Question about Miscellaneous
10282443711 card number - Miscellaneous
How can i get a pin for my greendot
Search Results
ATMs ' Help ' Green Dot Prepaid Cards
https://www.greendot.com > Green Dot Help > Using Your Card Top Searches: How do I Get Started? How to Add Money to my Green Dot card? How to Send and Receive Money on to Green Dot Card? How to Use my Green Dot Card? How to Manage my Green Dot Account? How to Direct Deposit my Tax Refund?
Forgot User ID? - Green Dot
https://secure.greendot.com/account/auth/forgot-userid Forgot User ID. Confirm your identity to receive your login info. Social security number. Please enter your social security number. 16-digit card number. Please enter the card number. CVV. The CVV is the 3-digit security code printed on the back of your card. Please enter the 3-digit security code. Submit ...
Forgot Password? - Green Dot
https://secure.greendot.com/account/auth/forgot-password Forgot Password. Confirm your identity to reset your password. Social security number. Please enter your social security number. 16-digit card number. Please enter the card number. CVV. The CVV is the 3-digit security code printed on the back of your card. Please enter the 3-digit security code. Submit.
Welcome to Green Dot!
https://m.greendot.com/activate This PIN will replace the PIN you chose when you set up your Temporary Card. You can use the same number or create a new one. Your PIN cannot be all the same digit, like 3333, and it cannot be a sequence, like 6789 or 4321. Last 4 digits of your Social Security Number. Please enter the last 4 digits of your Social ...
Help ' Green Dot Prepaid Cards '
https://www.greendot.com/help/ How do Green Dot Prepaid Debit Cards work? How much does it cost to order a Green Dot Card? How to Set up Direct Deposit on Green Dot Card? How to deposit a check on to Green Dot Card? How do I get a Green Dot Card? How to Register/Activate my Green Dot Card? How to add cash on a Green Dot Card? How do ... ‎Card Help · ‎Using Your Card · ‎Getting Started · ‎Adding Money
FAQs - Green Dot
https://secure.greendot.com/greendot/account/faqs Jump to What do I do if I have a question or think there is an error on my card? - You agree that any unauthorized use does not include use by a person to whom you have given authority to use the card or PIN and that you will be liable for all such uses by such person. For example, if you have given your card or card ...
Dec 31, 2017 | Computers & Internet
Tip
Locate Graphics Card Serial Number or S/N.
Your graphics card serial number is very important. It is there to to identify each graphics card shipped around the world. It is useful when needing support from the manufacturer. The serial number may be located in many places, here are a few of the usuall locations.
1.) The serial number can be found on a little sticker pasted to the out-side of your graphics card box. The abbreviation S/N is often used, it stands for Serial Number.
2.) Similarly a corresponding number is usually also placed on the graphics card itself. Usually it is placed on the flat most side of your graphics card, ie: the side without the heatsink cooler. Again look for S/N.
3.) Some-times the store that you purchased the graphics card from includes the serial number on their Invoice/Receipt that you receive with your graphics card.
This applies to virtually all brands of graphics card, from ASUS, EVGA, Gigabyte, MSI, XFX etc...
Take care!
Norman-Wynne Damstra
on Dec 26, 2011 | ASUS Computers & Internet
Tip
How to unlock phone requesting PUK number
First of all, you need to know what PUK means, it simply means Personal Unblocking Key.<br /><br />Phone requests for PUK code/number when a wrong code has been entered more than 3 times while trying to access your phone. The Sim card blocks itself and requires you to enter the PUK number in order for you to gain access to your Sim card once again.<br /><br />Most of the times, the PUK number is found inside the pack that you got the Sim card out of. In the pack, you will see a card, the one you broke the Sim card from, you will see your mobile number, the Pin number to the phone, then you will see a 8 digit code on the card, that is your PUK number.<br /><br />If you do not see it on the card you broke the Sim card from, then you will have to check thoroughly in the pack for the number.<br /><br />If you do not find it there, do not panic, you can call the customer care of the Sim card provider, they will give you Your PUK number as long as you can answer some easy questions about your Sim. <br /><br />Then you enter the PUK number on your phone, it will prompt you to enter a new PIN number, then you confirm the Pin number, after reentering the new Pin number, you will be able to assess you phone once again. Make sure you enter a Pin number that you will easily remember in order for you not to encounter such problem again.<br /><br />Hope this was helpful!
on Jan 10, 2011 | Samsung Star GT-S5233 Cell Phone
How do I change my debit card number to a new number? I lost my card on file, but now have a new card'
You can not change your old card number. When you apply for a new card they will send you a new card and ask you to activate the new card by calling a phone number that is on your new card. They will help you from there to set up a new pin number.
Nov 07, 2016 | Computers & Internet
What site can I go to get a puk code
PUK number can only be obtained from the service provider's SIM card.
Remove the SIM card from the phone.
Record the serial number (MSISDN / ICCID) available on your SIM card.
Contact your service provider SIM card (or via online).
Give information that you will be asked for the PUK number.
Customer Service from SIM card service provider will ask a serial number (MSISDN / ICCID) of your card (instead of your phone number), and will provide its PUK numbers.
