SOURCE: location of block heater cable on 05 F350 diesel
The block heater is already installed in your 6.0. The cord may not be there as it is an option in some states and standard equipment in others. The best way to see if your cord is there is to crawl under and look up by the # 4 cyl and you will either see 2 prongs sticking out for the cord or you will see the cord. The cord should end in the front bumper behind where the front tag would be. If you dont have the cord Id suggest getting it off ebay as it should be cheaper than the dealer. Hope this helps.
SOURCE: exact location for block heater for 1997 ford 7.3
It is located on the left side of the oil filter housing.
SOURCE: i have 05 volvo vnl 670, isx cummins 450/500.
I have a 2007 Volvo 670. The check vehicle ecu comes on. The fault code is MID 144 PID 191 FMI 5. THe truck won't go pass 1400 rpm, the speedometer doesn't work, the cruise doesn't work, the engine break doesn't work. I have to turn the truck off going down the road at highway speed for about 10 seconds and it'll go back to normal. Can anybody help?
SOURCE: location of block heater cord on grand prix 2004
could be anywhere since they are owner installed but usually through grill or under hood
You will likely need the heater hose junction (Volvo p/n 3522035) since it always leaks and it connects the heater core to the heater hoses on the firewall. The kit usually contains the retaining clips, but not the O-rings to connect to the heater core. You will also need the outlet and inlet hoses (9186847 and 9186849). The length, angles and configuration of these hoses will help you understand their orientation in the engine bay. They can only go on one way. Else, they won't connect to the pipes from the engine.
Testimonial: "Thank you very much for your time i really do appreciate it Thanks again Jimmy Cummings"
