Network problem, tv says IP address duplicated.
Sorted.
micromaster
  • 3614 Answers
SOURCE: 3com 3102 not working
try 192.168.2.1 / 192.168.2.0 / 192.168.0.1
hope it works.
enjoy
Posted on Feb 15, 2008
Muggs01
  • 71 Answers
SOURCE: Just moved IBM 6400 dot matrix. Need new IP address.
it should have kept the same address
Posted on Jan 19, 2009
efs_perpends
  • 1996 Answers
SOURCE: IP address to connect HP2035N on the network
Here's a good tutorial that may help...
See this MS article, though you don't mention whether xp or vista....(see here for vista)
See here. and here for HP info.
For more info on TCP/IP see here and here.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 30, 2009
Testimonial: "Many thanks for your help. You fixed my problem!"
SOURCE: DSi says that duplicate IP addresses exist and to
I got this same error using a Linksys WRT54GS.
On the basic setup page, under Network Setup>Network Address
Capture(lefemenu.dhcpserverset)Server Settings (DHCP), I changed the Starting IP Address from 192.168.1.100 to 192.168.1.110 and amazingly it worked.
Posted on Sep 20, 2009
SOURCE: acquiring network address
Make sure that you have not connect the ethernet cable to routers Internet port.
Posted on Oct 19, 2009
Ip address where can i find my tv ip address
Are you sure your TV has an IP address? Not all TVs are networkable.
Like most devices, most TVs expect to be given an IP address when they connect to the network through a process called DHCP. You can probably change that in settings.
If your TV is IP-enabled, you should be able to find the network section of the menu, and find the IP address there. If you decide to manually set the IP address, be careful, because only certain IP addresses will work on your network.
Aug 16, 2015 | Computers & Internet
IP address for element electronics model No:ELDFW374
That appears to be a TV model number - there will be no IP address ever - it is not a network device.
Nov 10, 2014 | Computers & Internet
Find my IP address
To have an IP address, your TV must be connected to a home network or the internet...Is your TV a internet-enabled TV?Then there are three ways..
a) On the TV, go to network settings
b) From your router, check the DHCP table of the clients, if your TV is connected to your network, its IP should be listed.
c) Visit IP-details.com and get the IP.
Feb 02, 2014 | LG 37LH3000 37" HDTV LCD TV
Find IP address
Ip address duplicated
IP address is duplicated using proxy (or) Hide IP software. To check the Network IP address, visit Ip-details.com .
Apr 14, 2013 | Arris SURFboard Gateway SBG6580 DOCSIS 3.0...
How do i manually configure and ip address for the mitel 5224 ip phone?
Press and hold the up arrow.
Configure Phone - Yes
network parameters - yes
press no until you see "change" and press yes.
You will need to set the following appropriately.
IP address, Subnet address, default gateway, ICP controller address, TFTP address, VLAN ID, VLAN priority, DiffServe Value, DNS address.
Normally it is not necessary to set the phone static except for testing. If your network and DHCP server is set up properly, you are not gaining any benefit for setting it static.
Also, you should find out what the other IP addressess are that are static on the Voice subnet. Along with that, you will need to know the DHCP range. These are needed so you don't assign a duplicate IP address to your network. Assign the phone to the wrong device could do great harm to your network. Assign it to use the same IP address as the phone system and none of your phones will operate.
Use with caution,
Mark
Feb 10, 2011 | Mitel 5224 IP Phone
Internet not connecting
Update the drivers for the network adapters. You may also run recovery cd if you have for those computers.
Sep 09, 2009 | Microsoft Windows XP Professional SP2 for...
DSi says that duplicate IP addresses exist and to check my DHCP settings
Jul 27, 2009 | Nintendo DSi Blue Console
I cant open an ip address for an assigned webpage.
There are several private address ranges that may be affecting the operations you are attempting to perform see table
IP Address Ranges Reserved for Private Use
Class Networks A 10.0.0.0 through 10.255.255.255 B 172.16.0.0 through 172.31.0.0 C 192.168.0.0 through 192.168.255.0
All addresses in this range in your network are only directly addressable to machines within your network at most by default. The router to your ISP and the internet as a whole maps these addresses onto the IP address assigned statically or dynamically by your ISP to the WAN side of your router using an address translation (NAT) service. So where you are attempting to connect to this device from may be significant. You may need to review your setup guide to see if it references router configuration requirements to support access to the Web_xpander port from devices not attached to your internal network. If you have multiple internal networks (address ranges and not devices) this could also be an issue.
Secondly -- does the Setup software for the device tell you the IP address assuming it is dynamically assigned. Otherwise how would you know what the address is. Static assignment could resolve that issue however you must understand your network to assign your own address. Given a theoretical network where the router gateway is 192.169.0.1 and the network mask is 255.255.255.0 the valid network addresses are 192.168.1.0 - 192.168.1.255. A router or other device supporting DHCP address assignment reserves another range such as 192.168.0.100 for 50 leases (ending at 192.168.0.149) for dynamic assignment to requesting network adapters. Ignoring the 0 and 255 address this leaves open to the network administrator (you in your home) the possibility of assigning static IP address in the ranges of say 192.168.0.2 - 192.168.0.99 and 192.168.0.150 - 192.168.0.254 or so. You as well as the DHCP server are required to assure that there are no duplicate IP addresses assigned on your network. So statically assigning 192.168.0.100 (which is DHCP assignable in our case) could and would most likely result in duplicate addressing and network problems.
Dec 08, 2007 | Computers & Internet
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
