Question about Boating
What do i got to do to fix my submerged 30hpr 4 stroke outboard
  • 86 Answers
SOURCE: 2003 yamaha 115 outboard motor that dies when
I would check your fuel lines from the tank all the way to the fuel pump. It seems that you might have a pinched line somewhere. You can also bleed the fuel rail with the schrader valve on the end of the rail. If that wont fix it then you probably have a weak fuel pump.
Posted on Aug 09, 2009
  • 18 Answers
SOURCE: yamaha outboard starting
New plugs and service
Posted on Sep 21, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
  • 2100 Answers
SOURCE: oil filter for 2009 25hp mecury 4 stroke outboard
PH6017A Fram Oil Filter,,,,, I found a number for a fram filter, also found a ton of complaints about that engine. Whew! Hope this helps.
Posted on May 02, 2010
  • 512 Answers
SOURCE: how do i replace the impeller on a honda 4-stroke 130 hp outboard?
Page 108
Posted on Oct 06, 2012
I need a manual for my 4 stroke 100HP Susuki outboard
Frans, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
suzuki 100 hp outboard specifications Google Search
May 02, 2016 | Boating
Do I use reg gas or a gas mix?
Matt, If engine is two stroke and not oil injected then yes you must mix 2 stroke oil and fuel. 4 stroke engine have a crank case which is filled to proper level with 4 stroke engine oil. Check the attached links,instruction and guides, Good luck
How to Decide Between Two or Four Stroke Outboard Boat Engine
4 Stroke Outboard Motor vs 2 Stroke Outboards
2 stroke outboard Vrs 4 stroke outboard
Apr 15, 2016 | Boating
Gas flowing out of the top of carb. this is a 9.9 mercury 4 stroke outboard motor.
this can happen when the float in the float chamber of the carb. jams or "grot" gets in the way of the seal that pressure from the float should create to stop fuel entering the carb. An easy fix, if this is the cause. Unscrew the float chamber be, careful of the gasket, and clean inside, check float for freedom of movement. I prefer paper/fibre gaskets. Good to keep a spare in your kit.
Hope the above was of help.
Feb 28, 2016 | Mercury Marine 15hp & 20hp 4 Stroke...
Are the controls for a 1998 15 HP 2 stroke Mercury outboard compatible with a 2011 30 HP 4 stroke Mercury outboard
If your old engine/control has the same 'options' as the30hp, yes everything is compatible... (Electric start or trim )
The throttle and shift cables are allways compatible...
Jun 25, 2015 | Mercury Marine 15hp & 20hp 4 Stroke...
What pins on the ignition switch are energized when when you turn the key on a 2003 mercury 15 hp 4 stroke outboard?
Red is Battery +
Red/purple is ignition
Yellow/red is startermotor
Black/yellow is motor kill
Black is ground
To have ignition, black/yellow wire must be disconnected
On is red/purple on bat+
To start Yellow/red on batt+
To kill: black/yellow on ground
Jul 29, 2017 | Boating
What year is a johnson 4 hp outboard serial number b 7643180 model number bj4brccs
To get the year of Johnson and Evinrude outboards use the word "INTRODUCES". Each letter corresponds to "1234567890" respectfully. It's best to check with a model year reference book, but this motor's model number contains "CC" which would indicate it's a '88.
Sep 21, 2014 | Clymer Evinrude/Johnson 2-70 HP Two-Stroke...
I have no spark on 1989 7.5 evinrude outboard motor
Hi have you tried it with the stop switchl/button disconnected, if so you have only got the stator under the flywheel left to replace, regards Phil.
Jun 04, 2012 | Boating
About 4 yrs old 90? hp 4 stroke outboard runs
ignition timing may be off slightly.
Mar 12, 2010 | Boating
Boating Logo
87 people viewed this question
Top Boating Experts
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
