How can I loading high 5 casio? - Office Equipment & Supplies
5= 4x+27 / 3.....Can this equation be solved on a casio plus?
Assuming you meant "5 = (4x +27) * 3^-1", if you enter the values as "((5 * 3) - 27)/4", I'm sure the calculator can handle that.
Sep 21, 2015 | Casio Office Equipment & Supplies
Loading problem on High 5 Casino on facebook
when i go to the game from facebook it gets to as far as connecting then just stays there b
ut
i
Feb 23, 2014 | Bold Games Vegas: Casino High 5
I was given a casio TE900 cash register and there is an eo37 error on it. How do I fix it. I was not given a manual and I really dont want to purchase one. Can someone please help
Error E037 is a high amount lock out/low digit lock out error. So you're probably entering an amount that is over the high amount limit. The manual can be found here: http://parklandbm.com/downloads/CASIO%20TE-900%20Operators%20Manual.pdf
For the steps to change the high amount limit, see page 31 of the manual. See also page 32 for an example of the high amount limitation.
Oct 24, 2013 | Casio Parts Cash Register PC Desktop
I lost my adapter to my keyboard and I need to find either a substitute or a new way to turn it on without the adapter, HELP!!!.
Some Casio Keyboards use 9V DC (center negative) others 12V DC (center negative).
If check what voltage your Keyboard use. Generic AC adapters are usually center positive. So you have to invert the wire with a new DC plug to make it center negative,
Easiest is to buy a Casio ac adapter made for your keyboard from a Casio retailer.
Sep 12, 2013 | Casio Keyboard Power Adapter
50.42 squared to 3.28
If you mean the 3.28th root of 50.42, press
3 . 2 8 SHIFT [xth-root] 5 0 . 4 2 =
xth-root is the shifted function of the "^" key.
Jun 20, 2012 | Casio Office Equipment & Supplies
My casio MS-TE caculates 100+5%=105.26315,not
From CASIO FAQS:
Why do I get the wrong answer when doing a percent calculation?
Make sure that you are following the correct procedure.
Adding 10%: 200 [×] 10 [%] [+]
Subtract 10%: 200 [×] 10 [%] [-]
Mar 26, 2009 | Casio MS-80TE Calculator
Can not load paper
Solved by itense perseverance!
Feb 11, 2009 | Casio HR-8TMPlus Calculator
Weather casio FX-115ES can solve 5*5 matrix
According to the manual for the Casio FX115ES, the largest matrix it solves is a 3x3.
Sep 06, 2008 | Casio FX-115ES Scientific Calculator
k24674
jasbo
jasbo
