Question about Sansui Televison & Video
I reviewed other answers and did not get help with my message: "No Signal or not Supported Video Resolution"
TV is Sansui 27 SDTV about 2 years old. Best remote I have only has the function of turning set off and on.
snakehead
  • 1074 Answers
SOURCE: Sanyo DS27880 27" TV, Dish signal lost after tv turned off, doesn't return
checks should on your tv tuner it could be bad.IF circuit should also be check and the video section call in the tech to make checks on your tv.and to do repairs on your tv.
Posted on Apr 12, 2007
  • 99 Answers
SOURCE: AUX mode
Try to disconnect power for at least one day.
good luck---------tomtaso
Posted on Dec 01, 2007
SOURCE: RCA TV Model 27V412T Standby light on but will not power up
anything?
Posted on Dec 22, 2007
SOURCE: Philips 27 inch TV - Model # 27PT543S37A - Keeps going off!
SYMPTOM:
Clicks and turns off after turning on set when cold. Have to turn on and off several times to work, or keep changing channels, right side of screen is black for a while.
PROBLEM: It is almost always a bad transistor and a bad capacitor. (about $0.70 in parts)
SOLUTION:
This repair is fairly straightforward. You will need a soldering iron, a solder ******, and a small torx bit. Unplug the set. Lay the TV on the floor, screen down. Remove the torx screws holding the rear cover on. There should be 10, (don’t forget the 2 by the input panel). You will see 2 circuit boards, the one of interest is the large one near the bottom of the set. This board has a retainer clip on each side that needs to be pulled out to allow the circuit board to slide out. Slide the board out about 5-6 inches. You might need to support the board so it doesn’t slide back down into the TV set. This circuit board should have numbers by each of the components. You want to look for 7461 (transistor) and 2455 (capacitor). They are located right next to each other near the center of the board. The transistor will usually overheat and discolor the circuit board immediately around it. Warm up the soldering iron and get the solder ****** ready. Heat up the solder joint while removing excess solder with the ******. Once the transistor and capacitor are free, check the numbers on each. The capacitor (round cylinder) should have “47uf” on it. The transistor should have “C33725” on it. You can order these parts from Digi-Key (google it) for about $2.50 including shipping if you use USPS option. The part numbers are: 493-1060-ND for the capacitor and BC33725-ND for the transistor. Once you get your parts, solder them in and check TV operation. It should work as it did before. This repair can be done by anyone familiar with a soldering iron in about 30-45 minutes their first time. Good Luck!!
-Courtesy of jack of all trades on howtomendit.com.
Posted on Dec 01, 2008
SOURCE: Sanyo tv stuck on "video 2"
I had the same problem and had to buy a new remote. Just Google Sanyo remote--it's the more expensive one with more buttons. Good luck.
Posted on Dec 30, 2008
Rca no signal
check thet rca video is on the video port and rca sound on the sound port alternatively choose screen mode with remote
Jul 16, 2014 | RCA 27" Tv Sdtv Universal R.c. connections...
Sansui no signal
Acer produces a number of LCD computer monitors. Acer's monitors range from 17 inches to 27 inches. Some monitors offer wide-screen viewing, embedded speakers, high-definition visuals, and various display connection ports. Acer computer monitor problems include common issues such as dead pixels, error messages, and blank screens caused by incorrect connections. Some reviewers have also detected image problems with DVD playback on some models.
"Input Not Supported" Error Message Acer computer monitors such as the G24 may issue an "Input Not Supported" error message when users set the display resolution too high. The G24's maximum display resolution is 1920x1200 with a 60Hz refresh rate. Maximum resolutions vary according to the specific monitor model and according to the capabilities of the computer's video card. b> "Input Out of Range" b> Some Acer computer monitors may report an "Input Out of Range" error message due to incorrectly set monitor refresh rates. Much like the display resolution, each monitor also has specific monitor refresh rates with which it is compatible. Blank Screen or "No Signal" Error b> Like other monitors, Acer computer monitors feature color-coded power indicator lights. If the power indicator light shows green, the contrast or brightness levels may be set too low and should be adjusted via the OnScreen Display. If this does not rid the monitor of a black screen, the monitor may be experiencing hardware failure. The "No Signal" or "Check Cable message" may indicate a problem with the monitor's cable connection with the video card. This error may also appear on a blank screen backdrop if the monitor is plugged into the incorrect port on the computer or if the computer is frozen and needs to be rebooted. Faulty power cords or outlets may cause the screen to be black and to show no power indicator color. b> Image Issues b> Some review sites such as CNET have reported problems with streaking and ghosting during DVD playback on some Acer computer monitors such as the AL1931. (A "ghost" is an identical offset image as the primary or desired image.) Unstable or unclear image issues may be caused by incorrectly programmed VGA timings or incorrectly installed monitor drivers. b> Dead Pixels b> Dead pixels and sub-pixels can cause a variety of display enjoyment problems. Acer will only accept returns on LCD computer monitors that have "more than four (4) defective pixels per million pixels." Further, the central area of the monitor may have no more than one defective pixel. Acer does not differentiate in warranty terms between pixels and sub-pixels. Hope this helps.
Jan 20, 2013 | Acer Aspire 4720 Notebook
Sansui sdtv is having a color issue ~ green is gone and picture color is more pink or red than before
To or three likely possibilities, there is an open element in the green gun of the picture tube, or the emission is very low, the other possibility is a shorted video driver transistor on the video board.
Jan 30, 2011 | Sansui 27" TV
I own a Norcent TV model LT-1931. I am a DirectTV
Out of range = the tv receives a signal with a resolution higher than it can display. Connect your DirectTV to another tv and make sure that the signal is one supported by your tv (any SD format will do). If it is then connect your tv to a pc and test the supported resolutions - if none work or the image is bad then the storm has fried its image processor - a repairman should take a look at it.
Jul 29, 2010 | Norcent Technologies2703 27" TV
Unsupported video signal
It is possible that Jewelquest changes the screen resolution to one that is not supported by the TV. I am not familiar with Jewelquest, but the typical reason for the unsupported message is a resolution outside of the supported range. The supported resolutions should be listed in the owner's manual. Dan
Jun 12, 2009 | Toshiba REGZA 47HL167 TV
Cannot see computer through vga- connected cable and keep getting "no signal or not supported" message
Your computer may be sending out a signal that too high of a resolution for the TV to display. Try reducing the resolution of the computer video signal.
May 11, 2009 | Sansui HDLCD-2600 26 in. LCD Television
There is no picture and it shuts down and then tries to restart
Your set is not receiving a valid signal for the resolution of the set and shuts down as a self-protective measure
so you have to make sure the source is sending what the set needs and then it will show a picture at the
acceptable resolution.
Do you know the range of resolutions allowed with your set?
They are:
Broadcast Format Displayed: 720p (HDTV) · 480p (EDTV) · 480i (SDTV) Broadcast Format Supported: 720p (HDTV) Digital TV Standard: HDTV - HDTV receiver is integrated. Built-in Tuner: NTSC Aspect Ratio: 16:9 · 14:9
Apr 17, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
My Sansui DTV2798 is V-Chip protected I need a code.
I HAVE A SANSUI TV MODEL DTV2798 AND THE VCHIP IS ACTIVATED. I DO NOT HAVE THE CODE. DOES ANYONE KNOW HOW TO FIX THIS ISSUE?
Mar 01, 2009 | Sansui 27" TV
Sansui tv
The DTV2784 has a SDTV tuner and is ready to receive digital broadcasts, but it is not HD(high definition).
Jan 04, 2009 | Sansui 27" TV
Televison & Video Logo
26 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
