn over-after second try the engine usually starts-what could...
Daisymoses... I am having the same issue with the same car and I have been fighting with VW about this problem and they admitted to the 2.5 engine having problems. Have you heard anything?
Sep 26, 2009 | 2008 Volkswagen Jetta
How do I put the jack back from where it came?
make sure you claps the jack all the way down center the tier place the jack on the the tier in the center of the tier you should have a wooden cover place that on top of thatyou shoud have a funny looking screw center that and tighten that down
May 15, 2009 | 1998 Ford Taurus
What gas should I use
but at least they don't have ethanol in it (yet). I think the octane is 87. Works great - no pinging good power easy starts and mileage seems right on. How about you other 200 Scarabeo owners? What gas are you using. ,Chevron plus - 89,,,
Nov 10, 2008 | 2005 Aprilia Atlantic 200
Check engine light on
I have the same problem, have swapped coils, injectors, plugs and replaced plugs w/ new ac delco iridium plugs. I have flushed out the fuel rail 3 times and tried adding seafoam, iso heet and berryman's B-12 chemtool to the tank over the last 15- 20 tanks of gas. I have also wasted money and cleaned the mass air flow sensor. NOW I FEAR THAT THE CATALYTIC CONVERTER IS GOING BAD DUE TO THE MISFIRES! (smells like sulfer/rotten eggs at times.)There is a service bulletin for contaminates and water in the fuel. It states that the fuel rail is a non-return type. This means that any water or contaminates in the fuel will enter the rail and stay there inturn clogging the injectors. The bulletin states that this causes the misfire on cylinders 1 and 4 during right and lefthand turns. So why is it only P0304 and never P0301? The dealer will charge you 300.00 to flush the injector rail. The problem is compounded by the fact that there is no fuel filter on the HHR except the one in the tank. Evidently that is not good enough to keep contaminates from reaching the fuel rail. I am going to drop my fuel tank and drain all the fuel from the system and refill w/ top tier fuel from a top tier station. Search for top tier fuel on the web. If it comes back again, I am going to get a ford focus. I can't keep worrying about this nonsense. Too bad too because I really like my HHR. Reliability is more important to me now, after all this time and money.
Oct 20, 2008 | 2006 Chevrolet HHR
Gas station gong thingy
Tap screen, Change Prefs, Right Arrow, Manage Pois, Warn when near POI.
Find the gas station warning, tap it, and confirm removal of warning.
Mar 07, 2008 | Tomtom GO 700 GPS Receiver
Miscellaneous Logo
14 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
