Question about In Microwave Ovens
Can i freeze boiled potatoes cut in small pieces
    Uploaded 5 video answers.
  • 47 Answers
Sure place them on a cookie sheet and freeze then place them in a zipbag and they wont stick together
Posted on Dec 29, 2016
How to heat cooked potatoes for mashed potatoes
hi Judy.
Put in the large pot as you peel and slice so they don't turn brown. Be sure water covers the potatoes by 2 inches, on medium-high heat and bring to a boil. Reduce to medium-low heat, cook the potatoes for 20 minutes until the potatoes are soft and fork tender. Turn off the heat, and drain well in a colander.24 Nov 2015
Make Ahead Mashed Potatoes Reheated 5 Ways - Delicious Table
if you want to know more go to this link.
How to heat cooked potatoes for mashed potatoes Google Search
Nov 23, 2017 | Microwave Ovens
How do i freeze raw potatos for french fries
Cut into fries and then blanch and freeze.
Nov 08, 2015 | Microwave Ovens
If I cut potatos into roastis can I just freeze the in bags?
not raw . but if you cook them they can be frozen .
Aug 17, 2015 | In Microwave Ovens
Can you freeze raw potatoes and how do you do this?
i assume you want to pre-prepare chips for big family gathering? or for any period of time.
you need good freezing unit
chips cutter
3ltr (1 gallon) water with bit of salt and bit of vinegar in it
5kg (11lb) potatoes
table spoon
water solution: to 3ltr (1 gallon) of water add and solve about 6 table spoon of salt and about same amount (6 table spoons) of vinegar (this solution will prevent blackening of the potato cuts), i am adding as well about 3 spoon of sugar to the solution, it allow liquid to cling better to the surface of potatoes, water should be cold, even few ice cubes in it will help
1. wash well your potatoes from debris, sand and whatever junk, remove unsightly, damaged or rotting bits from the potatoes
2. if you have chip machine or slicer - use it! chips should be not thicker than 12mm (1/2"), try not make them thinner than 3mm (1/8"), i do not bother with skinning them, but you may if you have masochistic tendencies. you can do that with knife as well, but will take longer. chips can be cut as straws, plates, sticks. waffle or whatever pattern you have in mind
3. chopped chips drop into the water solution and frequently stir as to allow all surfaces to be covered and prevent browning/blackening of the surfaces (this is oxidation of the surface, it is not poisonous but looks ugly)
4. after all potatoes were used, strain them from water, shake excess water and spread single layer on greaseproof (baking) paper or any other non-stick surface
5. your produce now need to be transferred to the deep freezer and frozen, minimum temperature should be -18c (0f), preffered will be -32c (-25f), if you are living in climate where these temperatures are outside, just put them outside...
6. after deep frozen (about 6h to 12h) divide them and pack them in sealed bags, in suitable portions
that way prepared chips can be stored for months, and if at lower temperature, even for years.
to fry:
have suitable fat at temperature of about 185c (365f), or whatever settings on your fryer is, you do not need defrost them, just directly from the fridge to the fryer, from the moment when they float, about 2min or until golden brown
if you like the recipy - why not vote for it?
Jan 01, 2015 | Microwave Ovens
How do I freeze cooked mashed potatoes?
Place them in a plastic container, close it, label and let go. I've never tried freezing mashed potatoes so can't testify as to how it holds up. But this is basically how I freeze everything else that comes my way.
Sep 27, 2014 | Microwave Ovens
I have the GE profile spacemaker microwave oven installed over my stove. One of the lights burned out on the left lower portion of the unit. I removed the screw, lowered the metal cover, and tried to...
You could try the potato trick. Take a small to medium potato. Cut off an end of the potato. Press the cut end into the broken lightbulb and unscrew the rest of the bulb out.
May 24, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Cannot remove broken bulb from rangehood
Hello. cut a raw potato so that you have a large piece that will fit into the area where the broken bulb is situated. Jam that potatoe right into the broken bulb and twist it out. Remember it will twist out by turning it counter clockwise. [right is tight, left is loose]. Joe
Mar 11, 2010 | Magic Chef CMV1000B Microwave Oven
Did I blow it up????
After washing you need to poke holes in potatoe skins or the steam can cause them to explode. Cook potatoes no longer than 6 to 8 minutes depending on your units power.
Microwave ovens can be very dangerous if damaged, so you will be safer to replace the unit. Better safe than sorry. Service on microwave ovens is not cost effective, and the newer ovens are very reasonable.
Oct 28, 2008 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
46 people viewed this question
Top In Microwave Ovens Experts
William Miller
William Miller
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
