Question about Saniflo Home
My SaniFlo under sink doesn't pump water out unitl i unplug and re-plug in
  • 19 Answers
SOURCE: kitchen sink soap dispenser won't pump
soap may be too thick or pump tube may not be touching soap in dispencer. try pumping same soap from cup
Posted on Jul 07, 2009
venexcsd
  • 1185 Answers
SOURCE: The water from the loo and shower is rising & not going down
The outlet is blocked , get an engineer in to fix it pronto
Posted on Aug 24, 2009
  • 82 Answers
SOURCE: my saniflo will not pump out and water is backing
Probably blocked on the intake pipework. You'll need to get the Saniflo out, clean out all the build up from the inside and try again. It is probably an idea to try and clean the pipes as well.
Not really advisable to use Mr.Muscle or other drain cleaners on the Saniflo range as it can eat the seals.
Good luck
Posted on Jan 17, 2010
  • 37 Answers
SOURCE: saniflo pump has a delay, kicks in 15 mins after flushed.
Either the rubber membrane or the microswitch is at fault.
Posted on Feb 26, 2010
  • 1015 Answers
SOURCE: pump keeps running and i unplug it and wait 30
It sounds to me like the impeller is not engaged with motor shaft. I would remove pump and check and see if set screw is loose or if impeller is broke. Thank you.
Posted on Dec 25, 2010
I have had a saniflo operating fine behind my ensuite toilet for 2 years. The saniflo drains into the waste pipe after the AAV and before the bathroom sink. Recently when we flush the toilet and the...
may need a backflow preventer in the waste line under the sink..it is basically a ball on a spring..designed to make the water go only one way..I am guessing the wasteline was opened up with a plumbing snake..that pump may have too much backpressure from the head line..
Jan 25, 2014 | Plumbing
Saniflo is working its only connected to a sink but only pumps three quaters of the water away then stops and leaves rest of water in the sink
Sounds like the pump needs to be de-watered completely and cleaned. There is a pressure chamber that contains, I am guessing here since I hve never taken one apart, a float and a microswitch. If the float gets heavy with gunk or gets a hole in it, it will not float as well and will take more water in the drain pipe to cause it to rise up and activate the micro switch. I don't know how hard it is to disassemble these units but hope it is fairly simple since they are pricey. You said it was only on a sink, not a toilet or both. It is possible that grease has built up (the gunk) and a hot water flush may do the job for you but it will take a lot of hot water flowing through the grinder, that of some grease dissolving drain cleaner.
Oct 02, 2012 | Saniflo Sanibest Grinder Pump Only 013
My Sanilflo system is fed by a toilet and a sink. When the sink fills it to operating the grinder runs for about 5 seconds and switches off. When the toilet is flushed (no solids) the grinder runs for...
The amount of time that the pump operates is determined by the amount of water that is drained into the unit. If the amount of water from the sink is less them the amount flushed then the pump will run accordingly.
Mar 06, 2011 | Saniflo SANIBEST Pump Macerator Grinder...
Pump keeps running and i unplug it and wait 30 min. and i still runs when i plug it back in and if i run water in the sink it backs up so i know the water is not getting out
Dec 25, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water won't drain from sink or shower and the system is whirring away.
there is a blockage in the saniflo pump or the saniflow outlet pipework
Dec 07, 2010 | Saniflo 002/003/005 Saniplus Toilet with...
Saniflo sanibest continually running , noisy ...
The float switch will be the problem.
We do not replace the switch, just change the unit as labour to strip and replace switch makes it un economical.
Jan 28, 2010 | Saniflo Sanibest macerator with multiple...
My saniflo will not pump out and water is backing up in the sink
Good luck
Jan 04, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Saniflo not flushing corectly
Does the shower or sink back up into the toilet bowel after running for a few minuits?
If not:
The bowel is clogged. Fill it with water then use a plunger
Nov 21, 2008 | Saniflo Sanibest Grinder Pump Only 013
Water leak from turboflush saniflo
water inlet pipe blows off when toilet is flushed
Nov 11, 2008 | Saniflo 013/005/007 Sanibest Toilet with...
Home Logo
71 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
