Question about Tablets & eReaders
How to fix my Zeki Tablet when I have forgotten the password. I have tried many things and none of them worked. Can anybody help me at all????
I have a TBDG874B Zeki tablet and I haven't had it in months so I forgot the password. HELP!!!!!!
  • Tablets & eR... Master
  • 5,621 Answers
Factory reset!!!!!!
Posted on Dec 18, 2016
Testimonial: "Well how do you do that???"
  • 4 more comments
  •  Mikey
    Mikey Dec 18, 2016
    This is how to do that:
    Make sure your tablet has sufficient battery charge, power off and boot into recovery by holding Volume - button and tapping the reset button (located between hdmi and usb ports). continue holding volume - button until you see the boot screen starting then release. at the menu, use the volume up and down to navigate to Wipe Data/Factory Reset and use power button to enter. Confirm with Delete all user data, and wait for reboot!!!!!!!
    I would suggest making a note of your password this time to avoid going through this again!!!!!!
  • Anonymous Dec 18, 2016
    I am sorry but I already tried that and it didn't work. Thanks for your help, though!
  •  Mikey
    Mikey Dec 18, 2016
    The process is precise and might take a few attempts before successful......just keep repeating the procedure until you see the boot screen.
  • Anonymous Dec 20, 2016
    Thanks! I'll keep on trying until it works! :)
  •  Mikey
    Mikey Dec 20, 2016
    Ok, just to clarify in the procedure the "volume -" is volume down button.
    I know that. Thank you!
How to reset a zeki tablet password
Hello there,
From the Zeki website it says do this.
If you have set the screen lock to a password or pin code, and have forgotten the code; you will need to reset you tablet to factory default setting.
  1. Make sure your tablet has a full charge
  2. Press and hold the Volume - button and tap the Reset button
    (The reset button is located between the HDMI and USB ports)
  3. Continue holding the Volume - button until the boot screen appears
  4. Release the Volume - button
  5. Use the volume controls to navigate to "Wipe data/Factory reset"
  6. Press the power button to select
  7. Navigate to "Delete all user date"
  8. Press the power button to select
Your table will take several minutes to reboot to a factory default setting.
Hop this helps you friend. :)
Sep 25, 2014 | Digital Products International Zeki 7
How to unlock your zeki if you forgot the pass word
good then just reset it an start over kinda, remove memory sd card ,
press reset with toothpick , might have to do it with it off or on .
Jul 25, 2014 | Digital Products International Zeki 7
How do i get it off the android screen so it will show the lock screen?
Sounds like its borked.
Have you pressed the reset button on the back - pinhole - press it with a pin its a long shot.
The real fix is to go into recovery mode using the power button volume up combo. Then select the restore tablet option.
If none of that works you will have to sideload or reinstall using an sdcard a replacement OS - Try cyanogenmod - your tablet will have to be rooted and have the cm bootloader installed however - tablets are not easy things to repair when the software goes belly up.
May 12, 2014 | Shopnbc Zeki 10.1" LCD Android 4.1 8GB...
I forgot password to my zeki 7 inch tablet model tbdg7738
You will need to reset your tablet Zeki Tablet. To do it, make sure your tablet is fully charged then press and hold the volume button. Tap reset and continue holding the volume. Go to for details.
Gopakumar Gopalan Google
Apr 16, 2014 | Tablets & eReaders
I have a zeki tablet that won't load, wondering if anybody here can help me?
I'm assuming it is the Zeki 8" TBDG874B. What I would do to get it of the flashy Android logo is hold down the volume button on the minus (-) side and get a small pin or needle to tap the reset. While holding the volume it will reset, then tap the power button still holding volume it will bring up a list. Do a factory reset (you lose all data but that's what I would to do to be on the safe side).
Apr 09, 2014 | Tablets & eReaders
None of my apps will turn on and it keeps saying all apps are closed
you might have transfered it to lacal sd card which are transfered to some other location
from file manager look wether all files are there only where it was prior(since app follow the same pathway to load app)
try to relocate it on prior position
or else you have to reinstall them
remember alway keep your backups
Feb 01, 2014 | Zeki Berk Ulu 8GB 7in WiFi Android Tablet...
I have a zeki tablet that has no sound. what can i do?
Have you solved your problem yet? I have the same problem too.
If you got it fixed, how did you do it?
Nov 11, 2012 | Shopnbc Zeki 7" Multi-TouchTablet
Tablets & eReaders Logo
181 people viewed this question
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
