I have error e3 on my daikin v3 vrv.hp switch,coil clean and motor ok.Could this be the main pcb?
3 Suggested Answers
farfield
  • 462 Answers
SOURCE: will you tell me the electrical diagram of 12
Remove a door Usually the wire diag is on a cover. I do not under stand why you have so many model numbers. Unless its a generic label used on all the models. and in this case the diagram will most likely be for all them too with foot notes showing the differences. If this helps PLEASE GRADE ME ACCORDINGLY. IF not I need more information.
Posted on Mar 02, 2009
ar1965
SOURCE: VRV 3 Daikin 2 pipe system. does any one know
no communication between indoor and outdoor units
Posted on Aug 12, 2012
U3 problem for vrv daikin
U3 Is a failure to carry out check operation, transmission error
This is a self diagnosis the unit does before starting to ensure both PC boards are communicating with each other. Check wiring is correct on the units, usually means one PC board has failed
Oct 28, 2013 | Daikin BRC2A71 - Simplified Individual...
Idec inverter e3 problem
This is stating that there has been a high pressure error on this system.
This could be due to fan motor or air flow problems with the condensing unit, but it could also be an issue with the high pressure sensor or switch
Oct 23, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Code u 4 - Daikin model Rxymq48mvju
U4 Is a communication error between indoor and outdoor units.
usually means one of the PC boards is faulty. If unit has been freshly installed check wiring between indoor and outdoor 1,2,3 are the same colours on both boards.
May 04, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Error code e4 on daikin split system ducted air conditioner - what does it mean?
This is stating that there has been a low pressure error on the system.
This could have been caused by a blockage in the pipe work or a possible shortage of refrigerant. It could also be due to a fault with the low pressure sensor/switch.
Jan 31, 2013 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Red light blinking and no cold air provide
Indoor fan motor is not running. Check and replace it.
Aug 17, 2012 | Daikin RXYMQ48MVJU, VRV-S Air Cooled Eight...
Daikin VRV J2
This is a fault with one of the standard compressor’s current sensors.
It occurs when the units PCB asks the compressor to run but then doesn’t recognise that the compressor is drawing any current. This can be due to a fault with the compressor contactor not coming in or a fault with either the Main PCB not giving an output to the contactor or not receiving the signal from the current sensor, or it could be a fault with the current sensor itself.
Mar 18, 2012 | Heating & Cooling
How to fix Daikin aircon error A6?
This is a fault with the fan coils fan motor.
This could possibly be due to either an issue with the main PCB or the fan motor itself.
Mar 29, 2011 | Cfm Daikin R410a Split System Air...
Daikin error code H6 Outdoor Compressor motor position detection sensor error
sir
daikin inverter air conditioner we are replace the indoor pcb then next it gone out door pcb,next we are replaced outdoor pcb also then compressor not working oftre last we are replaced compressor then it will be giving H6 ERROR CODE please give me suggestion
Feb 16, 2011 | Heating & Cooling
Looking for code E3 keeps falshing
E3 Outdoor activation of high pressure switch
Condenser coil is dust blocked.-Clean it. Rpm of fan motor is less-Replace capacitor. If over charged gas- release some gas. Check for continuity for high pressure switch, if no continuity, replace high pressure switch.
Thanks.
Feb 05, 2011 | Cfm Daikin R410a Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
