Question about PfaFF Sewing Machines
Pfaff 1196, needle won't pick up bobbin thread. Can I fix that?
  • PfaFF Master
  • 11,200 Answers
First, be sure you install a brand new needle. Old, damaged needles frequently will not pick up the bobbin thread. If not that, then the machine is out of time. Search the internet for sites and videos discussing sewing machine timing or take it for service.
Posted on Dec 18, 2016
  • 4 more comments
  • Gary Byrum
    Gary Byrum Dec 18, 2016
    I did the new needle. Same problem. Looked at videos. Nothing looks like the Pfaff 1199 I have. I need to see a close-up of needle positioning with the bobbin hook to check alignment. Can't seem to locate a pic of that.
  • Gary Byrum
    On a 2nd note, It appears the needle thread does loop around the bobbin thread, but it won't pull it up through the hole.
  • R.A. Ellis
    R.A. Ellis Dec 19, 2016
    The pfaff looks a lot like the Bernina 830 Record. Perhaps this would help:http://www.wikihow.com/Adjust-Sewing-Mac...
  • R.A. Ellis
    You can also try submitting your question to the Yahoo Groups: Pfaff_fixit or oldpfaffpforum Groups of very knowledgeable and helpful Pfaff enthusiasts. (You'll need a Yahoo email account and request group membership)--
  • R.A. Ellis
    http://www.quiltingboard.com/links-resou...
  • Gary Byrum
    Gary Byrum Dec 19, 2016
    Wow! A link to a repair manual! Thanks a bunch! Hopefully I'll get somewhere with the likes of this.
I got pfaff expression 2 not stitching i have rethreaded changed needle reloaded bobbin cleaned out all of bobbin area
If the thread is not picking up the bobbin thread and you have installed a new needle, then your machine is not in time. Search for sewing machine timing or take it for service.
Dec 24, 2016 | PfaFF Sewing Machines
I have a pfaff 2040 and when the needle goes down to pick up the bobbin thread the main thread wraps around the bobbin housing and jams. Doesnt grab the bobbin thread. How can I fix this?
Be sure to use a brand new needle because a bent needle could miss the bobbin thread.
Search the internet for sites and videos relating to sewing machine timing or take it for service.
Dec 02, 2016 | PfaFF Tiptronic 2040
ChaMy pfaff 2144 will not stitch properly; pools masses of bobbin thread; Changed thread, tensions, needle etc still wont sew, please advise as I am so desperate to fix this problem
bunching of thread under material is a needle tension problem
tighten it up
proper tension is when it requires a small amount of effort to pull the thread through the needle eye
Jul 28, 2016 | PfaFF Sewing Machines
I have a brother ls-2150 I can't pick cotton up from the bobbin
Try installing a brand new needle (verify it is installed correctly). If it still does not pick up the bobbin thread, the needle/hook may be out of time, requiring service.
Sewing Machine Needle Not Catching Thread
Sewing machine won pick up bobbin thread hook timing fix
May 15, 2016 | Brother Sewing Machines
Hello! My reliable 1222 has hit a snag. When try to sew, the top thread is not being picked up by the bobbin thread. How can I fix it? Pavla
try changing the needle
clean under the needle plate & in bobbin area for loose threads & lint
try rethreading the machine top & bobbin, make sure to get every thread guide
make sure the bobbin is inserted correctly in the bobbin case
Mar 11, 2012 | PfaFF Sewing Machines
How do I adjust the timing on a pfaff industrial 545?it will not pick up the bobbin thread at all.
This happened to me. Shucks, I had the wrong needle in; it was too short to reach the bobbin thread and pick it up. Installed correct needle (repair man did) and viola. . .
May 15, 2010 | Sewing Machines
Pfaff 260 bobbin thread not picking up
Hi. This can be terribly frustrating, but the most likely cause for the bobbin thread not catching is that the needle is inserted wrong. There is a flat side on the shank of every needle and that has to be facing a specific way on your machine or the needle's grooves can't make the stitch. On most modern machines, it's my experience that the flat side goes to the rear, facing away from the operator, but some of my older machines need the flat side facing to the left or to the right.
Another thing that can cause the bobbin thread not to pick up is a bent needle, but in my experience it's usually the needle not in correctly.
(Cost me $85.00 to find this out!)
Let me know if this works, ok?
Happy Sewing!
Robbie
Apr 01, 2010 | PfaFF Sewing Machines
Needle will not pick up thread from bobbin
Was the old needle picking up the bobbin thread ok? If it was, then there's nothing wrong with the machine. Check that the needle is inserted correctly--there's a flat side on the shank of the needle and where that goes varies widely by machine. Then check that it's threaded properly.
(I once had my needle in backwards and threaded wrong--took the machine to the shop cause I was sure my baby was broken. Cost me $85.00 to find out that on that particular machine the flat side of the needle faces left!)
Let me know if this helps!
Robbie
Jan 24, 2010 | PfaFF Sewing Machines
Sewing Machines Logo
Top PfaFF Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Irene Tulloch
Are you a PfaFF Sewing Machine Expert? Answer questions, earn points and help others
