Ihave a machine of supergeneral its seens e62 error code on the display board what is the probkem
3 Suggested Answers
SOURCE: i hv an error code of e62 on media washing machine
what's the model number?
Posted on Jan 04, 2015
  • 1144 Answers
SOURCE: Zanussi washing machine showing Error Code E62, why ?
Zanussi Washing Machine Error or Fault Codes
Washing Machine Repair with Active Appliance Repairs
Posted on Feb 15, 2015
Has a e62 error
Frigidaire Washer Error Code E62 - Appliance Repair Forum > Appliance Repair Help > Washer Repair
Apr 4, 2012 - 10 posts - ‎4 authors Hello, We have a 6 year old Frigidaire front load washer model GLTF2940ES3. Up until now it's worked fine. The machine now constantly ... Frigidaire Washer error code 31
May 1, 2015
Frigidaire Affinity Front Load Washer Won't Start ...
1 post
Dec 4, 2013
Frigidaire washer E6E error
Jul 31, 2012
frigidaire affinity E62 error code
Oct 30, 2010
More results from
Oct 19, 2015 | Washing Machines
Zanussi zde47100w what else can a e62 error be
E62, is a faulty heater unit, faulty wiring or faulty main control board. You have already changed the heater unit so check all wiring. If OK, then you will probably be looking at a new control board.
Apr 08, 2015 | Washing Machines
I have a Frigidaire Affinity front load washer ATF6000ES. The lights on the control board go on and off on their own and it beeps at the same time. I've tried resetting it but have the same result. When I...
Thank you for your inquiry, Steve Lesko!
I understand that your Frigidaire washer is displaying an error code of "E62" and the lights on your panel go on and off with a beeping sound. I do not show "E62" as a valid code it could be a possible miscommunication with the control panel and I would recommend performing a reset on your range. You can do that by disconnecting the power from it for roughly ten minutes. Also, think about what may have happened prior to this occurrence. For instance, did you notice any strange functions or other error codes? With this information I can better address the issue at hand. In the meantime, I suggest resetting your washer. If resetting the power does not correct the issue, could you please inform me of the new error code or if your washer continues to display "E62". I look forward to assisting you. -Matt
Jan 30, 2015 | Frigidaire Washing Machines
Good Morning John, thank you for your post!
I see that your Frigidaire washer is continuously beeping and displaying error code E62. However, I show that the correct error code is EB2. Typically, EB2 indicates that the incoming line voltage is above 130VAC. Please verify that the power supply is correct. You may also disconnect the power to your washer for up to ten minutes by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, it would be advisable to contact a professional the since the main control board is possibly faulty.
May 23, 2014 | Frigidaire ATF6000ES Front Load Washer
E62 code on display
E62 - Power relay to heater unit faulty
Could be:
  • Heater unit faulty.
  • Wiring faulty.
  • Electronic board faulty.
At this fault appliance forced cooling cycle.
Mar 11, 2014 | AEG T57800 Electric Dryer
Washer turning on and off with beeps showes e62 error
Hello coollove60, thank you for your post!
I understand your washer shows error E62. However, it appears the correct error code is EB2. Typically, it indicates that the incoming line voltage is above 130VAC. Verify power supply is correct. If so, it would be advisable to contact a professional the since the main control board is possibly faulty.
Jan 25, 2014 | Frigidaire Affinity ATF7000E Front Load...
Error code
E62 = System Contact Error. System contact error is just a fancy way of saying the washer has a loose connection. This connection can be anywhere on the machine, so check all connection plugs by unplugging and re-connecting all connections one at a time. If you don't find a loose connection, replace the control panel.
Read more:
Jan 13, 2014 | Dryers
Zwf1430w display problem
My Zanussi ZWG1120m is displaying fault code E60 and E62
I have ben told that the machine needs to be reset. lease can anybody tell me how to reset the machine.
Feb 08, 2008 | Zanussi ZWF1430W Front Load Washer
Washing Machines Logo
23 people viewed this question
Top Washing Machines Experts
