How much water does the tub clean function use? My washer seems to constantly fill while draining water.
the dr
  • 447 Answers
SOURCE: Clean light flashing
The clean light should be blinking 7 times, pause, then repaeat if it is doing this -- it is a water heating fault. Use one of the following key dances to clear fault
a) Heat Dry - Normal - Heat Dry - Normal
b)High Temp-Air Dry-High Temp-Air Dry
All the Leds should light up now just press cancel and Unit should operate. If it shuts down again the heater isnt working properly. Some times the door doesnt get shut well and that causes the fault. But the dishes arent very clean if the heater is not working.
Posted on Oct 16, 2007
  • 4088 Answers
SOURCE: When tub filling, it drains out at the same time.
The outlet of the drain hose must be higher than the water level inside the tub--normally the pump inside removes the water when needed. Get a plumber to install a proper height drain pipe for you.
Posted on Jul 16, 2009
beltronic205
  • 1474 Answers
SOURCE: GE Washer Wont Fill
Make sure drain hose not too low , creating syphon...
Posted on Jun 01, 2010
Testimonial: "After posting this question I saw something on the internet suggesting the same. I think this must have been the problem. Thanks for your help!"
Macmarkus
  • 2605 Answers
SOURCE: my washer tub will not
Hello, Welcome to FixYa.
Here`s what I find is most common when dealing with the symptom you`ve described.
I'd suspect the drain hose is lying down on the floor or is pushed down into the stand-pipe too far.
If the drain hose is below the water level entering the washer it will siphon out immediately. The drain hose must be above the highest point the washer has to fill, ( refer to your manual, but it is typically recommended to be about "48 to "60 in height )
Also if it is in a stand pipe insure it isn't pushed in too far, just a few inches and then secure it without completely covering over the opening or that too will cause it to siphon.
Check your drain hose. Let me know if this was indeed the case and if so please rate the solution accordingly. If not we can move forward from there.
Thank's for coming to FixYa and good luck.
Regards,
Macmarkus :)
Posted on Sep 28, 2010
  • 44 Answers
SOURCE: my general electirc washer model
I had a similar problem ... mine was related to a hole in the pressure switch hose (code E22). Inside the washer, there is a pressure switch that senses how full the tub is. It does so using air pressure at the bottom of the tub -- air hose gets "pushed on" by the filling water and causes a pressure spike the switch. If you develop a leak in the air hose, the pressure switch never gets exhausted. There is a safety feature that engages if the water runs for more that 8 minutes without the pressure switch engaging. E22 is one of the codes related to this event. Easy way to see if this is an issue is to run a diagnostic test.
Check out this posting for how to do so: http://www.fixya.com/support/t9576766-found_small_part
Test T02 will show you the most recently encountered codes. At the bottom of that posting is a link to the code definitions with problem resolutions: http://www.fixya.com/support/t9556917-ge_model_wcvh6800j_error_code_04
If you do find a pressure switch related code, here's how to fix it: http://www.fixya.com/support/t9807344-ge_front_load_washer_stops_45_min_35_min
Posted on Jul 28, 2011
I have a D3432 and had a blocked pipe that kept the motor running. I opened the toe kick and drained the water from the bottom tray which seemed to have solved the motor issue but after running the machine...
Well, there are a couple of places where washers can leak.
  • There are a couple of hoses underneath: from the tub to the water pump, and from the water pump to the drain connector.
  • The fill sensor switch has a length of small diameter tubing that connects to the outer tub.
  • The tub itself could rust through (as it did when my 1984 washer was about 22 years old)
  • The seal or bearing where the motor shaft goes through the outer tub could have failed.
You will have to take the back cover off and run a cycle to identify the site of the leak.
Nov 25, 2014 | Washing Machines
Tip
Winterizing a Washing Machine
If you keep your washer in area where you need to winterize for the winter (unheated garage or unoccupied vacation home), the following steps may provide you with some helpful guidance in preparing before extreme temperatures occur and possibly leave you with damaged plumbing and/or a ruined appliance.<br /> <br /> <b><u>TOP LOADERS</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub, and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. STOP or CANCEL the timer on the washer and UNPLUG.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. Clean the detergent dispenser and fabric softener dispenser and ensure they are dry.<br /> <br /> 8. Store washer, unplugged in an upright position.<br /> <br /> <br /> <b><u>FRONT LOADER</u></b>:<br /> <br /> 1. Turn off the main water supply to both water taps.<br /> <br /> 2. Remove the fill hoses, drain them of all water and reinstall them - leave water supply turned OFF.<br /> <br /> 3. Add 1 gallon of Recreational Vehicle (RV) antifreeze (non-toxic) to an empty wash tub.<br /> <br /> 4. Select the DRAIN/SPIN function on the timer and allow the washer to run for one minute to drain the antifreeze from the wash tub and any water remaining in the drain pump or drain lines. <br /> <br /> NOTE: Not all the antifreeze will drain. A small amount will remain in the drain pump and line (this is normal).<br /> <br /> 5. Press PAUSE/CANCEL twice to halt the cycle and UNPLUG the appliance.<br /> <br /> 6. Wipe down and dry the wash tub.<br /> <br /> 7. IMPORTANT: Check the perimeter of the door bellow (gray rubber seal) and make sure no small articles of clothing are left in the rubber folds. Clean this area thoroughly and dry. NOTE: Anything left behind will mildew over a period of time causing foul odors.<br /> <br /> 8. Clean the detergent dispenser drawer of any remaining water or fabric softener residue.<br /> <br /> 9. Store washer, unplugged in an upright position.<br /> <br /> <b><i><u>Secondary Method</u></i></b>: <br /> <br /> If you cannot find RV antifreeze (or prefer not to use it), another method of draining the washer is to remove the drain hose from the standpipe at the wall and pull a vacuum on the line with a wet/dry shop vac. This will pull any remaining water from the drain pump and lines. <br /> <br /> If a shop vac is not available, lowering the drain hose from the standpipe to the floor will allow it to drain using simple gravity. <u>IMPORTANT</u>: On a front loader, you may have to remove the drain line from the drain pump to drain the pump. Or, use the access cover (if equipped). Most front loader pumps are accessed by removing the lower panel directly below the door.<br /> <br /> <b><i><u>Taking the Washer out of Winter Storage</u></i></b>:<br /> <br /> To remove antifreeze from the washer following storage, run the appliance on a complete cycle with detergent and NO garments added.<br /> <br /> I hope you find this information helpful. If you have any questions, please let me know.<br /> <br /> <br />
on Aug 09, 2011 | Washing Machines
I have a GE toploader washer. The model # is WBSR1060T (VVSRV1040V, & YVSR1040V were also on the washer too) the washer keeps filling to the max setting no mater what the water level is set on, also...
