Question about Altec Lansing Audio Players & Recorders
Altec Lansing life jacket 2 won't turn blue light on front blinks constant
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
SOURCE: Altec Lansing ada745 fuse
Yes, it's a 1A 250V glass fuse, 0.75" (1.9cm) long. The only other number on the fuse is "239", if that means anything. You take it out by putting a flat screwdriver in the slot on the fuse holder cap, turn counter-clockwise, and pull out once it releases.
Posted on Nov 20, 2008
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
I work for a charity that had one of these donated today and as I was looking for a new sub for my cinema system I purchased it. I have no other speakers with it and no way of switching or varying the volume. I opened up the back of the sub and slid the board partly out exposing the PCB.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3734.jpg[/IMG]
You'll see 3 solder connections behind the scre in an "L" configuration. One of them is common, one volume and one power on. As I don't need volume, I'm happy with it being on full as my cinema system will vary the input, I joined all 3 together giving power on and full volume. It is working great now.
[IMG]http://i134.photobucket.com/albums/q116/mm0dxc/PICT3737.jpg[/IMG]
For you guys with volume controls, I would suggest shorting out the two rightmost pins in the "L" and I recon this will power it up and try varying your volume control. I recon it'll work just great.
Good luck
Posted on Jan 22, 2009
  • 7 Answers
SOURCE: output board for Altec Lansing ADA995
I've managed to fix the amp in the ADA995 when I blew the rear channel amp. There is a design fault with the voltage regulator that causes it to run very hot, which frys the plastic housing glued near it, which corrodes the circuit board trace.
Getting the sub/amp apart is a *****. But doable. You need to not only remove the screws in the back under the flat grills, but ALSO 3 screws behind the top speaker that also hold the amp in place. And getting the power supply out is another rather difficult procedure, which is needed if you want to run the amp on the bench to troubleshoot.
The amp chips are available, though no NTE equivalent, and replaceable.
Posted on Apr 22, 2012
I have Altec Lansing ada 885 I only have sub woofer can anyone tell me how to power on with out other speakers . Because I have no switch to turn on with no other speakers and also the name of he plug on...
Throw it away, they are garbage speakers. I ordered one and ended up giving it away as it was so dire. It hissed when turned off, it drove me mad! The part you are missing is the amplifier which is in a small box unit in the right hand front speaker. Power goes into it and the input audio is amplified and goes to the Sub Woofer and the two satellite front speakers.
It will work on a stereo amplifier, but not as it is.
Manual
Using the Speaker System Altec Lansing ADA885 User Guide
Set up
Setup Altec Lansing ADA885 User Guide
Mar 10, 2018 | Altec Lansing Audio Players & Recorders
How to confirm if sensor is damage or remote not working
To check the remote.. turn on the camera on your mobile... and look the led on the front of the remote through the camera press any key in the remote... and if it is working you can see light blinking in your camera.... if not.. confirm that the remote is not workin
Dec 31, 2014 | Altec Lansing : 5.1 Amplified Speaker...
AC adapter not charging system
The low battery light may be indicating that the battery needs to be replaced.
Nov 28, 2013 | Altec Lansing Inmotion-IM600...
Hp altec Lansing laptop won't turn on
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jul 10, 2012 | Sony VAIO R505JL Notebook
Disassemble Altec Lansing T612
The front of the Alec Lansing t612 got smudged with glue. How doiremovetkhespeakercover so I can clean the cover
Dec 06, 2011 | Altec Lansing T612 Remote Control Speaker...
Speakers will not "turn on",
Hi. You might want to try a different set of speakers or try the Altec Lansing on a different computer to isolate the issue. This can tell you if the problem is with the computer's sound card or your speakers. If the speakers won't work with any PC, try checking if the wires are all good and/ or soldered properly. Be cautious while doing this. make sure the speakers are not plugged in to any power source. I hope this helps. :-)
Jun 04, 2011 | Altec Lansing ACS 251 Computer Speakers
Need advice on Altec Lansing x5021
Altec Lansing is the best company to buy speakers if you watch movies or listen to music. it hits both deep and a strong bass. These are the best speakers to buy.
Feb 25, 2010 | Altec Lansing MX5021 System
Altec Lansing PT7031 - ''Panel Key is Locked''
With the unit turned on...
Press the following front panel buttons in sequence within a 10 second span:
[Vol+] / [Vol-] / [Vol+] / [Vol-] / [Vol+] / [Vol-]
Successful unlock is indicated when the front panel led's flash.
Apr 04, 2009 | Altec Lansing PT7031 Computer Speakers
Cannot connect my surround sound altec lansing system to my compu
The first thing you can do is go to www.retrevo.com to download the manual. Secondly all you have to do is match the colors of the wires to the imports in the back. You have five speakers. Two have gray wires, two have red and one has blue. If you also notice each speaker has two wires. One a solid color, the other striped with black. For instance, put the solid red wire into the red import and the red wire with the black stripe into the black import. Repeat this with all the other wires. The easiest way to hook it up to your computer or laptop is to take one of the aux wires (the wires with the yellow/green/black tips). It doesn't matter which one. Put into you headphone import on your computer or laptop. Then put the other side into the Aux on the subwoofer. Located on the front. Turn on the power on the back. Then hit the aux button on the remote. That should work....
If you have any other questions or need any more help you can contact me brown.faith@rocketmail.com
Jan 22, 2009 | Altec Lansing VS3251 Speaker
547 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