Insert the SIM card, turn on the phone, and enter the PUK number.
Filling the PUK numbers should not be any more than 10x. Because if that happens, your SIM card can not be used at all.
Sep 03, 2015 | Cell Phones
Change my credit card number
To no longer have use of a credit card number, while the account is still open and active, and to change that credit card number to a newly assigned number...
Call your credit card customer service number located on the back of that credit card, from an issued paper credit statement, or from the official credit card website. Mention that the existing credit card number has been compromised and that you need to change that number by canceling the existing card. The credit card company will then re-mail you another credit card with a newly issued credit card number.
In the past, MBNA credit cards had the ability to issue short term use pseudo credit card numbers that represented the existing account, but could only be used for a specific customized dollar amount. However, Bank of America no longer supports this function any more.
Oct 15, 2014 | Computers & Internet
I want to change my visa card no
Visa card no or pin no ?
Edit a Visa PIN
In today's world, many of us rely on plastic and go light on carrying cash.
Visa is one of the leading card brands worldwide with 1.8 billion cards in use, including credit and debit cards.
But in those instances when you need cash, you also need a reliable Personal Identification Number.
But what if you forgot your PIN or are concerned someone saw you use it?
Call the phone number of the Visa card issuer.
Most cards have a toll-free number listed on the back of the card.
Choose the appropriate phone menu options to speak to a live person. Most banks and credit card companies require live verification before they will implement a change of PIN.
Answer the customer service representative's identification questions.
These may include personal information such as social security number, current address, mother's maiden name, when your account was opened, your place of birth and location or branch where your account was opened if your card is linked to your bank.
Request your change of PIN.
Have a new PIN in mind in case your credit card company or bank allows you to choose the new PIN over the phone.
In some cases, the Visa issuer will automatically assign you a new PIN and will likely mail it to you.
Confirm with the customer service agent that the change has been successfully completed before you get off the phone.
Change Your Visa Card Number
Changing your Visa card number mitigates or prevents fraudulent activity on your account.
The customer service department of your issuing bank can change the number in some situations.
Some banks and merchants also offer services that mask your true card number when making purchases.
Prepaid debit or gift cards also provide an alternative card number in lieu of directly using your main credit card account. Threat of Fraud
Contact the customer service department of the card issuer if you believe fraud has already occurred on your account, or you suspect your credit card number is in the hands of an unauthorized party and fraudulent activity is imminent.
The card issuer will deactivate the compromised account, assign a new card number and mail a new card.
Cut up and dispose of the old card once the new card arrives.
Log into any online merchant sites where you used the old card number and delete that information from the site.
Decide if you wish to enter the updated card number at that time. Protect your account by masking it.
If you want to change a card number in a situation where no fraudulent activity has yet occurred, Rebecca Lindsey of Cardratings.com suggests contacting the customer service department of your issuing bank to inquire whether the bank offers "virtual card numbers."
Virtual card numbers are "disposable" credit card numbers that can be used a limited number of times over a range of specific dates.
Using a virtual card number eliminates the need to provide merchants with your "real" card number, preserving the security of your account.
Dec 09, 2013 | Computers & Internet
Greetings, I was just trying to process a phone
CVV2 is short for "card verification value 2", and it's the three-digit number you find on the back of a credit or debit card near the signature area. The value is derived from the card number but doesn't appear on the face. The idea is that someone may randomly generate a credit card number, or copy the card number from a good card, but unless they have the CVV2 number the card can't be used. The error you got means the CVV2 value didn't match the expected one for the card number.
Jun 03, 2011 | VeriFone VX510
I need instructions for "can't
"To begin, the deck of cards is spread out. Each card contains a number, from 2 through 12. The player on turn rolls all four six sided dice. From the roll, players may combine two sets of two dice to make a number, placing chips on the matching turtle cards. For example, if a roll of 2, 3, 3 and 4 is rolled, a player may combine the 2 and 3 (to make 5) and the second 3 and 4 (to make 7) and place a chip on the 5 and 7 turtle cards respectively. An even better play would be to combine the 2 and 4 and both 3s to earn TWO chips on card number 6. A player may continue to roll and place chips as long as he is able to combine at least ONE combination that is still viable. When it a number not viable? When the matching number card is won and out of the game!
As a player rolls and chips mount on cards, a player may choose to stop and mark on the score sheet the number of chips he has placed on a particular card or cards. Should a player place the required number of chips on a card (an amount that varies from only two for cards 2 and 12 up to seven for card number 7), that player claims that card and both that card and number are now out of play. Should a player be unable to place a chip on a card on his turn, his turn is over and all chips placed on that turn are lost! The first player to successfully claim three cards wins the game!"
Source
May 18, 2011 | Toys
Need a puk number to my viva sim
my number is 33734927<br />i need puk number.<br />
Sep 09, 2009 | Sony Ericsson K600i Cellular Phone
Miscellaneous Logo
26 people viewed this question
Top Miscellaneous Experts
Andy Fraser
Andy Fraser
Dan Grod
Level 1 Expert
dennis lewis
Level 1 Expert
Are you a Miscellaneous Expert? Answer questions, earn points and help others
