Question about Yamaha Boating
How to fix a submerged 4 stroke 30hpr yamaha outboard
  • 710 Answers
SOURCE: 40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Posted on Apr 27, 2009
  • 53 Answers
SOURCE: yamaha outboard 150 4 stroke bad vibration at 700
is you propeller bent? a dent the size of a quarter will cause a shake. If not that means your engine is misfiring. here are the troubleshooting test and tool list you need to find out. Tools(1) A compression gauge (2) a spark gap tester.(3) A Clymer service manual for your engine. (you can purchase from your local outboard dealer. I know all these are expensive but if your going to be a outboard tech you will always need them. Troubleshooting (1) check compression. without the year model I'm giving you a average numbers. Look at your Clymer manual. all cylinders need to be over 100 lbs and equal each other within 5 lbs.(2) check spark. use a spark gap tester all cylinders should jump a half inch gap. if you have good compression and good spark, fuel is the problem nine times out of ten.Ethanol gas is proven to stay stable in fuel systems for 30 days in 90 + degree heat. Drain gas tank,clean fuel lines replace primer bulb and replace all fuel filters. Yamaha has a gravity filter under engine coul clean it. Finally replace spark plugs, I know spark plugs probably don't look bad but this is a outboard. Fresh spark plugs means less resistance for the ignition system. The ignition system is week compared to automotive. Test drive boat, if the problem is still there then there is further steps to take. Again I don't know the year model so I guessing its fuel injected. Pull out your clymer manual. what is great about the Clymer Manual for Novice techs is it gives detailed info on your outboard. Troubleshooting tips and teaches you how your outboard works.
Posted on Nov 03, 2009
SOURCE: Re-assembling lower unit of 40HP Mercury 4 stroke
I found a lower gear case assembly diagram at which helped me understand how the shift mechanism works. This clued me in to the fact that I was missing the cam follower rod which I then found I had inadvertently mopped up in a shop towel when cleaning up spilled gear oil. After that discovery, assembly and operation was quick and successful.
Posted on Nov 12, 2009
  • 1711 Answers
SOURCE: i have a yamaha 2
On the tachometer back you have secured a wire thread just like the one from the brakes of a bicycle. The other end of the wire is secure to the engine. This wire complete, need to be replaced.
As a test first disconnect it from the tachometer and see if ok if not then the problem is with tachometer.
Posted on Oct 03, 2010
  • 512 Answers
SOURCE: how do i replace the impeller on a honda 4-stroke 130 hp outboard?
Page 108
Posted on Oct 06, 2012
Where is the oil filter located on a 2004 Yamaha outboard two stroke motor
Some links including a video of how to change the filter. In such questions horsepower is useful along with year :>) Oil filters would only be on a 4 stroke though to protect the engine oil. Your two stoke doesn't have filters in the lower unit. There may be a strainer in the two stroke oil tank.
check page 31 here
year make HP manual
Jul 04, 2016 | Yamaha Yamalube Outboard Oil Change Kit...
My 2002 Yamaha 115 4 stroke outboard engine leaks 2qts oil in 6 hr opn. How do I troubleshoot and fix
degrease engine when you got covers off then run in tub of water and look where its coming from !
Jul 24, 2011 | Yamaha Boating
Yamaha outboard starting
New plugs and service
Sep 21, 2009 | Rock & Ice Climbing
I need the spark plug gap for a 2001 Yamaha 115hp 4 stroke outboard.
For a 2001 Yamaha F115 4 stroke use NGK Plugs LFR6A-11 gapped between 0.039 and 0.043
May 09, 2009 | Yamaha 12V Air Pump
Boating Logo
79 people viewed this question
Top Yamaha Boating Experts
Phil Walker
Phil Walker
Colin Stickland
Colin Stickland
Are you a Yamaha Boating Expert? Answer questions, earn points and help others
