Question about Garden
I just got a new snow thrower and used it 1 time and notice blue drips on my driveway any idea what that might be
  • 10865 Answers
SOURCE: snow thrower won't stay running
Replace the spark plug being sure to use the plug recommended in your owner manual, and the gap recommended. Then clean or replace the air filter. Finally use high test, new gasoline. Not gas that has been sitting around for months. good luck
Posted on Jan 23, 2009
  • 430 Answers
SOURCE: CRAFTSMAN 5 hp 24 SNOW THROWER, WONT STAY RUNNING
rebuild the carb.
Posted on Nov 30, 2009
  • 506 Answers
SOURCE: Craftsman single-stage snow thrower hard to push
You can adjust the guides on the side of the blower so that it rides on those. If they are set to low you will see the problem you have now. If they sit to low for a long period of time you can wear out the blade on the bottom.
Posted on Dec 23, 2009
cmcduncand
  • 714 Answers
SOURCE: Simplicity Sno Away Snow Thrower Briggs 6hp engine No Spark
Check engine oil.
Remove wire from low oil sensor and the start.
Replace low oil sensor.
Hope this tip help solve your problem.
r/David
Posted on Jan 23, 2010
SOURCE: Just purchased a Poulan Pro Snow Thrower and on
i just purchased the poulan pro PR1030ES snow thrower, and the recoil spring is broken, anyone know of a place to buy a new one...can't even get an answer from poulan...did you ever get yours fixed
Posted on Nov 30, 2010
Can I use 0w 20 Mobil 1 oil in my snow blower
It can be used, although the manufacturer recommends;
Super S 5W-30 Snow Thrower Engine Oil - Sears
www.sears.com/explorer-5w...snow-thrower...oil/p-07188298000P
Sears Rating: 4.5 - ‎5 votes
Oct 21, 2010 - Explorer 5W-30 snow thrower engine oil is a premium formulation for use in all four cycle engines when temperatures are below 32 deg. F. Explorer 5W-30 snow thrower engine oil protects the engine by lubrication, cooling, cleaning and sealing internal moving parts.
Aug 23, 2015 | Craftsman Snow Blower / Snowblower Bottom...
Snow thrower not starting
Two ways to find out:
1.
2.elctric
start with elctric, take the plug cable out and see if have
https://www.youtube.com/watch?v=mUOmsGiirTU
if you have spark go to fuel :
change the old fuel to a fresh one.
https://www.youtube.com/watch?v=RfzzTilqwo0
Dec 13, 2013 | Craftsman Arnold Mtd Snow Thrower Blower...
Need manual for Noma snow thrower D2045010
I would suggest taking a look at this Noma Snow Thrower Manual. Well I just noticed it isn't quite the right one, but maybe it will work?
Feb 03, 2013 | Garden
I have a toro snow thrower 622 that is leaking fuel. its coming from under the unit fast. any ideas to why and how to repair?
a rapid volume leak could indicate a cracked/rotted fuel hose. Not uncommon for a gasoline engine that sits for long periods of time between use. If all hoses seem in order a stuck float valve(needle & seat) in the carburator would also cause rapid overflow of fuel. This willm require a carb overhaul to repair
Jan 07, 2013 | Toro Garden
I am looking for belt size for HABAN 24577 snowthrower to Murray 18hp lawn tractor. Book doesn't provide size info.
I have a Haban Model No. 24577A 42" front mounted snow thrower attachment, which I have mounted to a Murray lawn tractor. I needed to replace the lower drive belt, labeled: V-Belt-Long Part No. 23948 in my Haban manual. I had found it next to impossible to find a replacement belt part number or cross-reference to other brands. I tried many belt sizes and lengths to no avail - belts broke quickly and suddenly after 1 or two uses.
While researching Haban on the internet, I realized that they also supplied snow thrower attachments for Sears Craftsman lawn tractors. A thought hit me at one point in my research... that Haban probably sold the same snow thrower chassis to all manufacturers, but only with different interfaces to the tractors. So I ordered up a belt for a different Haban model that was supplied to Sears, and I think that my intuition was correct!! I have found a belt that works with my Haban Model No. 24577A snow thrower.
The belt that appears to be a direct replacement for the Haban belt part number 23948 (long) is as follows: Kevlar Blue V-Belt 5/8" x 87". It is sold by several suppliers under various part numbers, priced at $20 to $30.
I hope this helps you.
Jan 19, 2011 | Garden
Dec 22, 2009 | Toro Blowers Rake and Vac - Electric...
Is there a GENERIC Snow thrower for John Deere 110?
Two Stage - Snowblower - Snow thrower - Bercomac All of the Bercomac attachments are interchangeable on the same quick hitch mounting. Bolts on in minutes. What a great idea for people who have more than one tractor or buy a new one. No more having to go and buy all new attachments for the new small tractor, just buy a different model hitch kit if it doesn't use the same one. The resale value is preserved when you can sell your attachments to be used on another size or model lawn and garden tractor.
camcorder-pic.jpg Snowblower video clip
Snowblower-Snowthower Q&A's
If you are ready to buy or want more details give us a call: 1-800-618-8738 or e-mail jim@jimsrepairjimstractors.com
Sep 10, 2009 | Garden
Snow thrower won't stay running
Jan 11, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
