I have a gold air split unit..it is leaking water, how to unblock it
  • Heating & Co... Master
  • 1,925 Answers
Locate exterior drain, use shopvac and vacuum lines
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Posted on Dec 18, 2016
I have wansa gold series ac i start the ac then after 20 minute all led blinking & all system not working I need solution
i have wansa gold split ac unit >>>> i have water licking in the indoor peace
i need the solution please .
thank you
Apr 07, 2011 | Heating & Cooling
The inside unit is leaking water
Water leaking in split unit common, due to air filter & evaporator coil dust blocked- Clean it.
Drain pan and drain hose dust blocked-clean it. And also due to less rpm of indoor motor, there will be forming ice over the coil result to water leaking while defrosting.Replace motor capacitor.
Dec 27, 2010 | Fujitsu 24C1 Air Conditioner
Leaks water inside
Water leak is the common problem in split air conditioners.. It happens due to:
1. Air filter block 2. Evaporator coil Block. 3. Less rpm of blower motor. 4. Drain line blocked.
To rectify, service the unit completely. If blower motor less rpm, replace motor capacitor.
Dec 18, 2010 | Sanyo Split System Air Conditioner
The indoor split system is dripping water what can i do?
There should be a drain pipe to send the condensed moisture outside. Take the cover off the unit and check where the tray is and unblock the pipe.
Oct 05, 2010 | LG LSC121PMA Split System Air Conditioner
SANYO SPLIT TYPE AIR CONDITIONER LEAKING
The leakage is probably from condensation and there should be some sort of drain for it. You should check to see if it is clogged or partially clogged. Also since you say it does it when it hasn't operated for a while you may want to check out where the lines pass through the wall and make sure that it is sealed up there so you don't get leakage from out side.
May 04, 2010 | Sanyo Split System Air Conditioner
Samsung split systim leaks water from inside unite
when ambient air goes across your evaporater it causes it to condense check your drain hose it may be clogged up not allowing the water to drain properly
Feb 06, 2010 | LG LSC121PMA Split System Air Conditioner
Delonghi split system (inverta) leaking
clear drain line with air or water. If unit is really old possibly drain pan rusted with holes. make sure to change air filter this will cause coil to ice up if restricted.
Jan 23, 2010 | Heating & Cooling
GOLDSTAR AIR CONDICION (WALL UNIT) MODEL # BG8000ERY3
Download it from the manufacture webpage and the model #.
Sep 04, 2008 | Goldstar Heating & Cooling
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Mack Baxter
