Question about Sony PlayStation 2 (PS2) Console
Hi,when i switch on my ps2 some buttons of the dual shock conroller doesn't work,he i disconnect it and reconnect it and also reset the ps2,the controller will work again.but still sometimes after that the controller doesn't work but will work(also sometimes)when i save a game.it's really irritating.anyone has any idea why this is happening?
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 80 Answers
Your controller is coming to the end of its life you must start thinking about a replacement. you can find replacement controllers at all the retail store very cheap walmart, Kmart, target, gamestop, if you like you can order new or used from eBay at very good prices ......I hope this helps you
Posted on Jul 21, 2009
My mad catz dual force ps2 controller wont work
you will need a dual shock 2 ps2 controller. The mad catz controller is probably a dual shock 1 controller. Some games require the dual shock 2. It should say on the back of the game if the dual shock 2 is required. If it says something along the lines of "pressure sensitivity" or "pressure sensitive" on the back of the game case (where it says "1 player" or "2 player") ... then you will need a dual shock 2 controller. If this is not the case and it only says "analog controller" and "vibration" then you won't need the dual shock 2 controller. If the controller doesn't work for any games or even on the console main screen, then it must be the controller that is broken. Try turning the system on without a game in it and see if the controller works. Hope this helped :-)
Oct 16, 2012 | Mad Catz PS2 Dual Force Controller
My ps2 joystick L3 button stuck when i derict it to any direction .. it suppose to back into its center position but it doesn't it stuck and still unmoved untill i move it back to its original pos
I would suggest buying a new controller if you want to skip the hassle of trying to fix this one, but if you insist on keeping this controller, then there could be a way to fix it. First try your best to smoothly trace the joystick around in a circle, and see if that unsticks it. If this doesn't work, apart from buying a new controller the only other thing to do would be to open the controller up and put lubricant on the bottom of the joystick, this will most likely work, but you might damage your controller in the process.
Oct 11, 2012 | Sony PS2 Dual Shock 2 Controller...
I noticed that every time I buy new PS2 Dual Shock 2 it only last for 3 months because I play to much almost everyday then when I try to open the black wire of the dual shock the colored wires some...
Hi, This is happen because : 1. You may bought a non original controller. 2. You may always engage the vibration function. Sony dual stick controller ( analog stick) has fine cables inside controller. The imitation ones even smaller. While you use the vibration function for long time, it make some cables apart.
Suggestion :- Use only original dual stick controller ( analog stick). Don't engage vibration function for long time - I believe you can reconnect the wires inside controller ( so just fix it yourself) and play..
Dec 01, 2010 | Sony PS2 Dual Shock 2 Controller...
PS2 dual shock controller not responding
that means you have to get it to a repair shop or just buy a new one !
Jan 11, 2010 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock black controllers are not recognized?
1.) i think u r controller pin is bend are broken
2.) or controller wire is cut
its better 2 buy a new controller
peace out >>>>>
Jul 26, 2009 | Sony PS2 Dual Shock 2 Controller...
Options menu dead
hi!there,
well! you can't activate what you want because the button "x" and " triangle" are the function key to move on but because of the pads inside your analog controller on "x" and "triangle"are worn out,there is carbon contactor on buttons has fade out,when ever you press x button no connection is conducting your analog controler.you can change setting on analog controller between x and square depend on you,go to configuration then on dual shock controller menu reset function button,you select a key that will change the function key.
or maybe replace your dual shock controller is the best way,
have a nice day,don't forget to rate me,thank's
Apr 27, 2009 | Sony PlayStation 2 (PS2) Console
Directional buttons not working on both PS2 controllers
Try them on another playstation 2. If the same problem occurs, then the controllers probably or broken. Did it get banged around a lot? Is the cord ruptured or something?
Hopes this helps!
Jan 30, 2009 | Sony PS2 Dual Shock 2 Controller...
Directional buttons not working on both PS2 (controllers
the wire must have been.. twisted.. due to the way you keep it.. dont twist the wires around the controller to avoid this problem.. n.n
How to check terminals on a dualshock2 ps2 controller
does it stop working?or stopped vibrating?if the vibration stopped then wire connecting to the rotating motor is detached this is the common problem with dual shock because of constant vibration.Solution is to open the controller and connect the loose wire,dust is also a big factor if buttons are already not responding so try also to remove accumulated dust on the button touch board.
Jan 24, 2009 | Sony PS2 Dual Shock 2 Controller...
Ps2 dual shock2 controller buttons not working
Removed accumulated dust sticking on the board were the buttons touches.use cotton balls with alcohol or use clean damp cloth.If nothing's happen check the cord I'm sure it is twisted badly, open your ps2 use this controller and try to twist back the twisted cord if it stopped sometimes when your twisting it then you have to replaced the cord(make sure that your using the original ps2 controller not imitation)pls. rate
Jan 17, 2009 | Sony PS2 Dual Shock 2 Controller...
Sony PlayStation 2 (PS2) Console Logo
89 people viewed this question
Top Sony Video Game Consoles & Games Experts
shaun taylor
marley mcelhinney
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
