Question about Miele Dishwashers
I have a miele softtronic w2659 but the door lock is broken. Is it easy to repair this yourself? And where can I get the parts? Thanks.
  • 236 Answers
SOURCE: How to replace door lock
it may just need adjusting. it is located inside the top center of the door. check catch and lock. most of the lock is inside the door and is accessible by taking off the front panel.
Posted on Jun 11, 2007
  • 4793 Answers
SOURCE: ford focus zx3 2001 driver side door does not open from outside
that small plastic thing is always braking(slam the door a few times.....)you can get one from a ford dealer and its a pig to get to to repair....
Posted on Jul 09, 2010
  • 251 Answers
SOURCE: RE: Miele dishwasher G1472 The door
Sorry mate - manuals are hard to come by from miele, only service agents have these and are bound by contractual obligations.
there is a door locking plate located mid top of the dishwasher which latches to the door, a locking mech. # 6022271 located on the door itself.
The locking mech is electrically controlled only when cycles are selected and you push start. The chances are where the latch system which clicks into the mech is likely to be worn or jammed, the door should click into place as you close it and electrically locked during the cycle.
I would say there is a mechanical problem with the machine more so than anything else.
Posted on Jul 04, 2011
Testimonial: "Thank you very much for your kind help. I'll take the door apart to be able to inspect the the locking mechanism. Nice to know the part number. "
ercupa190
  • 12223 Answers
SOURCE: miele washer softtronics door will not open
go to this page and proceed according:
http://www.ehow.com/how_8562942_remove-door-miele-washer.html
God bless you
Posted on Jul 19, 2012
projdoc
  • 2237 Answers
SOURCE: samsung washing machine wf431ab door lock broken
try here- https://partstore.com/Model/Samsung/Samsung/WF431ABW.aspx?SearchTerm=True
Posted on Mar 02, 2014
I have Miele Softtronic W435 Plus. Display showing: check wastewaterpipe. What can I do?
Make sure the discharge pipe/hose from the washer to the house plumbing is clear.
Nov 19, 2016 | Miele Dishwashers
Washing machine miele w2659 manual needed
If you go to the Miele website you can download a manual for free. click on customer support and then operating instructions. Hope this helps.
Mar 04, 2014 | Washing Machines
How to reset miele wasmachine softtronic W3624
it may have a suds lock on it due to too much soap you may need to flush it
Jan 13, 2014 | Miele Washing Machines
Door wont shut
Door or Lid Latch Assembly
If the door won't latch, the latch assembly might be defective. Inspect the latch assembly to see if it is cracked or worn out. The latch assembly is normally replaced all as one part.
Enter your model number to see parts for your dishwasher.
Help me find my model number
Door Hinge
If the door won't latch, one or more of the door hinges might be bent or broken. If the door hinges are not working properly the door won't close squarely and then the door won't latch.
Door Catch
If the door won't latch, the door catch might be out of alignment or broken. If it appears to be OK, reposition it as needed. If appears broken it should be replaced.
Door Lock
If the door won't latch, the door lock assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door lock is broken, replace it.
Door Latch
If the door won't latch, the door latch assembly might be defective. These are normally made of plastic and cannot be repaired. If the door won't latch and the door latch is broken, replace it.
Door Strike
If the door won't latch, the door strike might be defective. These are normally made of plastic or metal and cannot be repaired. If the door won't latch and the door strike is broken, replace it.
Apr 05, 2013 | Miele Dishwashers
Miele washer softtronics door will not open
God bless you
Jul 18, 2012 | Miele Washing Machines
LOOKING FOR A DETAILED LAYOUT OF THE PART NUMBERS FOR A MIELE DISHWASHER G880SC
that is easy. miele is the only place that sells miele parts. you are going to have to deal with them to get replacements. no other suppliers and no parts to research. 800 843 7231. i have seen some parts on ebay so may be worth a shot.
Jan 26, 2012 | Miele G880 Dishwasher
RE: Miele dishwasher G1472 The door will not close. Does the lock work with a relay, or is just the plastic lock broken down? I should like to have a repair manual of this machine. Where can I find it?
Jul 04, 2011 | Miele G 1472 SCVI 24 in Builtin Dishwasher
Ford focus zx3 2001 driver side door does not open from outside
Jul 09, 2010 | 2001 Ford Focus
The lock which holds the battery door is broken. Where can i get a parts or repair it in Miami, Florida
You can order replacement parts on ebay relatively inexspensively. You may need a full housing ? These are easy to change you can do it yourself and save alot of money ; )
May 12, 2010 | Motorola Mobility MOTOROKR EM330 Cell...
Door hinge on refrig door
the door stop on the bottom of your door is either bent or broken off. this si located on the hinge side on the bottom of the door the part number needed to repair it is WR02X11465 you will have to empty and remove the door from the refrig to replace the part. it is a fairly easy do it yourself fix. good luck and thanks for using FixYa Peyton
Feb 19, 2009 | GE GSH22JFR Side by Side Refrigerator
Dishwashers Logo
46 people viewed this question
Top Miele Dishwashers Experts
mpservices
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
