Question about Food Mixers
The knwood prospero attachments will not slot in , worked well until recently,
Kenwood prospero wont start
There are interlock switches on that unit so that it wont come on with out the attachments. One of them is bad or loose
Dec 02, 2013 | Kenwood Prospero Compact Km265 4.3 Litre...
Kenwood prospero km262 stopped working
In my case, capacitor C1: 470nF (on the circuit board) proved to be the cause. It measured only half its normal value. It's part of a voltage divider used in place of a transformer. Replacing it solved the problem.
Came already across the same problem in another circuit.
Dec 02, 2012 | Kenwood KM800 Major Classic Stand Mixer
The machine only works intermittently
had the same problem with Kenwood Prospero.
look for 2 pairs of watty (1.1 kohm 2W?)series resistors. At junction of the
2 pairs there is glue which degrades with heat and becomes conductive. CAREFULLY scrape away the old glue after removing the resistors. Check for shorts and resolder the resistors. You may be lucky. I was
Sep 18, 2012 | Kenwood Prospero Compact Km265 4.3 Litre...
The machine keeps cutting out during blending and mixing
need clarification. what does cut out mean? The motor stops altogether? The beaters stop spinning but you still get motor sounds? It comes on and goes completely off while in use and then comes back on. is there ever a bad smell or smoke? Are there any unusual sounds that you hear before it does a cut out or after it comes back on? Does it ever go up or down in speed on it's own. do the attachment gears on top spin while you are mixing in the bowl? we need to narrow the field of questions down to get to the right repair path. Please let us know.
I recently bought a used 901 Kenwood mixer from a second-hand dealer. The attachments seem to have a coating which may be deteriorating, as a black, greasy smear appears when I wash them. Any ideas ??
Yes its when the attachments have been through a dishwasher it damages the surface. you can still buy new attachments you have to change the shaft from the old attachment to the new one
Nov 28, 2009 | Kenwood KM800 Major Classic Stand Mixer
KitchenAid KSM5PSGR Stand Mixer - attachments not turning
Hi Gail. Kitchenaid no longer has a Parts List for your model. This means that they consider it obsolete. Do an Internet search for parts. You may get lucky. Good luck!
If this solution has assisted you, please rate it. ricardok45
Apr 02, 2009 | KitchenAid KSM5PS Heavy Duty Stand Mixer
Food Mixers Logo
48 people viewed this question
Top Food Mixers Experts
Oscar Netto
Oscar Netto
Are you a Food Mixer Expert? Answer questions, earn points and help others
