Question about Health & Beauty
My pocket scale is one point off how to fix - Health & Beauty
My accura8 scale wont show the calibration mode
What model? Could be the battery need to be changed.
tobacco is selling out their accura8
Sep 29, 2017 | American Weigh Scales Aws Chrome 1kg...
What does it mean when my us-magnum 1000xr pocket scale says rCAL and keeps flashing 500.0
You need to send it out to the manufacture and have it recalibrated. Hence the code RCAL.
Feb 24, 2017 | Pocket Health & Beauty
How do I fix a manlloro digital pocket scale when it reads HHH?
I thinkn there is a reset button to press with no weight on the scale if I remember correctly. Might have to calibrate with the test weight too if the calibration is messed up (not likely though).
Jan 03, 2015 | Health & Beauty
How can you fix error on screen can it be reset
It often just needs recalibrating. Try turning the scale on while holding the mode/tare button with nothing on the scale. Then press the tare button again. It should show a calibration weight which you should put onto the scale. Then it automatically calibrates.
Nov 30, 2014 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
My pocket digital scale says full?
some one help ..when i turn on scales it says full what does that mean how do i fix
Nov 21, 2013 | Health & Beauty
My ProScale XX 250 shows out2
I had this problem with my Silvercrest kitchen scales model z30170. Being wall mounted the weighing platform was on a fold-down flap . It turned out to be a broken wire in the hinge joint.
Dec 28, 2012 | Tanita 1479V - Digital Pocket Scale /...
What does Errh mean?
Display - (ErrH) Errors - The value counted at zero point is too small.Items to be checked - Distortion of the load cell assembly.Repair & replacement methods - Replace mechanical assembly.BASICALLY - The error mention relates to a distorted/damaged loadcell. It will be uneconomical to repair this unit.
Aug 21, 2012 | Tanita 1479V - Digital Pocket Scale /...
DigiWeigh pocket scale showing..UnSE code..what is UnSE code?
Remove the battery - this happens when the scale tries to use a dead battery instead of the wall power supply.
May 02, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
Health & Beauty Logo
49 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
