Question about Tablets & eReaders
MY ONIX TABLET WHEN YOU TURN IT ON I ONLY GET THE TIME AND NO APPS ON SIDE OF SCREEN
Where can I buy a new battery for an Onix tablet AT9 014?
I will admit that I have never heard of Onix.
If you are located in the US, try "Batteries Plus Bulbs".
Feb 03, 2018 | Tablets & eReaders
I bought my daughter a Contixo tablet for Christmas, it connects to WiFi , but there are no apps installed or seemingly any way to log onto the internet. Any help will be greatly appreciated!
it should have an internet browser
does it have google play store .
Do you know how to use a tablet.
You may need to place finger on right hand side of screen and swipe finger to left side of screen. Apps may be on next screen
Dec 27, 2016 | Contixo Tablets & eReaders
What can I do, Asus tablet says "launcher has stopped" and will not do anything?
Always try a reboot first. If that fails go into settings, go to apps, then might have to go to system apps, see if you can start it from there. If it starts and stops, could be another app is interfering or you got too much installed and are low in memory. You can try to install a startup manager app and make sure to turn off all unnecessary apps from auto starting. If that fails, you can then try to reset to factory defaults and start all over. Just reinstall your apps one at a time and make sure system is stable after each install.
Jan 03, 2015 | ASUS 16GB MeMO Pad 7" Tablet Cherry Pink
How come sometimes my screen works real slow, or not at all. but when I restart it the screen works gust fine,
You might have too many apps or you might have too many apps that are active in the background that are slowing your tablet down. Uninstall unused apps or turn them off through settings. Apps always sync in the background, even when you don't use them. When too many apps are running at the same time, they drag down the wifi speed. Go to Settings>Wireless and Networks> Data Usage, view all the apps that are actively syncing. Also, in Settings>Device>Battery, you'll see which apps are actively draining your battery (if this is also an issue). You might be surprised which apps are either draining your battery or always syncing.
Sep 19, 2014 | Samsung Galaxy Tab 10.1 Wifi - Tablet -...
Where does the SD card go on 9" ONIX tablet?
It has a micro sd card slot on the side its very thin slot.
Aug 20, 2014 | Tablets & eReaders
Have ematic 003. When I uninstall any of preloades apps, it shows uninstall and the app no longer appears on the tablet. But the next time I turn on the tablet all the uninstalled apps are back.
It is not possible to uninstall preloaded apps on your tablet unless it is rooted. Then you have to check to make sure that no other services on the tablet depend on that app as it could mess your tablet up
Apr 30, 2014 | Ematic Tablets & eReaders
7 inch rca tablet support
What is the model number and brand name of your tablet.
Feb 15, 2014 | Tablets & eReaders
Power problem with Onix 7" tablet
The screen just flashess white i dont understand wat do do plz mi hopeles without it someone help me asap plz
Jan 27, 2013 | Tablets & eReaders
Can i download a manual for my onix tablet
my touchmate is loading only i want to fix this?
Dec 19, 2012 | Tablets & eReaders
Tablets & eReaders Logo
Top Tablets & eReaders Experts
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
