I need the instructions for creative roots snow globes
Airblown snow globe instructions
"snow" is small styrofoam pellets that get sucked into the blower on the bottom..there is a sort of recycleable drain in the base that allows the pellets to be reblown over and over..HOWEVER if the unit gets wet, the pellets stick together and will not go through until dried dry.. use a hot air blowdryer to heat the material carefully it is nylon.. it can melt...then the pellets and drain may need unplugged..(unstuck)
Dec 15, 2013 | Cars & Trucks
I bought a snow globe and I can't get it to charge nor turn on. My pc won't even recognize it. What is the deal and do I just need to send it back? It is a Unison Digi-Snowglobe with DPFMate...
I also have this same snow globe bought it in Pigeon Forge, TN this I decided to pull it out and use it and guess what?? It wont come on and my computer doesnt reckognize it either...Did you ever get yours working?? If so how?? Thanks
Dec 18, 2012 | Sakar Cameras
My 6 foot inflatable snow globe won't blow the snow inside,the fans and motor are working just fine it just wont blow the snow it just sits in the bottom...
Maybe the problem is condensation. The globe gets all fogged up and the snow pellets start sticking to the plastic and it just looks like a mess. Temperature might be less of a concern where you are, but it is something to consider. I had briefly thought of putting something like a hair dryer in line with the main fan to keep the inside temperature up. But it turned out to be more of a problem than I wanted to deal with. Good luck though!
Dec 20, 2010 | Gemmy Inflatable Polar Bear on Motorcycle
The glass that holds the water and snow has broken,can this be repaired
If you have all the pieces, it can be repaired. the tricky part is getting it refilled and sealed. If the globe is glass, you can use any cyanoacrylate glue (crazy or super). If it is synthetic, it is important to get an adhesive that is compatible with the material of the globe.
Oct 11, 2010 | Globe AUBURN TIGERS MUSICAL GLOBE -...
Mac OS 10.6 Snow Leopard: Printer Driver Update for Xerox Phaser 6110 does not work ! Xerox/Apple is providing a most complicated instruction to circumvent the problem that I am not able to...
    1) Change the “Xerox” Folder Permissions:
    • Navigate to Applications > Utilities and open a Terminal window.
      • Type the following command: sudo chown -R root:admin /Library/Printers/Xerox
    • You will be prompted to enter your password.
    2) Install Rosetta from the Snow Leopard DVD:
    • Insert the Snow Leopard Install DVD
      • Select Optional Package
      • Select “Rosetta only” from the list of optional packages
      • Click install and follow instructions to complete installation; there is no need to reboot
    3) Reset Printing System:
      • Navigate to: System Preferences> Print & Fax> Xerox Phaser [6100, 6110, 6110MFP]
      • Right click on the printer
      • Select Reset Printing System
    4) Install Printer (without removing the driver):
      • Select +: add the available Xerox printer
Mar 18, 2010 | Xerox Phaser 6110 Laser Printer
My gemmy inflatable snowglobes ( 2) are not blowing snow this year. The fans work fine- the globes inflate- but the snow just sits in the bottom of the globe. If I shake the globes the snow works for a few...
I am having the same problem the globe is inflated and the characters are rotating but no snow its all bunched up on the bottom and doesnt blow all the way up if you get an answer from gemmy its a miracle. if you solve it please contact me at thanks.
Dec 12, 2009 | Gemmy Toys
How do you fix a broken snow globe fan?
look closely at the fan blade, it probably got a little bent and is rubbing. You can bend it a bit and free it.
Sep 27, 2009 | Kitchen Appliances - Others
I have a disney snow globe that has a rusted music box and the fluid is low in the glode. How should it be repaired?
i hope my advice will help you. What I would do is the first thing is take it to a ceremic workshop they have all clock parts music box parts phone parts as when people make these they sell them the parts and show them how to put them in if that dosent work or you are not near a ceremic workshop try a clock or a watch maker they will take a look and might be able to repair it. If not I would then go out look for a music box find the company that made it or the company that makes snow globes just type it into google manafactures of snow globes or who makes snow globes and send it off to them but call them first and ask them if they could fix it for you they will usually say yes either drop it into the repairs area or send it to them but you will have to call first.
Hope that helps
Aug 07, 2009 | Disney Princesses Beauty and the Beast...
Once you have the box connected with the usb cable to the computer, you have to tilt it towards connect to pc. You might have to do this a couple of times the picture on the display should change to a usb cable. Now if you go to my computer you will see where it says pan digital. Here is where you can add the pictures. I just did add pictures. If you want the pictures in a certain order you will have to name them otherwise there are displayed in alphabetical order. I found this after I loaded everything and wanted them in a specific order. Right now I am trying to add sound. I see that there is a speaker but not sure how to add sound.
Feb 07, 2009 | PANDIGITAL PAN 70-0 7.0" LCD Digital...
32 people viewed this question
