Question about Keurig Coffee Makers & Espresso Machines
My Keurig not pumping keeps turning off - Keurig Coffee Makers & Espresso Machines
  • 9,870 Answers
Keurig will give you a 20 dollar credit on a new purchase. The machine cannot be disassembled for repair without destroying the plastic case.
Posted on Dec 18, 2016
How can I fix my Keurig Coffee maker? It pumps water from the time it is turned on 'till it indicates add water. Any suggestions?
either the heating element has failed or a thermal overheat trip device or thermal fuse has failed
you need to use a meter and see if the heating element is getting AC power
perhaps the pump actuator usualy a relay or a triac device has failed and gone short or fused contacts ....
hard one to diag from words only
Dec 04, 2014 | Keurig Coffee Makers & Espresso Machines
Cannot prime
I have the same unit. You need to descale it. Get a bottle of white vinegar (not the small bottle, the next size up). Unplug your Keurig. Empty out the water receptacle and flip your unit over in the sink to remove any residual water in your unit (I even shake mine a little to loosen up whatever is stopping it from priming. Fill the water receptacle to the top with white vinegar. Plug in the Keurig and turn it on. Cycle the unit (lift the lever, close it, push the button) and fill a cup with heated vinegar. Pour the cup out and continue until all the vinegar is gone, then fill the receptacle and keep doing this (I do it until the receptacle has emptied itself at least 3 times). If your Keurig will not allow you to cycle through this then the problem is internal with the pump. Call Keurig. If you are in your warranty period they will replace.
Dec 10, 2013 | Keurig B60 Coffee Maker
Won't prime
The water pump system is not primed properly. Remove the water tank while the pump is running and put back a couple of times. If not working, when the power is off, using a straw, blow air through and try to **** through the water port at the bottom of Keurig. Plug the water tank again in and start the system. It will take some time to prime, keep trying. There is nothing wrong with the machine, but the water pump circuit.
Oct 18, 2012 | Keurig Elite B40 Coffee Maker
My keurig b50 when turned on wont start or pump water to start
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
Feb 20, 2011 | Keurig B50 Coffee Maker
My 4 year old Keurig B60 just keeps saying "not
heatman101
Feb 19, 2011 | Keurig B60 Coffee Maker
My Keurig B60 stopped pumping water, the pump runs for 45 seconds and the pot then turns off. Any idea's on how to fix this would be greatly appreciated.
you can try contacting Keurig directly and see if they will honor the warranty, if that doesnt work i know of this great website that sells all kinds of keurig products for very cheap.http://stores.ilikenew.com
Jan 30, 2011 | Keurig B60 Coffee Maker
The Keurig is not dispensing any water when I hit the brew button. We have always been descaling the unit since we received this second keurig machine. Please help in solving the Keurig problems with...
the air pump in the machine might be locked up. if it is you will have to take the machine apart, not fun, and locate the air pump behind the water tank. take the pump apart and try to turn the pump manually until it moves freely. good luck
Dec 30, 2010 | Keurig B70 Coffee Maker
My B100 Keurig stopped pumping water
This is a very common problem, just call Keurig tech support. Explain the problem and they will send you a replacement unit and you get to keep you old partially functional unit. I bought mine in December 2009 and I'm on my 3rd unit already. They keep having the same pump issue and Keurig just keeps sending me replacement units. Their customer service is great, but I'm beginning to question their quality control.
Aug 24, 2008 | Keurig B100 Coffee Maker
Coffee Makers & Espresso Machines Logo
26 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
