Question about Home
I have a really bad taste in my mouth everyday that tastes like abowel and the smell is in my nose to also the same smell comes out my pores to and my clothes smell like it to please help me what is
Please tell me what it could be what is wrong with me I have tryed everything from taking a shower twice a day brushing my mouth 5 times a day help me
  • Brett Duxbury
    Brett Duxbury Dec 18, 2016
    Hi Rhiannon Yancey, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    have you been tested at the doctors for liver function ?
    have you had your bowel checked with a colonoscopy
    Could be a yeast infection cut out sugar see if it improves.
    Other cause a leaking bowel. http://scdlifestyle.com/2010/03/the-scd-...
huuum
  • 750 Answers
SOURCE: Bad water & ice cube taste
Hello redwood City
Welcome
You said,
Your Kitchenaid Superba KSRG25FKBL15 has bad tasting water and ice cubes. You replaced the copper tubing which delivers the water to the fridge and that didn't help. You replaced the copper tubing again with plastic tubing...no better. Any suggestions? Your tap water doesn't taste this bad.You bought a Kenmore french door fridge with water dispenser in the door in July 2008. The fridge has a filter. A few weeks after the fridge came the water and ice started tasting really bad, unlike any bad water taste I have ever tasted. And your tap water is fine. The bad taste appears to be random. Sometimes you get a cup full of nasty water and sometimes it tastes fine.
First you must know you have a 1 year warranty and can have them come out to fix anything, no charge.If it persists. You will have to get tough and you , MUST INSIST THEY REPLACE YOUR FRIDGE
When installing the water line these were a part of the directions!
Did you do this before connecting the water line to your fridge?
"Place the free end of the tubing in a container or sink, and
turn ON the main water supply. Flush the tubing until water is
clear. Turn OFF the shutoff valve on the water pipe. Coil the
copper tubing."
Whirlpool remedy
Off-taste, odor or gray color in the ice
1.Are the plumbing connections new, causing discolored or
off-flavored ice? Discard the first few batches of ice.
2.Have the ice cubes been stored too long? Throw old ice
away and make a new supply.
3.Does the freezer and ice storage bin need to be cleaned?
See “Cleaning” or “Ice Maker and Storage Bin.”
4.Has food in the freezer or refrigerator been wrapped
properly? Use airtight, moisture-proof packaging to help
prevent odor transfer to stored food.
5.Does the water contain minerals (such as sulfur)? A filter
may need to be installed to remove the minerals.
6. Is there a water filter installed on the refrigerator? Gray or
dark discoloration in ice indicates that the water filtration
system needs additional flushing. Run additional water
through the water dispenser to flush the water filtration
system more thoroughly (at least 2 to 3 gal. [8 to 12 L] or 6 to
7 minutes initially). Discard discolored ice.
Let me know what works,
Thank You ,
HUUUM!!
Please remember to leave a rating.
Posted on Oct 12, 2008
SOURCE: What if my coffee tastes bad?
Did you run the vinegar through it three times, then rinse it three times? You might try changing the filter and filter basket.
Posted on Jan 07, 2009
peyton32034
  • 410 Answers
SOURCE: Bad tasting water and ice from refridgerator.
i agree with rpbuice but in addition to flushing the water line you may need to replace the line then using the water dispencer run out about a gallon of water thru the door. this will clear the reservoir of bad tasting water. for the i/m throw out all of your ice then let it make a couple of batches and throw out that ice as well be sure to clean your ice bucket very good to remove any lingering tastes from the old ice.
fyi bad tasting water is generally from bad water supplies. good luck..
Posted on Jan 20, 2009
  • 131 Answers
SOURCE: Mr Coffee Maker FTX25 - coffee tastes bad
Try running a 1/3 white vinigar -2/3 water mix into the brewer, let it brew, then run several pots of clear water through it. This should clean up any bad taste.
Posted on Feb 13, 2009
  • 12 Answers
SOURCE: very bad smell coming from dishwasher
at the bottom of your dishwasher where the water drains out check that there are no food particles trapped inside that may cause the smell
Posted on Mar 17, 2009
Metal taste on my tongue,have recently had kidney infection
a metal tast6e on the tongue is an indication of a zinc deficiency or excess
talk with a chemist as to the simple test to determine if a deficiency or an excess
Kidneys are blood filters and the antibiotics used in the treatment may have affected that level
Dec 11, 2017 | Health & Beauty
2000 ford f150 makes a wining sound even after truck is turned off. to stop noise you have to take off one of the battery cables.
if you use your nose, you can smell where the problem is coming from. Just start sniffing, and locate the general winey smelling area. If it is a smaller part wining, you may need to taste the part along with some cheese and crackers to verify the wine. Once you have identified the suspect component, either start swapping parts and smell and taste the wine again or take the vehicle to a mechanic for a proper diagnosis and repair. Either way, you will eventually find the problem.
Feb 21, 2015 | Ford Cars & Trucks
Why cant i taste anything iv had a cold and iv had a chest infection for ten days
I am in no way a doctor but by pinching your nose you ability to taste is much diminished.If you have a blocked nose this acts the same way and your sense of taste is poor.
Jun 09, 2014 | Wiltr Taste Buds And Molecules
We are making our own wheat beer and followed all the instructions really carefully but there is a horrible egg-like smell coming from the barrel. Is there something wrong with it?
A good wort should take like a warm, flat beer. It doesn't sound like anything is wrong with your beer but you won't know for sure until you taste it. If it tastes bad it might be a sign of infection.
Feb 21, 2013 | Crafts & Hobbies
Keurig drinks taste bad like plastic
try running viniger threw it then flush it out
Aug 29, 2012 | Cars & Trucks
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
Drinking water has a bad taste and smell.
You will have to trace where the foul smell comes from by tracing the water line and testing the source. Check if it is before or after the filter you get the smell, if it is before the filter, you need to check if it is on the line which comes from the source or it is from the source. Most likely cleaning or probably a replacement of the part if cleaning does not help.
Sep 21, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice maker has bad taste and smell
Add a cap of Miltons or a couple of granules of pool chlorine. Allow it to stand for a couple of hours and then drain.
Mar 08, 2009 | Kenmore 21.7 cu. ft. Top Freezer...
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Home Logo
80 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
