Question about Video Game Consoles & Games
I just got the impact titan 440 about 6 months ago, qent to wpek yeaturday got a green light for just a bref second, then turns to solid yellow and does nothi g
SOURCE: Dell Dimension 8400
I have this exact problem.
The Dell Dimension 8400 will seem to randomly go into fan-jet-turbo mode on power-up and fail to boot. The problem I'm referring to is not a heat problem which an over-speed fan might otherwise suggest but a hardware problem the details I'll get to in a bit
I've done all the normal and obvious stuff that has been reported before
remove/replace memory
remove/replace AGP video card
removed all extra power loading / drives / USB etc
BIOS tweaks/resets
check supply voltages with a DMM (I even re-adjusted the hipot to get the right voltage - it was a little low)
As an engineer it is important to determine root cause. Do to this it is necessary to find a way to make the problem occur and not occur. If you're able to do this you can fix it.
Well in my case the problem it related to a mechanical stress on the heatsink. What I mean is a little force pushing the heat sink toward the fan turns off the problem (boots normally) while a little force in the directly away from the fan turns-on the problem (fan-jet-turbo-mode).
The root cause is could one of several things, it could be a damaged motherboard with a broken trace, it could be a socketing issue,
The Fix (not really - just a band-aide) was to use a tie a couple of small tie-wraps through a some small holes in the heatsink then through the fan mounting holes.
Only slight pressure is necessary - too much will likely cause permanent damage. The fan is mounted on rubber isolators so it somewhat limits the force on the heatsink
Any this mechanical issue is somewhat supported but all the information I've read - how removing/replacing the CPU can fix the problem, changing memory, removing cards - all these mechanicall stress the motherboard and likely move the heatsink some.
Intermittent problems are the worst to debug!
San Jose, Ca
Posted on Dec 07, 2008
  • 4 Answers
SOURCE: My playstation 3 stays in the "standby mode" and does not turn on
its a power failure inside the ps3!!! You have to call sony to replace the system it will cost u 150.00 dollars unless ur still under warrenty goodluck because i had to get 3 systems from sony before i got one that worked just right
Posted on Mar 25, 2009
  • 566 Answers
SOURCE: Right out of the box, my ML-2510 has a solid red error light
You should install the software prior to connecting the printer, to make sure the provided drivers are ibstalled and not the generic ones that come with Windows.
Posted on Jul 22, 2009
  • 195 Answers
Perhaps it needs the bulb, but there is also a good possibility that the lamp fan is getting clogged and shutting down the set. This is NOT the fan you see in the back, instead, it is above the lamp, and is a small blower-type fan, that tends to clog with dust. You CAN check this, when you open the lamp door,you can see the blower wheel, and if it is all dusty, it needs to be cleaned out--but do NOT just blow it out, or you might clog the engine!! It needs to be removed, and cleaned out of the set.
But first...if the blower is not too dirty...try another lamp.
Posted on Oct 10, 2009
SOURCE: On my Zenith Plasma model #Z42PX2D, when we turn
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
I have a Titan 640i painter sprayer that is older . Made around 2002 . It will not run . The yellow light flashes but the motor doesn't start. The power source is fine. The pressure is turned up.
If the motor fails to start look for a button (often red) on the motor. This is a reset button for the thermal overload protection most electrical motors of significant horsepower are equipped. Make sure the power is off, push the button to reset, then power on the motor. If the motor still does not start check to see that the mator's shaft turns freely. If not, the mator's armature is frozen due to corrosion or melt down. If the armature turns but the motor still isn't starting, another possibility is that the motor's brushes are too worn or have cracked or fallen apart due to age and/heat. Motor brushes are fairly cheap and normally easy to replace. If you're not a handyman consider taking the motor to an electric motor repair shop to check for continuity and estimate for repair. Hope this helps!
Jun 13, 2016 | Titan 440 Impact Airless Paint Sprayer...
What type of oil does the 440 titan impact use
No oil! but you have to use throat seal at the pump piston
Jan 04, 2015 | Titan Airless Sprayer Owners-service-parts...
Titan 440 wont prime
You don't clean it right what do you expect
Apr 09, 2014 | Titan Impact 440 Skid Airless Paint...
Dell Inspiron 1100 won't turn on
unplug, take out battery then hold power button for 30 seconds then plug back in and turn on
if the3 laptap gos on without the battery you need a new battery
Jun 14, 2013 | Dell Inspiron 1100 Notebook
Titan 640i wont prime
If you still have a problem with a Titan 640i please give us a call. We introduced this sprayer to the UK back in 1985. Lion Industries UK Ltd 01543 251 560
Dec 31, 2012 | Titan 440 Impact Airless Paint Sprayer...
We have a wd 57732 a solid yellow light on when turn tv on message air flow block shut down in few seconds shuts off with two green lights flashing and solid yellow acks as if room temp to warm. sometimes...
The lamp needs to be replaced. It's on the back and easy to do. I replaced mine about 3 months ago and it was about $182.00. Hope this works, I know it's hard to fork out that kind of money at this time but once you do the TV will be as good as new. Take care
Jun 09, 2011 | Mitsubishi WD-57732 Projection Television
Turn on ps3, light truns green for a second then turn red with a beeping noise?
I had this problem not a few months ago. It is the beginning of the yellow light of death syndrome. Sony can repair it if it is in warranty, or there are independent chains that also do repairs. The price to repair mine (replacing the optical drive) was $130.
Mar 12, 2011 | Sony Playstation 3 (PS3) Console
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Mar 24, 2009 | Sony Playstation 3 (PS3) Console
Video Game Consoles & Games Logo
26 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
