Question about Canon Office Equipment & Supplies
Where is fuser unit in ir2420 - Canon Office Equipment & Supplies
Hi everybody my photocopier canon ir2420 print full black the whole page..i change drum,charger roller,clean laser scanner unit,Pcb but the problems still..need ur help
You probably did not get the drum unit seated in place and the drum is not grounded. Make sure your lamp is coming on.one of the charge wires is not all the way in. Go back and reseat the drum unit. Check it twice. And you did release the developer. I hope so. If not that's what keeping this unit from being in the correct position.
Apr 22, 2017 | Canon Office Equipment & Supplies
E003 Error code in canon ir2420 photocopier
Code E003-0000 Description Abnormally low temperature (detected by main thermistor)
After the temperature detected by the main thermistor has reached the specified value, it does not reach the specified value during initial rotation. Remedy - Check the connector of the fixing film unit. - Replace the fixing film unit. - Replace the DC controller PCB. Error Codes Canon iR2420 Code E003 0000
Oct 28, 2015 | Canon Office Equipment & Supplies
ERROR CODE **E00000-00 IS DISPLAY IN MY CANON PRINTER IR2420 SO WHAT CAN IDO TO SOLV THIS
Startup error
The temperature detected by the main or sub thermistor does not rise to the specified value during startup control. - Check the fixing film connector. - Replace the fixing film unit. - Replace the DC controller PCB.
Dec 04, 2014 | Canon Office Equipment & Supplies
How do i upgrade firmware on canon copier ir2420
The firmware can be upgraded by USB stick!
Nov 10, 2014 | Office Equipment & Supplies
How can i solve for the error 00007-0000
problem with fixing unit.probably you have to change fixing film
Oct 14, 2014 | Canon Office Equipment & Supplies
How do I change out the fuser fixing unit on a Kyocera FS3900 DN
1. Draw the rear unit.
2. Insert a flat-blade screwdriver to push the
fuser lock (gray colored) on the rear unit and
the fuser unit is separated from the rear unit
(rails).
Do it both ends of the rear unit.
3. Check or replace the fuser unit and refit all
the removed parts.
Place the fuser unit on the rear unit (rails)
and push the fuser lock so that the fuser
lock catches the fuser unit.
Do it for the both ends of the fuser unit.
Aug 08, 2014 | Kyocera Mita FS3900DN Fuser Fixing Unit -...
26 people viewed this question
old marine
old marine
