How many btu is my hef33 model - Heating & Cooling
  • Brett Duxbury
    Brett Duxbury Dec 18, 2016
    Hi derek kwiatkowski, we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    is this a promaster heater it depends on the wattage as several different wattage models
    1500W 5,100BTU or 3000W 10,250BTU
My hef33 cord melted and blow a fuse why?
drawing too much power, may have a short circuit
Nov 14, 2014 | Heating & Cooling
Promaster model hef33
Check the capacitor for swelling or leakage. Any movement or sloppyness on the shaft and that motor is what they call in the biz poling out.
Nov 11, 2012 | Heating & Cooling
I am looking for a remote for my charmglow electric fireplace Model # hef33. I have been everywhere. Help!
I recommended this site to another questioner who needed a remote for their electric fireplace and apparently they were successful in purchasing a universal remote kit. It's worth a try.
Feb 08, 2011 | Heating & Cooling
Is there a remote 4 the fireplace pyrosmaster331hef
Yes, I believe you can, if it;s an electric fireplace, as I suspect.
It's part # 10006950. They call it a transmitter.
Go to the following link and check it out to see if that's what you need. Also, contact Dixie Products in Roanoke, VA, as I am sure Mark Silverstein can help you.
Feb 03, 2011 | Heating & Cooling
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
I have a pyromaster electric fireplace hef33 we have replace battery in transmitter and sometimes when can turn the unit on and off then it just stops working (transmitter)
The number provided by wilson524 is incorrect. To reach Hankscraft please call 608-524-4341. We are happy to assist you.
Thank you,
Hankscraft Inc.
Sep 29, 2009 | Leisure HOMEPRIDE Electric Fireplace...
That air handler can accamodate different size coils. Look for the coil model number. Also you can look at the outdoor unit model number they should be matched up. There is generally a set of 2-3 numbers in the model numbers that will tell you. xxx036xxx is 36,000 btu. tonnage is 12,000 btu per ton so 36,000 btu's would be 3 tons. xxx040xxx= 40,000btu's or 3.5 tons etc.
Mar 16, 2009 | Heating & Cooling
Elec. fireplace on switch
I found a website that has many of these parts. Try
Nov 02, 2008 | Leisure HOMEPRIDE Electric Fireplace...
Heating & Cooling Logo
29 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
