Question about Winter Sports
Loss of power when excellerating on 1993 indy 500 classic snowmobile
SOURCE: having difficulty getting my Indy Trail snowmobile started
pull it harder
Posted on Jan 28, 2009
SOURCE: 92 250 polaris indy lite snowmobile that back
I have the same problem.....I believe it is a result of low compression. I have also noticed the problem to be worse in warm climate. Check compresion on both cylinders would be a good place to start.
Posted on Jan 25, 2010
  • 105 Answers
SOURCE: Fixing a Polaris Indy 400 snowmobile pull cord
hello usually on any pull start, you have to wind the spring inside,the cover, on my atv i put the rope on the pulley burn the end of the rope and make a point on the end of the rope. put the pulley back in the case, turn the pulley backwards untill you get a lot of tension on pulley and turn the case up wright where you can see hole where rope comes out, turn pulley untill you see end of rope through hole. fish rope out with a pair of tweezers or a pair of themostats
Posted on Feb 06, 2010
  • 35 Answers
SOURCE: I have a 97 polaris indy 500 snowmobile. The spark
Wait, it just wont turn over, like the engine won't rotate?, that is either a broken crank, which not unusual for those 500's or you seized it, (welded the piston to the jugs). if this isn't what you mean, and it will turn over but not on its own power, then either your jets in the carbs are clogged, fuel may get to it, but not through it, or your rings are stuck closed and giving you low compression, check this by pulling it over slowly, you should feel each piston completing the revolution with a prominent glug glug. grab your primary clutch and rotate it back and forth, it should have a bit of play, but if it clanks and has alot of play, your crank is busted
Posted on Feb 17, 2010
  • 46 Answers
SOURCE: how to change sliders on a polaris indy xlt
REMOVE THE SCREW AT THE FRONT OF THE SLIDER (ON THE BOTTOM OF THE RAIL). SLIDE THE SLIDER OUT THROUGH ONE OF THE COG HOLES IN THE TRACH. THIS WILL TAKE ALOT OF EFFORT. MEASURE THE SLIDER TO THE NEW ONE AND CUT OFF. SLIDE THE NEW ONE IN AND REPEAT FOR THE OTHER SIDE
Posted on Jan 06, 2011
1995 Polaris 500 EFI. How do I replace the fuel lines?
Please Help : 96 Polaris Indy 500 EFI WONT START! No gas? - HCS ...
www.hardcoresledder.com > ... > Polaris General Discussion
Sep 2, 2008 - 10 posts - ‎3 authors
Please Help : 96 Polaris Indy 500 EFI WONT START! ... I pulled the gas line off that comes from the fuel pump to the fuel rail and when we start it it blows .... I'd changethem both and also check the pickup tube inside the tank. Polaris indy 500 issues... - Page 3 - HCS Snowmobile ...
Nov 14, 2013
650 RXL EFI won't start reliably - HCS Snowmobile ...
Dec 13, 2012
Frozen steering post - HCS Snowmobile Forums ...
Feb 11, 2009
More results from www.hardcoresledder.com
1995 Indy 500 EFI - won't start - Polaris Files
www.polarisfiles.com > ... > General Snowmobile Discussion
Oct 27, 2008 - 20 posts - ‎3 authors
I bought a (cheap) '95 Indy 500 EFI with a busted engine. ... I will be replacing the melted wires, but I'm not sure that's the issue. ... 500's have been knowwn to have fuel line /filter issues which will restrict the fuel supply to the
Oct 25, 2015 | Winter Sports
How to replace starter rope on 1993 polaris indy 500
Good luck! This model usually requires the muffler being removed,the right side of the engine disassembled.... A hint! do not remove the recoil spring unless it is broke. Turn the rope pulley clockwise about 6 times alaign the rope hole in the pulley and the starter housing , push the rope through, it helps to melt the rope ends.after the new knot is tied and pulled tight,gently release the pulley.
May 13, 2014 | Winter Sports
Polaris snowmobile troubleshooting
Well Cindy let me ask you was it doing it since you got it ? or it just start doing this ? just so you keep in mind that since you dont have battery in idle can be less power into the bulb filament now when accelerate creating more power meaning more light on bulb...
Jan 03, 2014 | ATVs
I have a 2000 polaris indy 500, seems to lack power and when you let off after giving it alot of gas and then give it gas again it backfires thru the carbs. it really lacks power...
I WOULD DO I COMPRESSION CHECK ON THE CYLINDERS, THEY SHOULD BE SOMEWHERE AROUND 100-130 PSI WITH A DIFFERENCE OF NO MORE THAN 15% BETWEEN CYLINDERS
Dec 12, 2010 | Polaris New Genuine Polaris Snowmobile...
Feb 16, 2010 | Polaris New Genuine Polaris Snowmobile...
I have a 1992 polaris indy 500 efi snowmobile and I just put a new piston cylinder head on it and got ot to run but however it will run and take off accept when the throttle is wide open it dies and I have...
hi ,i have a small and big project ,just busted a piston in my 500 piolaris indy snowmobile & to it apart & forgot about the presstone and it's all at the bottom of my engine ,where do i go from here &&&& another thing i had to drive awhile with the busted piston so what would be the damge ,what should i do with the whole thing
Jan 17, 2010 | Polaris New Genuine Polaris Snowmobile...
My indy 500 wont start i changed the fuel pump and it will turn over with stater fluied got compresion and spark
i have trouble starting a polaris indy 500 1990 new gasgets, pistons rings all i does is back fire through the two carbs
Dec 11, 2009 | Polaris New Genuine Polaris Snowmobile...
Winter Sports Logo
95 people viewed this question
Top Winter Sports Experts
Arnie Burke
Arnie Burke
Todd Arndt
Todd Arndt
Are you a Winter Sport Expert? Answer questions, earn points and help others
