Question about JVC Televison & Video
My jvc DVD player has no audio outputs - JVC Televison & Video
  • Brett Duxbury
    Brett Duxbury Dec 18, 2016
    Hi Mike Hughes, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    hdmi output ?
    then use tv audio out
    does tv have audio out ?
2 Suggested Answers
  • 8 Answers
SOURCE: There is no video output from my Sony DVP NS51P
Im guessing your connecting via a scart lead..... Try swapping the cable ends round so that the DVD end goes into the TV and visa versa.
Posted on Mar 23, 2010
How do i hook up my jvc player that only has audio out hook ups
See if has an HDMI output - if so get adapter wire that plugs into your JVC HDMI and terminates with the necessary RCA plug outputs of video and two audio (L & R).
Sep 14, 2015 | JVC Televison & Video
No optical output except when using ipod dock on tv
Unfortunately, there is a limitation on the JVC LT47P789 digital optical audio out. This audio output does not get the signal from any HDMI source. This is described on page 49 of the user manual. The manual is available from JVC here: . There is a similar restriction for the analog audio output from the TV with the HDMI inputs.
If you use the component audio/video inputs on the TV from your set-top cable box and DVD player, then the optical audio output will work. Otherwise, you need to find a way to connect the audio directly to the receiver. Some receivers have multiple HDMI input ports. These then forward the video signal on their HDMI output to the TV. Another option is to connect the analog audio outputs from the cable box and DVD player to the receiver. This may require resetting the Audio output from these set-top boxes to keep from sending the audio over the HDMI cable. With the Cinemate, you might need some sort of audio input switch or an HDMI converter and switch that separates the audio from the video signal.
I hope this helps. Please add a comment with more information about your devices for ideas on how to work-around the problem with this JVC TV.
Nov 05, 2017 | JVC LT42P789 42 in. LCD TV
Connect jvc dvd to zenith tv
just hooked up with an rca cable from the output jack ( audio/video ) of your dvd recorder then the other end connect to the input jack of the tv. then set your tv at the same time the dvd player to record.
Aug 11, 2012 | JVC DR-MV150B DVD Recorder/VCR
I have a JVC surround system, I have power to both the DVD player and the Subwoofer but no sound. Wheni plug in earphones to the dvd player there is sound but nothing when unplugged. Could it be the S
You must have an external cable connection from the DVD audio output to the surround DVD input. As well there should be an output from the surround marked subwoofer. Connect them with the proper cable
Apr 04, 2012 | JVC TH-S8 System
I have a JVC DVD Player & VCR Model HR-XVC27U. It is hooked up to a Panasonic TV CT-32SL14J. I have Cable. With the JVC, I have lost any audio. If I record a VHS, I get picture, no audio. If I...
Shifting a heavy item, or anything really, can cause damage to either the cable or the port the cable is plugged into very easily.
I recommend replacing the audio cable, or trying an alternate audio output (you may be able to choose between RCA-style stereo audio output, digital PCM and digital optical.)
Similarly, the dvd player may be setup to output audio in a format that isn't matching what your AV receiver is expecting - again a variation of either stereo, digital rca or digital optical.
I hope that helps.
Jul 18, 2010 | JVC HR-XVC27U DVD Player/VCR
JVC NX PS1 - No sound output when connected to PC
use the aux in front and connect to headphone output on laptop or desktop
Jul 05, 2008 | JVC NX-PS1 Shelf System
JVC RX-702B only detects linear PCM, not multi-channel digital
Like most receivers it will probably have settings for the sound output. Once you find this it will be just a matter of switching the system over to Dolby signals. If you find that it already set like that, try switching the DVD or blue ray player you are using or whatever source, using their sound settings on them. So that both devices are sending and detecting Dolby signals.
If both devices are set correctly then there probably will be a fault in the decoder of the JVC.
Dec 07, 2017 | JVC Audio Players & Recorders
Jvc rx-5020v dolby digital problem
Also...If your BluRay player only has a optical output for audio you will need to swap the inputs on the JVC rx-5020v. Press the "settings" button repeatedly until "digital in" appears on the display. Now use the "adjust" up and down buttons until DVD is selected as option 2. It will look like something like: 1CD2DVD Note: this may bugger any other previous setup you have.
Feb 02, 2008 | JVC RX-5020VBK Receiver
Jvc hdmi????
Do an EEPROM reset and will be ok.
Dec 11, 2007 | JVC HD-61Z886 61" Rear Projection HDTV
Televison & Video Logo
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
