Started as a black stripe on right side of screen with bright coloured lines through it when we connected the ps3, only the tv is now plugged in, bt appears if the screen is now bleeding black
Drummernick
  • 440 Answers
SOURCE: Black Vertical Stripe
try doing white wash feture in options see if u can get it out this way 1st before having to take aprt cheak cables are using old style sumtimes they do get glitch do factory reset thx for using fix ya . nick
Posted on Feb 03, 2008
jdbouncer
  • 72 Answers
SOURCE: Black stripe down TV plasma screen
along the sides or the center ? if on the sides check the picture format and see if it changes. If its doesn't go away sound like u might have a defective IC on the ribbon cable that plugs into the plasma panel
Posted on May 03, 2008
Ajkill
  • 2035 Answers
SOURCE: colour lines on samsung tv top side concave
  • Unplug your TV.
  • Leave it unplugged for a minute or two.
  • Plug the TV back in and turn it on.
  • Posted on Dec 06, 2008
    • 6 Answers
    SOURCE: I get this blue stripe down the right side of the page
    Open the doors to locate and wipe off the green shiny roller really well. Spin it and wipe it off all the way, especially on that right side. Pull out the cyan toner and wipe it around where the toner comes out. Check other rollers for blue marks and wipes those off as well. Lit free cloths work best but I just use a damp paper towel and then a dry one.
    Posted on Apr 27, 2009
    • 3 Answers
    SOURCE: multi coloured vertical stripes on plasma screen
    I had the same problem and I fixed it on my LG plasma
    This how I done it.
    Take the back plate off
    At the bottom you should see a metal solid plate, behind that plate is the ribbon connectors for the vertical picture.
    Be carful not to brake them.
    Look for any that may not be fully connected.
    My one looked like they were all connected but actually the last one was a out just a little.
    Try pulling them all out and reconnecting them.
    Worked for me.
    Good luck
    Posted on Jan 25, 2013
    Ps3 right side of the screen is completely black
    the PS3 is not putting out the right signal, consult the manuel, there is a switch to make it 1080
    Feb 23, 2014 | Panasonic STAND PN: TY-ST42PA20
    4 narrow bright stripes down left side of screen
    reset the projector,if it doesnt help,its probly got to do with ur dlp colour wheel.
    Jul 03, 2010 | Optoma EP739 Multimedia Projector
    I have a toshiba 22 inch hd tv, when i go on my ps3 at the start screen there is a thin green line (or different colour line depending on the colour of my theme) down the right hand side of the screen. Any...
    Would like to tell you that there is nothing wrong with your PS3, but it's the T.V that is causing the problem.
    Unfortuntely, the only thing that will cause a thin line or two is the lcd panel assembly. The cost to replace this would be really high so the best you can do is put up with it as long as you can, then replace the set.
    Apologies on the bad news but i must be honest with you. I have seen this with all makes of both lcd and plasma tv's
    Mar 19, 2010 | Video Game Consoles & Games
    Sreen is black
    It's probably a problem with the connection of the PS to your tv. If the connection setup is right, and you still get no sound or colour, connect the PS3 to the TV using the standard-def A/V cable provided in the packaging and press and hold on the power button for about 3 seconds when you start up the console. After that, you can change the display settings to an HD connection and connect the PS3 to the tv using an HD cable. (That is if you want it in HD)
    Dec 14, 2008 | Sony Playstation 3 (PS3) Console
    Grey cable in dash
    Hi again,
    Appreciate the update and additional information. If I understand it right, your vehicle then has two connectors at the back: 1 big black/red/gray plug:
    • Yellow/light Green - always ON B+12;
    • Yellow/Black stripe - ACC B+12 goes to the IGN switch;
    • Black - chassis/ground;
    • Blue - remote trigger for add-on amplifier (if connected);
    • Blue/Red stripe - illumination (can go to parklight switch).
    and the 2nd smaller gray 8pin plug:
    • White/Red Stripe Right Front +
    • Brown right front -
    • Green Left Front +
    • White/Orange Stripe Left Front -
    • Light Blue/Black Stripe Left Rear +
    • Yellow Left Rear -
    • White/Blue Stripe Right Rear +
    • Light Blue Right Rear -
    Cheers.
    Aug 28, 2008 | 1994 Ford Explorer Limited
    Verticle lines
    You should connect your TV to an Active DtH Connection or a Live TV Cable or even to a working DVD/VCD Player etc. and tune it to the frequency of the same and it should start working. If it doesn't, please contact Service Center.
    Jun 18, 2008 | LG RU-42PX11 42 in. EDTV-Ready Plasma...
    Hitachi 42EDT41 plasma model-1" black stripe on right side
    This is an old post but maybe it will help others. You will have to take the back off of the TV. On the bottom you will see ribbon cables coming from the screen and connecting to 3 PC boards. Take the screws out that holds the cable down. Underneath you will see 4 resistors marked 100. All you have to do is re-solder the resistors and your vertical line will be gone. You need to be good at soldering or you could damage the ribbon. The only ones that you have to re-solder is the ones in line with the lines on the screen.
    Jun 06, 2008 | Hitachi 42EDT41 42 in. HD-Ready Plasma...
    Hdmi leads
    Well did you try the 3 coloured plugs thats connected to the PS3 the problem with the PS3 is that the 3 coloured plug is abit heavy so it goes down you mite want to adjust the plug so that it doesn't make the screen turn black or w/e.
    Your Welcome
    I tried my best.
    Rate my Solution.
    Apr 29, 2008 | Sony Playstation 3 (PS3) Console
    Washed out colours and thin red lines across the screen
    your problem is in red video circuit. please get it done with skilled tech.
    Oct 05, 2007 | Panasonic CT-32SL15 32" TV
    Hyundai 42inch plasma tv
    If these are thick black lines, this is most likely line frequency noise entering the set. you may have a leakage from the DC ground on the secondary side of the powersupply to the AC side, or a bad filter capacitor(s). Most of the time it is the filter caps that give these types of problems. If you are connected to cable TV service, or an outside antenna you can also have this problem from an AC ground loop return. Also if there is a device such as a VCR connected to the TV and it has problems, it can cause this as well...
    Mar 20, 2006 | Hyundai ImageQuest DPD4210 42 in. HD-Ready...
    Televison & Video Logo
    27 people viewed this question
    Top Televison & Video Experts
