I pressed the wrong language I tried to change it but cant
  • kakima Dec 18, 2016
    Hi Rose kydd, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
How do you change the language to english on the Lexmark X5250?..Its in another language so I cant change it because I dont know what im pressing.
1 Press the POWER button to turn on the All-In-One
2 Press and hold both the POWER and CANCEL buttons for 10 seconds.
Language text then appears on the display.
3 Press the BLACK COPY button repeatedly until the language you want appears on the display.
4 Press the ARROW button to select that language.
Thats it!
Mar 08, 2011 | Lexmark X5250 All-In-One InkJet Printer
Its in wrong language
Press the Menu button. Select Setup (the wrench icon, or else the last item). Select Language (either the waving flag icon, or else "xxx/Language" where xxx is Language in whatever language is currently selected. No matter the language, it should still say "Language" in English after the slash. In that menu, each language is labeled in that language, so you should see "English" as one of the options. Select that, and everything should be back in English.
Dec 29, 2009 | Nikon COOLPIX S200 Digital Camera
I accidently selected the wrong language of my
1.Touch the screen for the menu
2.on page 1 of 3 on the menu, touch the blue wrench (change prefs) the black right arrow key to page 4 of 7 in preferences and touch the flags icon your desired language
Dec 26, 2009 | Tomtom ONE 3rd Edition GPS
All in the wrong language cant change it back to english
In standby mode, Press left arrow or left joystick followed by 0000 and right arrow or right joystick. this sets the language to english. All the best. :-)
Sep 10, 2009 | Sony Ericsson K800i Cellular Phone
Setting the language on a canon iR1530 photocopier
Press the usermode star(menu button)ones,press ok one time,press the arrow untill no 8 is display,press ok the arrows untill you get english press ok.
Mar 20, 2009 | Canon Office Equipment & Supplies
Garmin 350 sat nav stuck on wrong language can it be changed back to english
What have you tried to do to change it back? Have you tried changing the setting in the menu?
Press the wrench symbol and then the symbol with the lips.
There are 2 settings that need to be changed.
1. Text language (displays the text using characters of the chosen language)
2. TTS (text to speech - the actual speaking voices)
- Jim
Oct 21, 2008 | Garmin GPS
Change Language on Brother MFC-215C
So here you go:
1# Call brother hotline for info what is the 4 Digit eeprom code for England.
2# If you have the info (e.g. 0004 -> Check by help of brother hotline because I am not sure what code you need for GB!!!)
press menu then start bk copy then fourtimes arrow-up (tel.index). machine will be in maintenance mode. press 7 then 4. You will see the dutch eeprom language code. Press the 4 numbers given to you by brother hotline. You should see the 4 digits. Press start bk copy to confirm. machine will return to maintenance.
press 9 then 9 to leave the mode. machine will come up again with english language ;-)
Dec 30, 2007 | Brother Multi-Function CenterĀ® MFC-215C...
Compaq keyboard
Try pressing the ALT GR-key instead of the up (shift-key).
Sep 04, 2007 | Compaq 118003-008 Keyboard
Setting language and date
Try the following: 1 In any mode, press the Menu button. 2 Press up & down arrow keys to highlight Setup (the spanner sign), then press the OK button. 3 Press up & down arrow keys to highlight the setting you wish to change, then press the OK button. 4 Choose an option, then press the OK button. 5 Press the Menu button to exit. Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 12, 2007 | Kodak EasyShare Z650 Digital Camera
22 people viewed this question
