I have a logic 6k front loader with E60 what does this mean?
2 Suggested Answers
richroth
  • 9472 Answers
SOURCE: Hi I have an
The E60 is a common problem with this washing machine and it refers to a blocked inlet valve not filling in within correct time, pump blocked, or not draining in correct time.
Posted on Aug 27, 2011
My electrolux front load washer had a bang and a spark on electrical display now showing E60 EWF 1087
Family error code E60 is visible to customers and (could be E61,E62,E66,E68 and E69 only visible in service mode) means problem with heating phase.
Possible failures : heating element faulty, NTC sensor faulty, PCB faulty, wiring.
Dado
Feb 21, 2015 | Electrolux Washing Machines
Lg fuzzy logic wf t652
Front loader? Coins do get into the baffles. They may be riveted on. I would leave it alone, personally.
Dec 01, 2013 | Washing Machines
What does e60 mean on a zanussi
E60 - Fault in washing NTC sensor
-Washing NTC sensor, wiring, main PCB
Pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Checked the electrical installation already twice to ensure adequate voltage and grounding.
Hope helps (remember to rate and comment this answer).
May 31, 2011 | Zanussi ZWF1440 Front Load Washer
What is the meaning and fix for error code E60 on a John Lewis JLDV08 tumble dryer. The dryer stops mid-cycle, the door pops open, and code E60 appears on the display.
When there is an error with the door switch and sensor, the "E60" error code will appear. An unbalanced door will produce the E60 code. Try to close the door gently and listen for the click. If the error remains, the door switch may need to be replaced.
May 08, 2011 | Dryers
Just hada brief power flash. Washing machinbe was on. Now just keeps beeping with E60 lfashing on the screen. Not continuing cycle. Can't open door. Can;t re set
The E60 is not listed but it means the cycle was interrupted due to a fault with the motor.
You don't provide many details about what is happening or when the code is displayed.
Try to run a drain and spin cycle and see if the motor will turn.
The E60 error most likely means there is a problem with the motor.
Mar 13, 2011 | Washing Machines
E60 on zanussi zwf1630
I am not a repair professional. I am just a 78 year old
man who has been making his own repairs for about
50 years. Therefore the washer or dryer ID doesn't
mean much to me. I came to fixya looking for a
schematic for an really old AM/FM radio and
discovered that more than 4,700 people were asking
for help with a washer repair. I recently had a washer
repair of my own and found an excellent video which
showed me how to take my machine apart. This
video made it possible for me to do my own repair. I
was so impressed with the video that when I saw all
these people needing help, I wanted to tell them
about it. If you have a top loader (washer) of the
direct drive type, this video might be a Godsend for
you. If you look at the back of your washer and the
panel is solid (no small inspection plate to remove)
chances are you have a direct drive and this video
is just what you need. You can see this video at
www.acmehowto.com You will probably need
more help in determining what the problem is and
how to fix it. If your repair problem is a washer or
dryer I suggest you go to www.applianceaid.com
where they have very good trouble shooting and
repair information on most washers and dryers.
I think you'll find what you need there. Don't worry
about the timer, they hardly ever go bad. Good
luck with it. If I have helped you, please rate my
advice on fixya.
Nov 29, 2009 | Zanussi ZWF1630 Front Load Washer
I have an LG Fuzzy Logic top loader. it keeps draining water out
If it's really as you described, when draining at the same time filling up, then it's a problem in the main control board. You'll need some electronics knowledge to repair it, or just replace the main board
Aug 07, 2009 | Washing Machines
Error code e60
Hi I had this on my zanussi not long ago I pressed the reset button in for 5 seconds and it stopped . The computer board needed resetting. Hope this helps
Jul 07, 2008 | Zanussi ZWF1440 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
