After turning on TV a loud noise sound is coming from it. After a very short time it turns off and back on and goes though the cycle again.
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Posted on May 28, 2008
  • 136 Answers
SOURCE: LG 47LC7DF LCD TV turns off with a pop then turns back on.
Sounds like a overheating issue. Try facing a large fan blowing across the back of the unit and see if this changes anything. If it does, it might help to blow the back out with compressed air as dust might be helping it overheat.
Posted on Aug 08, 2009
  • 458 Answers
SOURCE: Sound problems
Contact your LG dealer to request a service call out, it is very possible the operating software requires to be updated to the latest version especially if you have had the TV for quite a while. Once this is done if the problem still persists then there will be a problem with the audio processor & this will need replacing.
Posted on Oct 19, 2009
Testimonial: "Thank you very much for your help, I am very grateful to you. Kind regards Mark."
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Posted on Oct 20, 2009
  • 115 Answers
SOURCE: model hln617w. the picture on the screen freezes
Most likely your problem is on the DMD Assy Board P/N BP96-00249A . More presicely there is a few bad electronic components on that board that are bad. That board can be repaired by replacing the bad components (and the other few compoonents that are probly going bad and will soon cause your tv to lockup and lose remote and button functions when it fails so you will need to unplug it to get it on again).
Or the DMD board can be replaced .But it is not a cheap board.
For removal and Installation of the DMD board I would reccomend a tv service person because it is in the heart of the television and there are some adjustements to be made when the new board is installed.
To get the new board you could probably find it by just gooogling the part number.
Component level repair would require some experience in desoldering and soldering SMT,SMD , and or surface mount components.The actual components are about $15.00 total so just repairing your board should cost about $125.00 by a qualified servicer (if you were to remove and install it yourself). This DMD board is used in many models and can a few common problems.
HLM437W HLM4365W HLM5065W HLM507W HLM617W HLN437W HLN4365W HLN467W HLN507W HLN50665W HLN567W HLN617W ( L2 and L5 chassis )
-Intermittant picture freezing with a negative looking B/W frozen picture.
-Intermittant loss of pic with/without shutdown,abnormal color wheel noise if attempted to start after shutdown.
-lockup of tv control functions . Remote and front keypad do nothing , TV must be unplugged to reset .
-horizantal tearing, distortion , flippnig , solarization , red picture, leading to blank screen and lockup.(tv menu would be affected by all picture defects).
Hope this helps someone..
Posted on Jul 21, 2010
My 55ld520 screen goes black, turn off for short time comes back on but then goes black again.
Start simple by using different cables, whether they be HDMI, VGA or standard COAX cables. They could be losing the connection. Also, it's possible the power supply is wearing out and it gets too hot. You might want to simply try some spray air duster type thing to clear out any dust that can make it hot.
Sep 20, 2014 | LG 55LH40 55 in. LCD HDTV
Loud schreikin noise and cuts off.
it sounds as thought the main-board of the TV is arching or shorting out. This is due to a faulty component in the power section of the TV . It is about to completely go out.
The main board need to be checked for bad components.
Apr 23, 2010 | Philips 20PF5120/01 20 in. EDTV-Ready LCD...
Tv turns on w/pic then pic dissapears light blinks 4 times
I have the same issue, we've had to change our bulb three times in less than two years. now we have 61" expensive paper weight. Our current bulb is less than 6 months old. The TV is only 2 years old and like i said this is our third bulb.
the blue light blinks 4 times. you get sound. then a few minutes the the picture returns... then it goes out, and the cycle goes on.
A solution to this would be greatly appreciated.
Oct 08, 2009 | RCA HD61LPW165 61" Projection HDTV
Loud white noise sound when i switch my LCD tv on.
the main total assy is failing. it has the tuner ,sound, and a lot of the processing for the set check there first
Jul 09, 2009 | Televison & Video
No picture
Seems like the bulb needs replacing.....
May 28, 2009 | InFocus ScreenPlay 61" Rear Projection...
Try unplugging for 36 hours. I had the same problem but with no sound and picture
Mar 03, 2009 | Sony KP-53HS10 TV
Funny noise and electrical smell
Sounds like a product defect to me, I would be on the phone with LG to get a certified tech out to the house ASAP!
Mar 03, 2009 | LG RU-52SZ51D 52" Rear Projection...
TV turned off and wont come back
looks like the color wheel its bad in the set,color wheel its not spining at its proper speed( one of the segments may be broken)
thats the vibration you are hearing.. and the set its trying to turn on..until you replace the wheel you will be able to watch tv again.
Jul 03, 2008 | Samsung HL-R4266W 42" HDTV-Ready...
Toshiba 46HM95 Buzzing
I have the same thing, mine is the cooling fan for the lamp. If the sound continues for a short time after you turn off the TV then this is the most likely cause as the cooling fan will continue to run for a short time to cool off the bulb. I have looked into replacing mine, the part runs around $50 but I can't say yet how easy it is to replace yet.
Apr 02, 2008 | Toshiba 46HM95 46" HDTV
Televison & Video Logo
Top Televison & Video Experts
