Question about Coffee Makers & Espresso Machines
My machine light goes to flashing green. The machine then stops for a couple of seconds and then starts again. This is continuous till the cup is full
  • kakima Dec 18, 2016
    Hi Roger Brill-Edwards, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model?
  • 63 Answers
SOURCE: flashes on then goes black
The green light only lets you know there is a valid video signal reaching the monitor. If the green light was not "on" your problems would possibly be within the pc itself. Something is not holding the circuit for the backlight "on" thus going black. Suggestions are: 1. Take it to get it repaired (if not under warranty) Hyundai carries a 3 yr warranty on this monitor. Website provided. 2. Buy a new monitor http://www.hyundaiq.com/Eng/Customer/CusSvc/Csvc.asp
Posted on Aug 27, 2007
SOURCE: Power up problem
One thing u can do also. Open your system case, remove cmos battery clean cmos battery and then insert like same. And restart your system. Other wise check power connections voltage. If it is ok then definitely it will wirk.
Posted on Sep 07, 2007
SOURCE: Frigidaire Tumble Action Washer - lights flash, beeps, does nothing else...
If you have had a lightning storm or power surge it may have fried the electronics panel. That is what happened to mine. Once it is fixed you should put a surge suppressor on it that is rated for major appliances.
Posted on Apr 27, 2008
SOURCE: The Machine Lights are Beeping and Flashing
after i looked over the machines thred routing i found a pice of thred jamed in under the top clear plastic panel i took thihs panel off and removed the thred ,cleaned in there put it back togather and it now works fine just what i found hope it works for others
Posted on Nov 12, 2008
  • 188 Answers
SOURCE: Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
Both lights on my older model machine won't stop flashing
Try holding both buttons down while you turn on the machine - hold down till they stop flashing, usually 2 - 5 seconds. This resets the machine to its original factory settings.
Oct 11, 2014 | Nespresso Coffee Makers & Espresso...
Just out of the box, the sirena espresso maker doesn't heat and buttons don't flash
You need to prime the machine with water. Fill the water tank. Plug the machine in and turn the power on. Instructions state the lights will flash, but they won't. Blue water drop will illuminate indicating the machine is empty (the water tank is full, but the pipes in the machine are empty until you do the following). Place a cup under the steam wand, and rotate the steam knob fully to the "on" position (fully clockwise as you view it from the side until you hit the hard stop). No need to use force, just rotate until you hear the pump turn on. At this point, you'll hear a pump running, and after 10-30 seconds, water will be ejected from the wand. Continue until the blue light goes out and you're ready to brew. At this point, I think the lights flash and it comes up to temp. One more thing, when using the steam wand, always turn the knob until the pump engages, or you run the risk of emptying the water line. Hope this helps and enjoy!
Sep 15, 2009 | Saeco Starbucks Sirena Espresso Machine
Blue light blinking, tank full, water not heating up
noavatar_s.gif rktcyntst
Rank: Apprentice
Rating: 0%, 0 votes
Sep 14, 2009 | Saeco Starbucks Sirena Espresso Machine
Red descale light is on
I use distilled white vinegar, but you can use specialized coffee cleaners with this model:
Descaling
Descaling 11
Descale your Tassimo machine every three months to keep it
operating at full potential.
Descaling products are widely available from stores selling coffeemakers and espresso
machines. Only use a product intended for descaling. Mix the descaling product
directly in the water container, following the instructions provided on the descaling
packaging. Replace the water container on the machine.
2 Place a large cup or mug on the cup stand, insert the cleaning disc, bar code down,
and close the brew mechanism. When the AUTO light illuminates, press and release
the start/stop button. The brew cycle will fill the machine with descaling solution. Empty
the cup and let the machine stand for 15 minutes.
3 Open the brew mechanism and close it again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and release the start/stop button. When the
machine stops running, empty the cup, and let the machine stand for 15 minutes.
Repeat this step two more times for maximum descaling effectiveness. Discard the
remaining descaling agent from the water container, rinse it thoroughly and refill
with fresh, cold water.
4 Open and close the brew mechanism again, leaving the cleaning disc in place.
When the AUTO light illuminates, press and hold the start/stop button to flush water
through the machine. The MANUAL light will flash. When the cup is full, release the
start/stop button, empty the cup, and replace it on the cup stand.
5 Repeat step 4, flushing clean water through the machine in the same manner and
emptying the cup as it fills. To ensure that all the descaling solution is completely rinsed
away, flush two full water containers through the machine before using it again.
Mar 26, 2009 | Braun Tassimo Coffee Maker
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Tassimo
Mine sometimes does this but cleaning the barcode reader at the top of the machine (small glass panel) fixed it. Also make sure the water container is seated correctly. If these dont fix it try pushing the water container left right/back front while there is a disc in the machine-mine has started to only work if I push the fitted water container backwards when "brewing".Its out of warranty now so I will make do until it breaks completely. Regards Nicki
May 09, 2007 | Braun Tassimo Espresso Machine/Coffee...
Coffee Makers & Espresso Machines Logo
23 people viewed this question
Top Coffee Makers & Espresso Machines Experts
Shehu Pro
Shehu Pro
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
