I nee small squirm cage fan for mitsu bishi and How to change it model wd-65638
  • Televison & ... Master
  • 10,137 Answers
5 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: video on 65 inch Mitsubishi
If you have the original working Mitsubishi remote you can try a soft restart:
Menu, 1,2,3, enter
SD TECH
Posted on Aug 31, 2011
bugoy31
  • 1238 Answers
SOURCE: mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
I think you need to download the manual for you to easy follow how it works...
try this link:
http://safemanuals.com/user-guide-instructions-owner-manual/MITSUBISHI/WD-65638-_E
try to click the right box and click the boy to the left side...rate and comment then download..
Posted on Dec 19, 2011
gopakumarg43
  • 75157 Answers
SOURCE: My Mitsubishi t.v model number wd-65638 won't turn
Check and replace damaged component/s at it main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Do a search by type in the brand name of your device at its search box.
It will be best to replace the power supply regulator board as card basis.
Posted on Jun 04, 2014
  • 5631 Answers
SOURCE: Model WD-65638. What are the instructions for programming remote?
If you have the original remote of your TV, it doesn't need to be pregrammed. If doesn't work, it's defective.
If you want to program a universal remote, you need the codes of the remote for your TV. If you don't have the manual you should look for it using google with terms
Manual make and model of remote
If you have a manual and no codes for your TV, follow the prodedure indicated to scan your TV with the remote till you find the code or cover all the range of the remote without getting a working code.
Posted on Sep 28, 2015
Humming Noise from TV
There are multiple fans and a high speed light device and a ballast in that television. All could be causing this.
Feb 05, 2016 | Mitsubishi WD-65638 65" DLP HDTV
Replaced bulb, now tv comes on for 1-2 minutes, goes funky and turns to a red light on power.
Possibly replacement lamp is wrong power, size, type, etc., or may be defective. Try another lamp. Also, clean and vacuum cooling fans and filters. One fan is squirrel cage type, the other is a pancake type. Lubricate each fan with a tiny drop of Z-Max or other light oil on each motor bearing. Regards.
Nov 05, 2015 | Mitsubishi WD-65638 65" DLP HDTV
Mitzibushi Tv model WD-65638 no picture no sound
Youre lamp has failed. you need to replace the lamp. Refer to the manual to see how to replace it. It only requires 2 or 3 screws on the back to be removed. Please check the manual.
You need a 915B441001 lamp. 915B441001 PVIP Mitsubishi DLP TV Bulbs
Feb 25, 2015 | Mitsubishi Televison & Video
Mitsubishi dlp wd-65638 with error code 61. What is this error code? How do I fix? no picture or audio.
if the power LED is flashing green then there is a circuit or board that either has a blown fuse or relay. if it comes on solid red when you turn on the television then the Lamp inside is burned out and needs replaced. Before you spend all the money that changing the bulb would cost i would invest that money in a good LED Smart TV instead. Sometimes you just gotta let that old technology go away.
Dec 30, 2014 | Mitsubishi WD-65638 65-Inch 3D-Ready DLP...
Mitsubishi wd-65638 dlp tv error codes sound no picture replaced the bulb I get a code of 6 blinking red and 1 blinking yellow
If you wish to get more details, check this site. Pull up older posts there. Check the site with patience, as it has over 2250 posts now. All are related to electronic equipment repair help.
Blinking codes to Mitsubishi PTVs are given in detail.
Apr 10, 2013 | Mitsubishi WD-65638 65" DLP HDTV
Troubleshooting lakewood fan model hv 18
This one the best brands on the market that I have ever owned.
If the fan motor will not turn on or hums and/or turns slowly more than likely its a lubrication problem.
1. Unplug the fan from the wall remove the 516 screws to the cage
2. Try turning the fan blade by hand if it is tough to turn more than likely it's a lubrication problem
3. You will have two oil holes one in the front one in the back spray WD-40 into these holes, turn the fan blade if it starts to free it up apply more WD-40 and keep turning the blade add more WD-40 until the blade turns freely. Especially in the rear oil hole because this is an oiled bushing that you are adding oil to. Once the fan is turning freely replace the front cage with all the screws plug the fan and I hope this solves your problem. You may add 3 in 1 oil or some other very light lubricating oil periodically.
I hope this solves your problem Mike
Mar 03, 2012 | Lakewood HV 18-c Floor / Box Fan
Mitsubishi wd-65638 65 in hd tv dlp tv usb i dont no how to work it
try this link:
Dec 11, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Video on 65 inch Mitsubishi Tv model WD-65638 is not working how may i reset this or even fix the situation.
Menu, 1,2,3, enter
SD TECH
Aug 31, 2011 | Mitsubishi WD-65638 65" DLP HDTV
Does the lakewood fan have a fuse that can be replaced?
No, it is either the speed control, capacitor or motor. You can get parts, if it worth your time, try nelsonappliance.com and part # LW007JRMOTOR
Aug 26, 2009 | Lakewood HV 18-c Floor / Box Fan
My tv shows its's geting 1080i only
1080p signal... THE MITSU. WD-65731 has a resolution of 1080p its just the res your PS3 is pumping into your screen is loaded with a little bit more pixels than you 1080p res MITSU. I suggest getting a MITSU WD-57731 since it has a 1080P/24 input. and has great clarity and HD ample for the BD of your PS3. however the differences in picture rate and quality is very small. goodluck.
Sep 22, 2007 | Sony Playstation 3 (PS3) Console
Televison & Video Logo
24 people viewed this question
Top Televison & Video Experts
