Question about Cell Phones
MyMacBookAiroff of my bed onto my carpet and won't turn on. some waterfell after it fall but I saw the screen go black before the water fell I it plugged in but the light on the charger won't turn on
  • Eimme nean Dec 18, 2016
    How much money would you say that would cost?
  • Andrew Taylor
    Andrew Taylor Dec 18, 2016
    A lot as you are talking about Apple spares. Should be a little bit less than buying a new one.
  • Cell Phones Master
  • 19,068 Answers
They don't like water. You need to have it professionally serviced. It may have shorted the motherboard or the power supply board.
Posted on Dec 18, 2016
5 Suggested Answers
Bajanguru
  • 7752 Answers
SOURCE: hii
all you need to do is chagne the battery and connect the charger to the phone...it will boot up again.
Posted on Jun 04, 2008
  • 174 Answers
SOURCE: black screen fell into water and not working
you can take the battery and the back off the device and place in completely submerged in a bag of white rice and leave it in there for 1 to 2 days this will help absorb the moisture, this should fix it if the water did not damage the circut boards if the water damaged the circut boards then the device is fried
Posted on Apr 04, 2010
bijujena
  • 35 Answers
SOURCE: My LG enV Touch won't
You Go To Service center
Posted on Sep 27, 2011
  • 51 Answers
SOURCE: Motorola cellular w376g, battery won't charge
If possible test with another charger like a car charger if you have one
also try removing the battery plug in the charger and put the battery back in (don't touch the contacts/gold pins)
if it works with other chargers then the charger is bad
if it doesn't work with other chargers charging port/battery/phone is bad
Posted on May 28, 2012
My Acer ES1-512 model no.MS2394 fell over in its carrier case on carpet. went to turn it on & the screen is black & says no bootable device. What do I do? I can't get the back off to check hard drive.
Have you tried to unplug and then reboot after several minutes? Usually Hd will survive a fall on carpet. It may be that It needs to Have the bios checked and updated. I recently had several power spikes and inspite of a power supply with Serge protection, the next day I had similar issues. Had to "set up bios again".
May 04, 2015 | Acer Computers & Internet
The volume button onmy samsung s4 is not working, it is dented in the middle and now its not working right. The reason it is like " DENTED " it fell off my bed which was a fall of about 3''foot onto carpet...
I just opened a S4 mini and replaced the SIM carrier, so got a good look at the way these are made. You may be able to replace the volume key, or it could have simply slipped out of position with a very unfortunate landing. There are ten screws and 4 ribbon cable connectors plus another one between the main board and the display board. You have to decide if you have the appetite to take on a repair like this and if the part is available. You might also look for a unit that had a cracked screen but the rest is OK for swapping parts. Another possibility to be sure of is that the fall broke one of the volume switches on the motherboard off.
Feb 20, 2018 | Cell Phones
My iPad2 fell from my bed to the floor with the screen faced up and was protected in a quilted cover. Now my iPad won't turn on. Please help. All I see is the black screen. I charged it, and tried a master...
On another site, after a dropped ipad, the person did the hard reset 9 times after seeing the apple logo appear until it worked. They had it connected to the power cable all the time resetting it.
The advice at that site was it might be necessary to have the ipad professionally repaired, by replacing parts unfortunately.
Using Google, it is possible to find other suggestions.
ipad 2 fell won start Google Search
Jan 20, 2018 | Apple Cell Phones
Rainbow stripes and color changing gradient box
Since this is a problem that obviously occured because the laptop fell and the LCD got damaged I suggest you take it to a repair shop, if it can even be repaired.
May 01, 2013 | ASUS Eee Computers & Internet
Fuse
How high did it fall from? Any lights come on when it is plugged in?
Feb 07, 2013 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
32" TV fell over onto carpeted floor and won't
It's probably a write-off. The circuit board inside has been cracked so that some of the copper traces that connect parts have broken. This commonly happens around the area of the horizontal output transformer, which is heavy. The shock of the fall causes the transformer to bounce and breaks the board. Other areas too may have been damaged because of flexing. And worst, the picture tube can be damaged in a fall, so it either doesn't work at all or shows permanently distorted colors.
It's tough to find anyone willing to repair a set that's fallen. Many circuit board tracks are very narrow and hard to repair. Then it's difficult to know if all the damage has been found and repaired, so even if the set starts working a technician doesn't know if something else won't go wrong. And then there's that bad tube possibility; no technician likes to spend lots of time fixing a broken board only to find the set then needs a new tube. Trust me, this has happened to me several times during my career in TV shops.
Your best bet is to use this as an excuse to buy a new LCD or plasma TV. 40-inch models, a good size match for a 32-inch CRT (tube) model, are reasonably priced.
Jul 03, 2011 | Quasar SP-3233 TV
Sharp Aquos 15 LCD TV
Maybe. Unplug the unit and disassembly it. Look for damaged parts or cracked circuit boards. You may also find the buttons you push to turn it on and activate the menu ect. may be damaged. In most cases the board can be repaired but because that would be time consuming and the repair man charges 60 bucks an hour it is usully not cost effective. You might get lucky and find a wire that fell off in the fall. Good luck.
Apr 20, 2008 | Sharp 15" AQUOS LCD Flat-Panel LC15B4US...
Ti83 Plus
e0df163.jpg does it look something like the example I gave? Anyways, I don't think that it can be fixed. and you can either:
A.) have the screen fixed (approx. $100)
B.) buy a new calculator (approx. $85)
( the monetary figures are approxamate and should not be taken literally, the $85 is at least what I last saw one for @ a Wal-Mart)
Sep 10, 2007 | Texas Instruments TI-83 Plus Calculator
Dropped TV
Hi craigaloid your problem is the flourecent lamp on that side it could be broken after it fall have a tech look at your tv for repairs.good luck
Apr 26, 2007 | Samsung TX-R3080WH 30" TV
Cell Phones Logo
26 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
