Question about Radio Communications
End pullled off wire need pin out. I assume w-12v-, red-12+,& yellow with shield could use small coax
  • 160 Answers
SOURCE: Microphone wires are broken at connector.
what kind of mic m6b, devil, turner, black and silver eagle
Posted on Jul 08, 2008
SOURCE: Astatic 636l microphone Cobra 29ltd classic
pin 1= sh & bl
pin 2= wh
pin 3= red
pin 4= blk
yellow = not used or put on pin 4
Posted on Dec 18, 2008
  • 14 Answers
SOURCE: DEH-P80MP need wiring/color description
http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/103539332INSTALLATION%20MANUAL%20DEH-P80MP.pdf
Installation guide for your model with wiring diagram.
Hope this helps.
Posted on Dec 25, 2008
alicantecoli
  • 22326 Answers
SOURCE: Why is not there a VW Polo 6N listed?
if warning light control not working change the altenator
Posted on Feb 22, 2009
  • 6 Answers
SOURCE: wiring is broke on 4 pin mike plug
This is the wiring for a stock mic ... if it is a different one let me know
Mic Wiring
Stock
1- Shield
2- Audio
3- Transmit
4- Receive
Posted on Apr 07, 2009
2 WIRES FOR 12V SUPPLY. PIN NOs 2 WIRES for Signal PIN Nos. ??
How PC Fans Work - PCB Heaven
pcbheaven.com/wikipages/How_PC_Fans_Work/
Mar 29, 2010 - The connector of a 2-wire fan has a red and a black cable. ... The firsttwo wires are the power supply of the fan. ... This fan is designed to be controlled with a PWM signal and .... I have a four-wire (red black yellow blue) 12v fan out of an old .... My case has a number of 2 pin outputs for multiple case fans, ...
Motherboard Power Connectors ' PC Repair and ... - InformIT
www.informit.com > Articles > Hardware
InformITFeb 28, 2003 - Table 3.3 ATX Main Power Supply Connector Pinout (Wire Side View) .... The auxiliary connector has no +12v leads at all, so that is no help. Pulling up to ...Pin. Signal. Color. Yellow. +12V. 3. 1. Gnd. Black. Yellow. +12V. 4. 2.
ATX 24 pin power supply connector pinout diagram ...
pinouts.ru/Power/atx_v2_pinout.shtml
Rating: 52/60 - ‎60 votes
Jan 28, 2014 - Pinout of ATX (ATX12V) 24 pin power supply connector and layout of ... and later (ATX12V 2) is common ATX standard, 24 pin connector. ... Power Ok is a status signal generated by the power supply to notify ... 10, 12V, Yellow, +12 VDC ... 18 AWG is recommended for all wires except pin 11, which should ...
ATX power supply connector pinout diagram @ pino
Dec 16, 2015 | Cars & Trucks
I just want to know on my cm 918t that i got this right the wht and yello wires have a center and a sheild yes and thx
Black negative/ground,
Red +12V,
White shielded =Audio out, centre white to centre pin of Rca plug shield to outer rca,
Yellow Shielded = video out centre yellow to centre pin of Rca plug shield to outer plug.
