Question about Maytag Dryers
My maytag epic z (medz600wr) dryer start button has broken and fell out. Can it be started without it?
  • 4 Answers
SOURCE: maytag gas dryer
This is valid for a Maytag Neptune MDG3000AWW Gas Dryer (I am responding to a problem which was mis-identified as a MDG5500AW Gas Dryer)
NOTE: Motor problems begin intermittantly. They can be temporarilly fixed by blowing out the motor with compressed air. Eventually ALL motors fail. In my case, with six kids it took 10 years for our Maytag motor to fail. YMMV.
  1. Confirm where the burn smell is coming from. This will require you to disassemble the dryer. This is not hard - it will require the following tools:
    crosstip medium screwdriver
    1/4 inch socket
    5/15 inch socket
  2. UNPLUG DRYER
  3. TURN OFF GAS
  4. Disassemble by taking apart the FRONT of the dryer:
    a. Remove the door and opposite side door plugs (crosstip screws)
    b. Remove the front panel - this exposes sheet metal bolts (5/16 inch) some with crosstip on left and right of unit. Set panel aside (right side) WITHOUT unplugging wires
    c. Unscrew all the exposed bolts.
    d. Top bolts left and right secure the unpainted metal hooks which secures the top of dryer. Unscrew these bolts and wiggle the metal retainer hooks off. Lift top and support to create 6 inch gap in the front (top unit hinges in back and has electrical connections - do NOT disconnect wires)
    e. Release belt from pulley by reaching left and under drum (this is out of sight)
    f. gently lift out drum and belt and set aside
  5. This has exposed the interior.
  6. IF your motor still made sounds when pressing the start button, THEN plug the dryer back in and have an assistant press and hold the start button. You press the dryer close door button (on front panel which you set aside) and observe and listen. IF the glow plug in the gas ignition chamber glows bright, it is fine. You may see a slight curl of smoke or smell some smoke from the glow plug. THIS IS NORMAL and indicates your ignition circuit is fine.
    Observe the motor. Listen and smell. IF you see smoke from the motor, or IF you hear a "starting sound" but the motor itself doesn't spin, is very slow to start spinning, or makes racket, or it made a noise and then stopped... THEN your motor is burned out. Confirm by sniffing the motor. IF the motor smells burned, THEN your motor is burned out.
  7. IF you determined your motor has burned out, THEN you can replace the motor for around $100. OR you can replace your dryer for > $700. Your choice. It is slightly tricky getting the motor out. Instructions Below.
    NOTE: If your motor is burned out it CANNOT be fixed because it is a "double wound motor." The motor must be replaced.
MOTOR REMOVAL INSTRUCTIONS
  1. UNPLUG DRYER
  2. TURN OFF GAS
  3. Expose the dryer interior by following instructions above
  4. With the drum out do the following:
  5. Remove the blower cover by unscrewing the 8 screws
  6. Remove the cotter clip securing the front of the blower to the motor spindle (Try using two screwdrivers... You'll need to replace this cotter clip because it will deform)
  7. Remove the wiring harness on the back of the motor
  8. Remove the two motor securing clips holding the motor to the motor support frame (this is tricky - I got them off by leaning on the top of the clip with a heavy screwdriver and a large channel-loc wrench)
  9. Remove the cotter clip between the motor and the blower housing
  10. Remove the two 5/16 inch bolts securing the motor support frame from the motor
  11. Lift out the motor and blower housing
  12. Have an assistant support the plastic blower barrel tines with the motor hanging down and the blower up
  13. Using a hammer and a punch tap the motor spindle (axel) until the blower is free of the motor
  14. Take this motor to your appliance repair center for replacement.
To replace simply reverse these instructions. GOOD LUCK!
Posted on Nov 01, 2008
  • 409 Answers
SOURCE: Maytag Epic dryer won't start
hi there,
if it beeps it means that the keypad is sending a signal to the control board to start it but it doesn't. since the control board sends a signal to the motor to start the dryer to spin. does the dryer hum?
Posted on Dec 17, 2008
iwillfixforu
  • 619 Answers
SOURCE: I have a Maytag Epic Z. The dryer turns on but with no heat
There are several things that can cause this. 1 st the thermal fuse(white plastic piece with 2 wires attached to it, then the igniter, is it glowing orange when you start the dryer, then the flame sensor located on the side of the burner assembly and finally the gas coils located on the gas valve close to the burner assembly. If the igniter is glowing orange and then going out without ignition change the gas coils, Hope this helps,
Posted on Feb 05, 2010
cool78259
  • 228 Answers
SOURCE: Maytag DE303 Dryer
first check and make sure the power breaker is on. next the door when it closes there is a safety switch normaly there is a small hole around the frame of the door. when you push on it, you shoud hear a clicking noise. if you don"t, that switch will prevent the tumbler from turning another thing is the belt that goes around the tumbler if it's loose or broken the tumbler will not turn. that can be checked by accessing the bottom panel in the back the belt should be tight. good luck!
Posted on Jul 25, 2010
  • 110 Answers
SOURCE: how to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
Posted on Apr 17, 2012
Control board sparks, smokes and smells when trying to start
Did you have a lightning strike near by? Or power outage with a power surge. Could have shorted the board.
Mar 13, 2015 | Maytag Epic MGD9700S 27 7.3 cuft. Gas...
Maytag epic z power button wont start machine
Maytag dryer. has no start check door switch. if not door switch then its your relay board that may be bad also check all stats.
there will be 2 at blower cage and 2 on heater assembly
The 2 on blower cage one of these are a resister stat has to be exact resistance or dryer wont start or will start and then shut off dryer b4 it is completed drying hope this helps there should be a cheat sheet paper work that will help you diagnose your problem fallow the steps if not with dryer can be viewed online
Jun 25, 2014 | Maytag EPIC MFW9700S Front Load Washer
Maytag Epic Dryer Model MED9700SQ0, everything lights up, power is on, but drum will not turn and no heat.
Can you tell if the motor comes on? If it does, then it could be a broken belt.
Sep 01, 2012 | Dryers
When pressing start button it does nothing anymore,any help or suggestions?? it worked up till now..
Check and make sure the door button has not broken and fell out. If you see the button sticking out mash it several time hold it in then mash the button. If it is electronic it's probally in the board.
Feb 16, 2011 | Maytag PYE2300AY Electric Dryer
Feb 04, 2010 | Maytag EPICz Electric Dryer
hi there,
Dec 17, 2008 | Maytag EPICz 6.7 Cu. Ft. 8-Cycle King-Size...
Dryers Logo
97 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
