Question about EIO Vacuums
Where can I get a replacement vacuum bag bracket for my EIO canister vacuum? Also the bags and replacement filters?
I have an EIO Millenniumm 2000 canister vacuum. This is an older model, and appears to be the same design as the more current EIO Varia Estate. The last person to dispose of the full vacuum bag did not realize it was held in place by a removable bracket, and inadvertently threw out the bracket as well. I need help to find and buy that bracket online, as well as a package containing both the correct replacement bags and the necessary filters. Thank you.
4 Suggested Answers
advacak
  • 125 Answers
SOURCE: Eio Varia Estate Vacuum cleaner
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs
Posted on Dec 02, 2008
ukvacfan
  • 328 Answers
SOURCE: where can I buy vacuum bags for my Bosch canister model BSG71 UC
Check out Ebay.com
or
http://cgi.ebay.com/GENUINE-BOSCH-TYPE-G-VACUUM-BAGS_W0QQitemZ190296223025QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item190296223025&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on Mar 27, 2009
SOURCE: were do I get replacement
4dfa5d4.jpg advacak
  • Rank: Wiz small_appliances_small.png
  • Rating: 83%, 100 Votes
contact the VDTA its a vacuum trade association. they will have contact info for all mfgs Call Suburban Vacuum Cleaner Parts at 1-877-592-5888 and they stock them.
Posted on Jan 07, 2011
Where do I get teh EIO Baria Estate or cottage replacement bags>
www.eio-vacuum.best-price.com
This is the web site that you can order bags from...if this helped you please remember to click on the yes box on the way out if you are satisfied with your answer. THANK YOU AND GOOD LUCK
Oct 10, 2010 | EIO Estate Bagged Canister Vacuum
How do I gain access to the motor of an Electrolux 2000 canister vacuum. The air intake on the motor must be partially blocked as there is a loss of suction and the motor makes that high pitched whine like...
Dismantling the vacuum probably won't help much, and reassembling can be a bear.
To check the intake, remove bag and look into bottom of bag well. It there's a filter there, remove it and check intake at bottom of bag well. Clear if there is.
The afterfilter on a canister is located beneath the air diffuser grid on the top of the machine where the tools can be attached. Remove this cover and there should be a white filter. Yours is probably black, or at least real dirty, if it's never been changed. This also blocks the airflow, reducing suction, and potentially damaging the motor. Extremely dirty filters are an indicator of how much dust is getting into and through the motor. This is usually caused by using generic bags rather than the genuine Electrolux, now Aerus, bags.
It is also an indicator of another internal problem on some other Aerus and pre-Aerus Electrolux vacuums.
Sep 10, 2010 | Electrolux UltraLux 2000 Bagged Canister...
Were do I get replacement bags for the EIO varia estate vacuum?
4dfa5d4.jpg advacak
Aug 24, 2010 | EIO Estate Bagged Canister Vacuum
Electrolux 2100 vac dies when you attach hose even with new bag.
If the bag full light keeps coming on, you can first try adjusting the dial on top of the vacuum cleaner. If that does not work, then you need to change the control valve. This is an internal component of the canister and is directly below the dial. You will need to follow the instructions on a previous post to open the Electrolux plastic canister vacuum, and remove the bage cage. Once you remove the bage cage you can change the control valve, and this will solve your problem with the bag full indicator.
Mar 31, 2010 | Electrolux UltraLux 2000 Bagged Canister...
How to use the after filters for the electrolux canister vacuum
At the back of the vac on top you will have a removable grille. Release the thumb tab to lift the grill.Older models had this tab at the back of the grille. The filters will sit underneath. They should clip into the round exhaust opening. Then replace the grille. Change filters every 6 bags. More often if you have pets or allergies.
Sep 12, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux #1521 Canister Vacuum won't stay closed
hi from uk your problem with the canister cover/door coming off whilst vaccing ? you have renewed bag ? ok but there is a filter/gauze also inside the canister where bag is fitted if you check inside you should see the filter at opposite end from where bag is secured it is usually fitted behind a slotted pull out plastic gate ? this filter/gauze is to allow air out of canister when vaccing and the filter traps any dust that may accumulate inside the canister case so the dust does not get blown out to atmosphere/rooms SO if this filter is clogged it will not allow vacced air to escape out of canister so result is build up of pressure within cylinder and eventually cover flips open ! so for now you can remove filter/gauze and wash then dry refit this will allow air to escape from canister but still retain dust particles from escaping as it is designed for however may i suggest you replace filter when convenient ? all above is on assuming that the latch on cover is working ok and not now damaged ? hope this helps best wishes
Mar 01, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux vacuum turning off
hi take off canister cover remove bag now if you look inside canister you will/should see a gauze type filter at the opposite end of canister from where bag locks in ?? remove this gauze filter and for now just shake tap on floor to remve dust/debri etc /from it this gauze is the filter that when vac is working andfilling the dust bag ? the pressure of air only that blows bag up but allows only air to pass thro the microscopic holes in bag ? then has to expel via the gauze filter to exterior ? and any dust etc that is clever enough to seep through the bag ??? will not pass further due to gauze ? and so prevents this blowing back into room ok so far ?? if this gauze is blocked due to whatever ?? then pressure build up in canister will result in cover lifting? this is provided that the fault is not the actual cover securing latch is ok and not damaged ? hope this explains and helps ? best wishes from uk !
Nov 08, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Aug 12, 2008 | EIO Estate Bagged Canister Vacuum
Bags
go to website for Aerus, which is the new name for older (grey) Electrolux vacuums. Long story.
website
http://www.aerusonline.com/
follow link to find dealer or order online.
J
Jun 11, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Vacuums Logo
65 people viewed this question
Top EIO Vacuums Experts
JoeVacs
Are you an EIO Vacuum Expert? Answer questions, earn points and help others