I have no idea what your question is but hope that's what you wanted to know
Jun 22, 2014 | Cars & Trucks
2000 KIA SPORTAGE STEREO WIRING DIAGRAM
You can use the attached diagram for assistance, but here goes:
1. Blue/Yellow (Pin 1) - Illumination (+12V) (when headlights on)
2. Black/Yellow (Pin 1) - Main Power (+12V)
3. Light Green/Black (Pin 2) - Memory Power (+12v)
4. Black (Pin 11) - Ground
5. Blue/Red (Pin 9) - Left Front Spkr Return (-)
6. Green (Pin 19) - Left Front Spkr Signal (+)
7. Brown (Pin 10) - Right Front Spkr Return (-)
8. Light Green/Yellow (Pin 20) - Right Front Spkr Signal (+)
9. Blue/Orange (Pin 7) - Left Rear Spkr Return (-)
10. Green/Yellow (Pin 17) - Left Rear Spkr Signal (+)
11. Green/Red (Pin 8) - Right Rear Spkr Return (-)
(Note here that the wire color at the rear speaker is
Green/Blue - not sure if this is a misprint (see diagram))
12. Yellow (Pin 18) - Right Rear Spkr Signal (+)
Nov 10, 2013 | Vehicle Parts & Accessories
I trying to connect my SFC-4160 (security first color ccd camera) the wiring has been cut n there is 5 wires black,red,yellow,white and a bare wire ???? help
Inside the camera is a 4 pin connector connected to the LED Board, with the connector in hand, turn it till you see the pins inside the connector, from left to right wires 1st-white, 2nd-black, 3rd- bare wire or shield, 4th-red, yellow is not connected, the RJ45 end, face the latch away from you, wires are 1st-red, 2nd-white, 3rd-yellow, 4th-shield(bare wire), 5th-black, the LED Board has the wire positioning marked,,,,,
Nov 27, 2012 | Car Audio & Video
Need pin outs for eagle cuda 168
Coda has flat D 6 pin with center pin grd for 4 wire vs old arrow 6 pin round black one. Flat on bottom, count cw 12345 pins w pin 6 center... 2 pin minus 12 v, 4 pin +12v. For other 4 wire like speed/temp... 1 blue, 3(top) white, 5 pin bot right yellow, 6 center ground for spd/temp. White for speed wheel, rest not known. I used 2wire cable and 4wire cable with 2ft pigtails and 3amp fuse in red wire. I used old radio stereo 2 and 4 pin male female connectors at end of pigtails.
Nov 06, 2012 | Eagle Cuda 242 Fishfinder
I have a general lee cb with a 4-pin standard mic. the wires in my mic cord broke at the plug. does wnyone know how to wire this type of mic back and what color wires go to the correct pin?there are 6...
Here are the Pin outs for different mics that will work with your radio. If a wire is not listed then you cut it off. It's best to keep the wires as short as possible no longer than a half inch is suggested. Normally the Cobra pin out is standard for most radios.
Stock - 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - (4 wire) 1- Shield 2- White 3- Red 4- Black
Astatic - (6 wire) 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500, Cobra, CA Series - 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - (4 wire) 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI - 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta - 1- Shield 2- White 3- Brown 4- Green
Turner - 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Jul 12, 2011 | Magnum DeltaForce CB Radio
I need the wiring for the mic
Here is the wire diagram for several common mics in relation to a 4 pin CB. Most recent 4 pin CB's such as Midland, Cobra, Connex, Uniden, etc can use 4 pin mics. The wiring is actually depending on the mic rather than the CB so long as the CB's are 4 pin as well. Once you go back to late 80's the 4 pin design was a little different. Anything new it is simpler.
Stock Mic 1- Shield (Ground) 2- Yellow (Audio) 3- Red (Transmit) 4- White (Receive)
Astatic - 4 wire 1- Shield 2- White 3- Red 4- Black
static - 6 wire 1- Shield & Blue 2- White 3- Red 4- Black Yellow NC
Daiwa EM-500 Cobra CA Series 1- Shield & Black 2- Red 3- White 4- Blue
Galaxy DC-521S - 4 wire 1- Shield 2- Yellow 3- Red 4- Black
Galaxy CB-660EI 1- Shield & Black 2- White 3- Red 4- Blue
Sadelta 1- Shield 2- White 3- Brown 4- Green
Turner RK56 Road King 1- Shield & Red 2- White 3- Blue 4- Black Yellow NC
Regards, Tony
Apr 07, 2011 | Connex Radio Communications
Audio Technica PRO-35: need wiring diagram for mic end
If you feel the shield goes to the middle, try red on one terminal and white on the other. If not, reverse it.
If it's labeled on the circuit board...pin 1, pin 2, pin 3, then pin 1 is usually ground, pin 2 is hot (red), and pin 3 is cold.
Mar 31, 2010 | Audio Technica Audio-Technica AT2020...
Trying to hook up cable to a raytheon r10 radar scanner.Needs wiring diagram to show where each wire goes.
Large Blk and Large Wht goes to 2a
Large Red goes to 1a
Grn goes to 1b
Blu goes to Bz
Coax goes to Vd
Wht (shielded) goes to Gs
yel goes to 33
Red Shielded goes to Bp
Brn (small) goes to pl
black shielded goes to tI
Large brown not used tape end fold back and secure to harness.
Apr 19, 2009 | GPS
Radio Communications Logo
71 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Are you a Radio Communication Expert? Answer questions, earn points and help others