Remove the front panel of the washer by using a putty knife to release the retaining clips, located in the seam between the front panel and the washer's top, about 2 inches in from each side. With an empty wash tub, remove the small hose on the left side of the outer tub and clean out the inside of the hose. Replace the hose. Test.
Mar 15, 2011 | Washing Machines
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
Water in tub
I don't know if the outside temperature has anything to do with your problem. I think it may just be coincidental. Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
I hope you find this information helpful. Let me know if you still require assistance.
Nov 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Water comes up into our tub when washer drains
The washer puts out a lot of water when spinning/ draining, sounds like the house drains are not of sufficient size or possibly blocked causing water to backup into your tub, check house drains for blockage or install seperate drain for washer into main drain that your tub goes into.
Oct 27, 2008 | Admiral AW22 Top Load Washer
Washer tub won't fill up with water
Sounds like you may have a siphoning problem. Have you checked the drain line by pulling it up out of the standpipe while the washer was filling? You may have a vacuum causing the water to constantly siphon. The following link explains this:
Having the drain hose high enough may not be the problem. You could very well have the hose stuffed in the standpipe too tight, or placed in the pipe too far. Please doublecheck and let me know if you need further assistance.
In addtion, please post the make and model number of your washer for better advice.
Aug 27, 2008 | Washing Machines
LAV3600AAW Maytag Top Loading Washer
check your house drain make sure it is above water line in tub
Nov 30, 2007 | Maytag SAV5710 Top Load Washer
Fault code fh on awm8143/1
Two questions: Is there water in the tub? Or...is the tub empty? If there is water in the tub you need to check the following: 1. Verify that you do not have a siphon problem. This is caused by placing the drain hose too far into the drain standpipe and/or sealing the top of the standpipe. This will cause water to constantly empty as the tub tries to fill. You need to have an air gap for proper drainage. 2. Check your pressure switch and pressure switch hose. 3. Make sure the drain pump is operating correctly. 4. Check operation of flow meter. This is what actually detects the water flow coming into the machine and causes the error to flash if the proper conditions on are not set. It will detect the AMOUNT of water entering the tub and it detect the pressure switch trip that shuts off the supply when the tub is filled. If there is no water in the tub you need to check the following: 1. Check your fill valve screens. Turn off the water and remove the hoses from the back of the washer. The fill valve screens are inside the hose connections on the back of the washer. It only takes a small amount of debris to restrict water. You can clean them out using cotton swabs. 2. Make sure your fill hoses are not kinked or clogged. Check the easy possibilities, first. I suspect you may have either a siphoning problem, or clogged fill valve screens. If you check everything and still have problems, I would replace your fill valve before suspecting a defective pressure switch or flow meter. Let me know if this helps.
Aug 17, 2007 | Whirlpool AWM8143 Front Load Washer
Water problems
If the washer doesn't fill properly, or if only one temperature of water fills the tub, something is probably keeping water from entering the machine or it's draining before the tub fills completely. Set the controls to the first wash cycle, and then try each water temperature setting. If both hot and cold water seem to be entering the washer with good pressure, water may be draining out prematurely during the fill cycle, through siphoning action. Be sure the drain hose's connection to the standpipe is at least 34 inches above the floor (otherwise, discuss the problem with a plumber). An air gap between drain hose and stand pipe that prevents backflow is also good to have. If hot works but cold doesn't, or vice versa: 1) Be sure both the hot and cold water faucets are turned on. 2) Be sure the supply hoses are not kinked. 3) Turn off the faucets. Unscrew the hoses from the faucets and drain them into a bucket. Hold the bucket under the faucets and test them to make sure they both work and have plenty of pressure (see HERE for information on replacing faucets). Screw the hoses back onto the faucets. 4) Unscrew the hoses from the inlet valves and clean the filter screens just inside them; these may be clogged. To do this, pry out the screens with a screwdriver (this can be difficult; the screens may be inside the valves), flush them under running water, then put them back into the hose. If the screens look defective, replace them. Then screw the hoses back onto the valves. Be careful not to cross-thread the hose threads when screwing them back onto the valves. 5) Call an appliance repairperson; there may be a defective inlet valve or a problem with the controls.
Jan 18, 2006 | Hotpoint Aquarius WD63 Front Load...
Washing Machines Logo
32 people viewed this question
Top Washing Machines Experts
