Question about Candy Washing Machines
Hi, I have a Candy Grand comfort which has just stopped working. the power is there lights on but when I turn the dial it clicks as if to start but nothing happens. Thanks in advance.
Candy Grand comfort Model GCC 580NC - 80 2 years old when it is on it makes a little buzzing noise but as I say nothing happens. Turned it off at the mains, lint cleaned and water tank empty.
    Problem Solver:
  • 16 Answers
Could be the door interlock or simply there is no water entering the machine. Check water supply and also the vales inside the machine . the solenoids should buzz nd hum a little if they are energised but could still be blocked ???
Posted on Dec 03, 2017
SOURCE: Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Posted on Apr 19, 2007
  • 248 Answers
SOURCE: hotpoint washer
  These older units had an insert in the agitator that would strip out.  Remove your agitator and take to a parts store. They should be able to help you out.
Posted on Oct 13, 2007
SOURCE: Frigidaire affinity not draining
The problem is that on the infeed side of the pump there is a catch/filter in the Hose/boot that will catch lint and coins (LOTS OF COINS) and will not allow the water to flow through to the pump. This will stop the cycle and prevent the tub from spinning and the basin will not drain.
to fix this turn your washer over and access the pump from the bottom. the boot can be disconnected from the wash basin with a phillips screwdriver, reach in the boot and pull out the plastic catch and empty the debri, reinstall the the catch after cleaning it and put the boot back on. Set your machine back upright and conncet all the hoses and plug it in. It should work. This is a easy job but it will take an hour or so.
Posted on Sep 26, 2008
  • 5911 Answers
SOURCE: Kenmore Washing Machine fills with water then just stops
The symptoms you describe are typical of a lid switch malfunction. The lid switch is usually located on the right hand side under the cabinet. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the right side of the wash tub opening. Make sure the lid strike is still on the lid and intact, first. Then, check the mounting screws that hold the lid switch in place (two screws along the tub rim on the right hand side). Often all that is required is to tighten up the mounting screws and this will realign the lid switch where it can be properly activated by the lid strike. If the lid switch is broken, you can find a replacement at Just type in your model number and look under the "Top and Cabinet" heading for item number 11 for the lid switch and item number 20 for the lid strike (if needed). If you do not wish to order online, take the part numbers provided by Sears and go to your nearest appliance parts retailer. These are common parts that most will carry in their store inventory. The following link explains how to replace the switch:
This is a very inexpensive repair that you can easily accomplish on your own. I hope you find this information helpful. If you require additional assistance, please let me know.
PS This is a common problem experienced by this line of washing machines. To prevent future failures, do not slam the washer lid or place anything heavy on the lid. Repeatedly slamming the lid to get it to work, or manipulating the timer can also cause more potential problems.
Posted on Oct 21, 2008
SOURCE: stop light flashing
i have a candy activa cm1 146. no matter what i do the stop light is always flashing. Ive emptied the machine, turned it off at the mains, checked the waste pipe and currently trying to empty the filter, whilst the light is flashing it will not work on any programs???
Posted on Jul 28, 2009
Why does my top load whirpool washer restart on its own after it finishes the last rinse and spin cycle. It does this on all settings, delicate, normal or heavy.
  1. Turn the washer off.
  2. Set the mode selector dial to NORMAL.
  3. Turn the dial counter clockwise ONE click (LEFT), clockwise THREE clicks (RIGHT), counter clockwise ONE click (LEFT) then clockwise ONE click (RIGHT).
  4. Now press the start button.
  5. All the cycle indicating lights should be illuminated.
  6. Press the Start Stop button once.
  7. Rotate the dial until Rinse, Wash, and Stop light illuminate.
  8. Turn the washer off and unplug it for 10 seconds.
  9. Finally, turn on the washer and it should now be reset.
  10. Run a test load empty to be sure the reset worked. If not perform the reset procedure one more time.
Oct 07, 2016 | Whirlpool Whirpool 3.5cu ft Top Load...
How do in remove the control panel on my candy washing machine to fix buttons that have been pushed in too far?
Remove the top cover of the washer. look in there, remove the screw of each end of the panel.look into the back of it u see a plastic stopper at each side left and right,push it by finger.pull the panel backward .
Sep 08, 2015 | Candy Washing Machines
Candy grand o go1682
you should clean the knob with alcohol careful there is spring and a small ball in it
Feb 09, 2014 | Washing Machines
Washing machine does not work on any program though stop light and spin speed light are flashing t
The stop light and the spin light flashing are acting as an error code. Have you tried to google what this means? here is a link to candy error codes for that machine...
hope that helps
Jan 15, 2014 | Candy Washing Machines
Candy CDB 854: Just installed, spin tested briefly. Now just lights and no function.
Turn the power back on, go through the instruction book to start the machine up. If its still not right, call the Service Agent. Its brand new and will be covered by warranty.
Apr 26, 2017 | Computers & Internet
I have a candy go c58f and it is stopping after approx 10 secs of starting it's cycle and all the lights are flashing - I have checked the filters and emptied the water
This is a problem of the dryer being too cold. What you need to do is turn it off when all the lights flash (using the dial) then turn it back on again and start the cycle again. Repeat until it keeps going.
This is a real PITA. I spoke to their customer services about it and told me what to do. It seems the sensors in it are not happy in cold weather!
Mine takes 6 to 10 go's in very cold weather. I find it's best to get it warmed up when empty as the hot air gets to the sensors more quickly.
Dec 19, 2010 | Candy Dryers
Problem with candy dishwasher model CSF 456M.
hi it may need a new inlet valve,can you hear a humming sound when its due to fill.or is it doing nothing.if its not humming change the valve,also these dishwashers are well known for overheating and sticking on cycle.
Jun 01, 2010 | Dishwashers
Door lock , wont light up , therefor wont start washing.
Click on "Candy" (below FIXYA) on this website, type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you have your manual on line.
You can also go to "troubleshooting" above, you are sure to find some solutions. And dont forget to rate me on this great site.
Jan 07, 2008 | Candy CNW136 Front Load Washer/Dryer
Programme dial
that is your only solution but u might find u can buy a second hand machine that works for u to get parts off this will proberly be cheaper than buying a timer thats what id do u get more for your money m8
Aug 14, 2007 | Candy AQ130 Front Load Washer
Washing Machines Logo
75 people viewed this question
Top Candy Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Candy Washing Machine Expert? Answer questions, earn points and help others
