Question about AudioBahn Car Audio & Video
I need replacement part for my a2300hct. The fuse melted the whole thing
I have a audiobahn a2300hct and the block where the wiring hooks up on the outside is melted around where the ground wire goes in. Where can i get parts or an old 1 for sale i can use for parts?
There are several facebook pages. Old school stereo for sale, i was into auto sound in the 80s and 90s, legends of car audio. Otherwise watch for one to come up on ebay.
Aug 26, 2016 | AudioBahn Car Audio & Video
I have put in new fuel pump for 1996 tahoe but, when i was about to connect the harness plug to fuel pump and noticed the plug was melted. So question is can i replace just the plug end or do i need to...
Just replacing the plug or terminal will be enough. Make sure to tighten the replacement very well. Loose contacts create high electrical resistance heating the plug or terminal. High temperature creates even more resistance heating even more the plug or terminal. This is the reason why it melts. Good luck.
Nov 13, 2013 | 1996 Chevrolet Tahoe
Changed spark plugs AND HAD TO TAKE OFF THE ALTERNATOR TO GET TO BACK set of plugs. when replacing alternator hot wire touched the alternator casing and it arced, now car wont start
You melted a fusible link. These are on the starter solenoid, attached to the big terminal that has the battery cable on it. There should be maybe two or three of them. You can recognize them by what look like plastic barrels between the meltable portion and the hard wire. Grab each one individually and pull. If it stretches, it's melted. Sometimes there is enough left to put a **** splice in line, or maybe have to replace the whole thing. I think you can get these at your auto parts store. Take the barrel portion with you as the amperage rating should be molded into this part.
Aug 17, 2011 | 1991 Chevrolet Corsica
A2300HCT Car Audio Amplifier: i have a audiobahn a 2300 hct amp and it has stopp...
Well, sounds like you have an internal damage since it smokes, if it smokes as soon as it kicks on, and blowing the fuse right away, I would have it fixed. But my guess would be something with the ground that is making this happen, or some how your power is grounding on the amp. When ever smoke comes into play, thats never good any way at this point you gotta admitt that thiers internal damage.. blowing fuses can also be cause by over working your amp. along with the sub load at 1 ohm make sure your amp can do the same.. hope this was helpful in some way
May 16, 2010 | AudioBahn A2300HCT Car Audio Amplifier
POWER TERMINAL MELTED
MOST TIMES THAT A POWER TERMINAL MELTS, YOU WILL FIND THAT THE POWER CONNECTION WAS LOOSE AND AT HIGH CURRENT LEVELS, IT WILL ARC AND HEAT UP ENOUGH TO CAUSE IT TO EITHER MELT THE HOUSING AND DISCOLOR THE METAL OR SOMETIMES GET SO HOT THAT THE SOLDER CONNECTING THE CONNECTOR TO THE PC BOARD WILL GET HOT ENOUGH TO MELT AND BURN FROM THERE. IF IT IS DAMAGED ENOUGH AND YOU CANNOT MAKE A NEW CONNECTION, YOU WILL HAVE TO HAVE IT SERVICED AND SIMPLY PAY GREAT ATTENTION TO THE TORQUE OF THE SCREWS TO INSURE THAT YOU HAVE A GOOD CONNECTION. AFTER IT IS TORQUED DOWN, YOU SHOULD BE ABLE TO PULL QUITE HARD ON THE WIRE WITHOUT DISLODGING IT FROM THE CONNECTOR. IF YOU DISLODGE IT FROM THE CONNECTOR WHEN PULLING QUITE HARD ON IT, THEN IT WAS NOT TIGHT ENOUGH. LET ME KNOW IF YOU NEED FURTHER ASSISTANCE....V
Nov 19, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Rca plug-in on amp came off,try to get the schematics to fix so i
just replace the whole rca unit there should not be any wires it is a plug with little pronges on the bottom
Jun 15, 2009 | AudioBahn A2300HCT Car Audio Amplifier
Red status light on no power goes to my subs
no but u only need one. it needs to be no more than 10 inches from the positive battery terminal.
Apr 20, 2008 | AudioBahn A2300HCT Car Audio Amplifier
Wierd stopped working audiobahn a2300hct
Disconnect all speaker wires from the speaker terminals of the amp and disconnect signal cables from the amp. If it powers up normally, the wiring and speakers need to be checked. If it still shuts down, the amp likely has blown output transistors.
Apr 05, 2008 | AudioBahn A2300HCT Car Audio Amplifier
A2300hct no aound
are there power to the output transistors?
Aug 06, 2007 | AudioBahn A2300HCT Car Audio Amplifier
Car Audio & Video Logo
43 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
